Reset Hitachi Rear Projection Television 50EX12BAV5K022561
  • ducatiman911 Apr 09, 2011
    Well here is the problem the TV turns on and changes channels. When I go to the menu items via the remote. none of the menu options work. I can scroll to and select an option and press the enter button (as per the manual instructions) but nothing happens.
    President:
  • 1,654 Answers
There are no resets. The only way to reset a tv like this is to unplug the unit for several hours and let the memory and capacitors drain before restarting. Have you checked you manual for lamp hours reset and how to change the bulb? These sets need to have lamp hours reset when you change the bulbs or they won't turn on. I might just be possible your bulb has burned out.
Posted on Apr 09, 2011
  • 4 more comments
  • Dcramer531
    Dcramer531 Apr 09, 2011
    That almost sound like an issue with the remote! Are you sure the enter button is working? if not then it might very well reset it self in the manner I listed before. A complete power down for several hours or better yet overnight.
    i've tried the power down for several days actually. Yes the remote functions properly i took it apart and tested it all the buttons work.
    Well here is the problem I have Hitachi rear projection TV model # 50EX12BA V5K02256 the TV turns on and changes channels. When I go to the menu items (to program the channels for example) via the remote. None of the menu options work. the remote works I can scroll to and select an option and press the enter button (as per the manual instructions) but nothing happens. Is there a way to do a hard reset to return the tv back to factory settings?
  • Dcramer531
    The only other thing that can cause this is the software in the machine and this might need up graded. have you done an upgrade lately? if so that could have caused this issue. The tv other wise is working correct? just having the trouble with menu items right?
  • Dcramer531
    I will look through some manuals and see what else I can find on this. there is a factory reset but that is usually in the menu items most times under settings.
  • Dcramer531
    You also could try holding the power button in for 5 sec or so and the set should start then stop and this is a mini reset also unplug the set and remove the small battery in the back of the set and let it sit for an hour or so before you replace the battery and then plug it back in, This should clear any memory and could possible clear this up.
Hitachi 51s500 screen is flashing, but no real picture or sound, where is the master reset button?
this set has no reset button at all. If the screen is flashing is it red,green, blue, 3d or what? This may be a clue to what is wrong.
May 05, 2012 | Hitachi 51S500 51" Rear Projection...
65SWX20B 65 in. Rear Projection Television: how do i clean my Hitachi 65SWX20B 65 in. Rear Pro...
Remove the upper back cover of the television and clean the back of the screen, the mirror which reflects the image onto the screen, the focusing lenses (do not loosen or remove the wingnuts).
May 05, 2010 | Hitachi 65SWX20B 65" Rear Projection...
Hitachi 43FDX20B 43 in. Rear Projection Television magic focus
Hi, replace the convergence IC`s and any fried resistors and chemical fuses (if any), do not push magic focus anymore it will not correct the prroblem and it will evenntually corrupt the DCU and cause you more problems (and of course more money), questions? ask awayy, video-tek
Feb 02, 2009 | Hitachi 43FDX20B 43" Rear Projection...
Color problems with Hitachi 57in rear projection
One or more of the projectors lights( my guess is the green one) are either blown or in the process of going bad. Have them repaired or replqaced by an authorized tech.
Dec 28, 2008 | Hitachi 57F500 57" Rear Projection...
Too large of screen on hitachi rear projection tv
Some models had a 'zoom' feature on the remote, don't know why only some channels would show and others not. Try unplugging it overnight, maybe it will reset.
Jun 28, 2008 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 50UX57B 50 inch Rear Projection smearing...
try this
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Sep 18, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 53fdx20b rear projection color tv with no picture
Reset tv to factory settings refer to your owners manual. If still no picture attach a DVD or video player and test. If still no pic refer to tech.
Apr 08, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 52 projection tv
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
Televison & Video Logo
197 people viewed this question
Top Televison & Video Experts
