My indoor unit while getting cooled throw sprinkle of water
  • 413 Answers
If this is in the wall or window, the unit itself is not tilted back enough for the water to drain out the back
Posted on Apr 09, 2011
How can resolved PJ error in daikin vrv 2
PJ is an error that has to do with the outdoor unit not matching the indoor unit. This means the outdoor board thinks it's a 2 ton unit and the indoor thinks it's a 1 ton unit. (Just throwing those numbers in)...but, the indoor is not matching the outdoor. You need to read the manual and go through the setup process.
Jul 30, 2017 | Heating & Cooling
A/C Unit SAMSUNG -Outdoor unit model= MH080FXCA 4A was connected to 3 indoor units:
It's possible you have a bad data wire on one of the systems. Swap the data wire or both if two with a different wire. (1&4--2&3) whatever. Whatever you do inside obviously do outside. Might have extra resistamce that is throwing the error but will be fine for a ground wire.Or do one system at a time, being sure to change your dip switch settings until you figure out the problem unit. Good Luck!!
Apr 19, 2017 | Samsung Heating & Cooling
Flashing light the at says e6
Usually Indoor Unit Anti-freezing protection (Cooling
Mode) or Over-heating Protection (Heating Mode)
for Evaporator
A) Indoor room
temperature too low
under cooling mode,
Too high under
heating mode
B) Indoor unit filter or
evaporator too dirty
C) Indoor unit fan motor
blocked
D) Insufficient refrigerant
under cooling mode
E) Indoor unit evaporator
sensor wrong
connection or failure
Jul 28, 2014 | Samsung AQV12VBE Vivace Wall Heat Pump Air...
Yapmagic split unit aircon
if the indoor unit is throwing air but no cooling then check if outdoor is throwing hot air or not. May be the refrigerant has leaked. call a technician.
Jun 20, 2013 | Heating & Cooling
Mzb-12a icemaker every thing appears to be functioning but unit is not making ice
Thanks so much for the help, I was fixing to throw the ice maker down the street when I read your post I got it working. Thanks Joey Jacksonville Fl
Apr 07, 2013 | Refrigerators
The indoor unit of my 1.5 T , 2 yr old split ac is making noise like cracking of ice or plastic whenever the compressor is tripped or restarted. I've noticed water leakage (splash) from indoor un
indicates dirty evaporator fins that are icing up
that will overload the compressor and trip it
the ni oise you hear is the ice breaking up and the splashing is excessive water in the blocked drain that cannot run outside
get in a technician to clean and service the ac
Nov 24, 2017 | Heating & Cooling
Water dripping out of Mr. Slim on indoor unit.
Reason for water leaking.
1. Filter block. 2. Cooling coil block. 3. Alignment of indoor a/c unit is sloping downwards. 4. Drain pan block. It's advisable to service your unit first.
Jul 02, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Throws or sprays lots of water out the front on a daily basis which is soaking the carpet and furniture. The window unit is over ten years old and has been running non-stop for at least 5 years.
It sounds like that unit is getting a bit low on charge and is freezing up a bit....maybe even needs a good cleaning of the indoor coil... that would make it freeze also.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 02, 2010 | Daewoo DSA-122L Air Conditioner
LG Split Ac-Sprinkles water in roomafter a while of cooling
first check to make sure that the indoor unit is very slightly off level sloped to the drain area also turn off power and inspect the indoor coil with a flash light to make sure all the fin area is open the drain pan has two possible drain connections if they are both hooked up then the primary "lowest"
could be stoped up a blast of water or air to the drain line should clear out slime also make sure their is a trap in the drain line or the water will only drain dwhen unit is off hope this solves your problem thanks
May 15, 2009 | Heating & Cooling
Leaking water
water leakage from indoor unit
1.clean cooling coil
2. wash air filter
3. check drain tray.if it block then clean it
4. check drain pipe U band.
5.check indoor unit water tray.if damage change by new one or repair it
Sep 04, 2007 | Friedrich QuietMaster RS10J10 Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
