Question about RCA HD52W59 HDTV Projection Television
I can't get my RCA HD52W59 to autoscan the digital tuner... only the analog tuner will work. Was working before we replaced the convergence fuse. Also, when you turn the TV on, it comes on in setup mode and you have to clear it everytime.
  • RCA Master
  • 5,138 Answers
When you replace Fuse on the defection board Did you Resolder FBT flyback Tansfromer?
You also need to resolder around the Hori circuit ,in front of Hori output transistor.
Posted on Apr 09, 2011
My rca hd52w58 on autoscan will only find 4hannels MY Visio fines 38 suspect digital tuner any suggeationas?
Could be a tuner but a simple way to find out is DIRECT ENTER with the remote (numbers) a channel and hit enter---if it goes to missing channel you can manually in the menu with the remote ADD each missing channel one at a time--tedious but will rule the tuner out.
Almost every set made is able to add or delete channels one at a time.
Apr 15, 2012 | RCA HD52W59 HDTV Projection Television
I see a possible fix for missing convergence on a rca hd52w59 by replacing the convergence fuse. I've looked all over and can't find it. If it really has this fuse, where is it??? Thanks
If your looking in the rear of the set on the far left side you will see a large black HV transformer that has a large red wire coming from its top. Thats the flyback transformer look directly to the right of that and you will see three small brown rectangles with FL221, FL231 and FL251 stamped on it. The center one is FL231 if thats blown the set will have a 3D look and the auto convergence feature will no longer be listed under the setup menu.
Dec 18, 2011 | RCA HD52W59 HDTV Projection Television
Rca tv modle #hd52w59 convergence problem need to know cong.location
if you need to know where the convergence settings are you click menu then setup and then convergence. I have the same tv as you and the picture looks like its 3d with red and green and the words on menu are doubled and I tried auto converge and it didnt work. If you figure it out let me know. it also might be a fuse.
Nov 01, 2010 | RCA HD52W59 HDTV Projection Television
Rca convergence ic's
RCA projection televisions usually utilize descrete component to achieve convergence. The most likely candidate for this problem is a small fuse that is open on the back of the deflection board. This is usually caused by a cracked soder joint. Either at one of the pins of the IHVT or the rectifier connected to it. Re-soder all of the points on the fly-back transformer and replace the fuse. This should correct your problem.
Dec 20, 2009 | RCA HD52W59 HDTV Projection Television
My convergence keep going out, I replaced the convergence twice. I have a rca hd52w59 modle
When you say replaced the convergence twice, are you refering to the convergence boards or the FL231 fuse? If its the FL231 fuse unless you replaced the DL231 and CL230 plus reflowed the solder on the flyback it will continue to keep blowing untill the 3 parts are replaced together and the flyback gets resoldered. If you replaced the convergence boards then try resoldering the flyback.
Nov 27, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 convergence problem
Point-by-point convergence can be set by a good technician, but the controls are not accessible to the customer. also check the fuse in the power deflection board.
Jul 26, 2009 | Televison & Video
RCA HD52W59 wave
OK those are the correct fuses one in middle does cause lost of convergence FL231,recheck second ribbon connector, make sure it is in correctly also ck cp 150 it will be a green and gold writing on capacitor 2200uf 16v ,see if it is bubbled on top if so replace it and 2 other caps 220uf 35v,what you are saying about it waving could be a big capacitor on small AC board where ac fuse and cord plugs into ck them .Let me know if you need more help . Resolder all connection pinns on flyback.
Dec 03, 2008 | RCA HD52W59 HDTV Projection Television
ITC222 - RGB flickers using Tuner
its the Tuner rf gain voltage or AGC not set properly.
Dec 09, 2017 | RCA HD52W59 HDTV Projection Television
Convergence off on Digital Cable
convergence for the rca itc222 is set individually for digital and analog tuner. Most of time the set will have to be converge in service mode. as a tech i would not recommend getting intoservice mode. but the key is the the convergence has to be set indiviadually for each tuner. You could try autoconverging in digital or even manualy converging
Jul 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 HDTV Projection Television Logo
65 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
