Washing machine does not seem to get cold water and pauses with a beep beep sound
  • 415 Answers
Shut off the cold water and remove the water hose you'll find hardwater build up at one end of the hose screens or at the valve connection.
Posted on Apr 09, 2011
Hello. Recently my fisher &PAkel smart drive 703 was removed from its connections as we renovated our laundry. When it was reconnected by our tiler, it stopped working properly. This is what hap
Need to know the error code to help you. When it beeps, take note of the top row of lights & count from right to left. Tell me exactly which lights are on & which are off. Also, tell me if any other lights are blinking. The only thing the tiler would of disconnected are the inlet water hoses. Check that the hose from the cold tap is on the cold inlet & hot tap is on the hot inlet. Marked C & H on back of panel.
Mar 06, 2017 | Fisher and Paykel Washing Machines
Fisher & Paykel Kelvinator Smart Drive 601. Machine does not complete full cycle. Stops at most stages and beeps. Seems to have trouble with water intake. Hoses have good water pressure when...
the magnetic switches may be warn. in hard water areas they can block up and stop working. you may need to change them or take them out and stick them in some vinaga and see if it will soffen the hard crust off the inside of them out.
Oct 06, 2013 | Fisher and Paykel Washing Machines
Whirlpool duet washer fills with water (maybe overfills) then stops and the wash light flashes an 8 then 1 type sequence
Hello, we are sorry to hear that you are experiencing this problem. We would recommend having a certified technician out to take a look at the Washer and give the appliance a proper diagnosis. If you would like further assistance you can send your name, phone number, address, model/serial number and the date of which you purchased the Washer to Whirlpool_Reviews@Whirlpool.com.
Apr 18, 2017 | Whirlpool duet Washing Machines
Tried to do a load of laundry and the water doesn't seem to come. The machine beeps and flashes F and then H or vice versa
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 03, 2011 | Kenmore Elite 45986 Front Load Washer
Not getting enough water
Hi just read your posting.Now what water temp are you using for you wash cycle?Is it cold , warm or hot?Problem could be your cold water valve not opening enough or your motor controller.If you selected a COLD wash how fast does your cold water come in to the machine?Please reply with additional information on the questions and I can help you rectify this fault.Looking forward to your reply.
Jul 27, 2010 | Fisher and Paykel IWL12 Top Load Washer
The washer is set on cold/cold. The hot water faucet is turned off. The washer should not be asking for hot water because it is set to cold/cold. It asks for and received cold water. At some point...
Newer machines know the water temperature. It will mix hot water even on a cold setting if the incoming water is too cold. Detergents need a temperature of at least 60 to activate.This will only happen in the winter usually.
Feb 24, 2010 | Washing Machines
Rental...no manuel...first time using washer. pushed regular, large, cold, pause resume. When it finished filling with water it beeps 3x than stops for a couple minutes then beeps 3x etc. It is filled...
Your problem is with the pause/resume button. This button allows you to add/remove items before the cycle is complete. If you press this button and there is water in the machine it will beep for a period of time (3 mins) and then empty the machine automatically so you can open the door. After opening the door the cycle can be restarted again by pressing the pause/resume button again.
Nov 07, 2009 | Washing Machines
Intermittent water flow interupted by solenoids pulsing
I've got the same problem. If I pause the cycle, wait about 10 seconds, and then resume, the water starts normally. I suspect the Cold Water Inlet Solenoid is sticking, probably due to water sediment in the solenoid causing it to stick. I'll try cleaning it and then replace if that doesn't help and let you know what happens.
Sep 22, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
