Question about TC Electronic TC Helicon VoiceLive Touch Portable Vocal Effects Processor
Hello, I lost my power adapter for my voicelive touch. What sort of power adapter do I need to replace it? I tried to use one but it didn't work and the system said BOOT, and then nothing showed up.
2 Suggested Answers
  • 5603 Answers
SOURCE: I want to buy a
Check your pwer adapter as MANY of them will take 100 to 240 volts inout... if yours does, you are go to go... else here is one that will work as it is a worldwide type:
http://lcdpayless.com/productpage.php?productId=6679
Posted on Mar 12, 2011
My zoom g1x displays BT even though i don't use any batteries for it
You need to replace the power resistor R54:
http://gisywall.blogspot.it/2016/01/zoom-g1xn-continuously-shows-bt-on.html
Sep 28, 2012 | Samson ZOOM G1x Guitar Effects Pedal
How to connect a vocal processor to a peavey6 mixer
Set the voice input level on the voicelive2 by following this guide from the live 2 manual... Step 4: Set Mic Level This step informs VoiceLive 2 how loud you plan to sing with your particular mic. We'll use VoiceLive 2's automatic MIC GAIN feature to quickly set the optimum level. 1. Press and hold the REVERB footswitch 2. If you need to activate phantom power for your condenser mic, adjust the onscreen PHANTOM parameter which will restart the level test 2. Sing for five seconds with peaks that are as loud as you plan to sing 3. Follow the prompts in the display to finalize mic level setting, cancel or redo the procedure During performance, if you see the CLIP indicator light in the HOME screen, you can return to the automatic
MIC GAIN feature to adjust the input level.
When input level is set on the voice live ;
on the mixer set
the gain control to 12 o'clock position and
individual channel volume level to 7 ....raise the master volume
slider to hear mic input at desired level and without feedback
Jan 15, 2012 | Peavey PV6 Mixer
Casio lk-33 does not work with external power adapter. The unit will work on battery power. The connector for the adapter provides power to the power board, but the unit does not work. I don't have a...
I once had this problem with another Casio synth.
I hadn't the power adapter ant I tried with an other one, with the same specifications : the synth was apparently powered but it didn't work.
I finally understood that it was a problem of polarity (+/-). You may just have to cut the cable and resold it inverted.
Hope it could help!
Nov 05, 2011 | Casio LK30 Note Lighted Keyboard
HI, unfortunately I lost the power adapter of my Gemini FX 7000. I want to replace it with a universal power adapter with the accurate voltage but the connector is quite weird for a power supply (RJ 45)...
Don't even think of using a universal adapter !!! I could not find the schematic of this unit, but other Gemini mixers like this use center tapped AC power transformers. Any universal adapter will be DC, not AC. I have found that the FX7000 indeed uses an 18 VAC adapter... Try this as a source:
http://www.topdjgear.com/gemini-110vac18v.html
Jul 05, 2011 | Gemini Sound Products Gemini FX7000 10...
I have an Alesis SR16 drum machine. It fires up ok and you can select a drum pattern, but the output is barely audible. Only by bringing the volume on the machine and the amp right up can you hear anything...
What power adapter do you have on this? This one REQUIRES and AC input, NOT a DC adapter !!! Many people try DC adapters on these because they lose the original and ALL fail. You need a 9VAC at 830ma or more adapter. If you have lost yours, search for "SR16 power adapter" to find replacement.
Apr 27, 2011 | Alesis Sr 16 Stereo Drum Machine
I want to buy a voicelive touch from the states,what do i need to do to make it work on australian 240 volt power
Mar 12, 2011 | TC Electronic TC Helicon VoiceLive Touch...
I cannot turn on my Micro BR - its plugged in and has new batteries but still won't work Does this mean it's completely broken or is there some sort of stand by phase that may have initiated itself?
The devices that have battery AND adapter capability OFTEN have a switch that the adapter opens when powered by the adapter. Often this switch contact gets bent and units won
t run on battery, so try it on an adapter... if the adapter works and battery doesn't, this contact whcih is a part of the input power connector has failed.
Sep 06, 2010 | Boss Micro BR Digital Recorder
Power adapter specification ct-630
Hi - look in back or under keyboard for power specs.Then go to Guitar Center and the right adapter. GuitarCenter.com has casio power adapters.
Jan 04, 2010 | Music
Yamaha YPT310 use of wrong adapter fried fuse won't power up
1200 ma provides more power than the 700 ma, and would not be affected by using it on a device that draws 700 ma. The voltage of the charger makes a difference as well as the polarity of the plug. (if it is dc)
If the 700 ma charger is not working, most likely the 700 ma charger is not working
Sep 16, 2009 | Yamaha Portable Keyboard with 61...
TC Electronic TC Helicon VoiceLive Touch Portable Vocal Effects Processor Logo
343 people viewed this question
Top TC Electronic Music Experts
Michial Gueffroy
bigdawg7299
Tom Chichester
Are you a TC Electronic Music Expert? Answer questions, earn points and help others
