Question about VOX Da5 5w Battery Powered Digital Amplifier
Hello i have a vox DA5. i was carrying it artound in a back back. i sat down to play it in a subway and when i turned it on the red light came on and then decayed and died. batteries had just been charged so it shouldhave been fine. i came back to the apartment and plugged it in and nothing happened then either. no light no nothing. any ideas? both battery and ac adapter dont work and they both worked the other day
2 Suggested Answers
  • 5603 Answers
SOURCE: Hello fixya. So I have placed
This might be the schematic for your unit:
http://elektrotanya.com/vox_ad15-30vt_sch.pdf/download.html
Scroll down to the link "Get Manual" to download the PDF file.
I don't see any connection on a pot that could be touched to cause the problem. OFTEN when screws are too long and they touch a board they can crack the circuit traces or PUSH etch to cause a short.
Use a BRIGHT LED flashlight to "candle" the board for cracks or scrapes. The voltage regulators are current limited and self protecting. The first thing is to determine what the screw touched and look for damage in that area.
I hope you replaced the pots with the CORRECT TAPER as well as resistance value. Whille incorrect taper would not inhibit operation, it would make adjusting the pots in use somewhat difficult.
Posted on Apr 15, 2011
I have a vox vt40 and the light for the power comes on bit there is no sound. I talked to someone with the same amp and they said there is a clip that switches on the tube that tends to go out with this...
If your amp isn't producing signal, your best bet is to take it into a local Vox autorized repair shop. There are leathel voltages involved and if you're not an experienced tech, you can get hurt, not to mention screwing to amp up worse. Here's a link to the Vox contact page http://www.voxamps.com/contactus
And one to find the list of Vox repair shops.
Korg USA Musical Instruments
Feb 11, 2015 | VOX Music
Why won't my clavinova clp 150 play?
Hi, Could be a lot of different things.
Does it play through headphones?
If so this implies an amplifier issue.
Does it play when you press the demo button - if so it could be a keyboard issue.
Carry out a factory reset by holding down highest note whilst turning on. Watch screen does it report anything?
Let me know what it says and I will try and help.
Jun 21, 2014 | Yamaha Music
Vox vt40 factory reset
Consider reading the Manual for this amp, it explains how to reset to factory with the VFS5 footpedal. Or with the power off ..hold down CH1 & CH4 then turn power on.. when the Bank & Channel leds start blinking.. then release the Channel buttons. Next press the Tap switch ... the bank & channel leds will change from blinking to lit. with in a few seconds it will enter preset mode.
Apr 12, 2014 | VOX Amplification Vox VT40+ Valvetronix...
My da5 does not work on battery power
Not to suggest you are an amateur; I'm sure you are not. Nor do I suggest that I am, but if the amp works fine on AC, then the problem must lie in either the polarity of the C-cell batteries (put in wrong) or the contact points are dirty. That's all I got, Jack. . .
JB
Sep 16, 2013 | VOX Da5 5w Battery Powered Digital...
No funciona al amplificador de potencia, si el resto
Could you please translate into our site language. Thanks
Dec 26, 2011 | VOX DA5 Digital Modeling Portable Electric...
Vox vt120+ cutting out and then coming back on. even when the jack lead is not in the jack input. the fuses all seem ok.
i live in mexico and musics stores here sucks I'm an engineer and y started experimenting i think its an IC the TAS5615 im about to order it but does anyone know for sure what it could be??
Sep 28, 2011 | VOX Amplification Vox VT20+ Valvetronix...
Hello fixya. So I have placed new pots on a Vox VT30. Tested it and it worked fine. My son was playing while I replaced the back panel. A screw was too long and touched one of the pots. It shorted out...
Apr 14, 2011 | VOX Amplification Vox VT30 Valvetronix...
My guitar amp has power(Lights up),but no sound.Fuse was good,the one right by the power plug in.No blown capacitors or resistors.100 att vox 2 by 12''
Here is a link to Vox:http://www.voxamps.com/support/circuits/ Start by checking the wiring to the speakers and the speakers themselves.
Jul 19, 2010 | Music
No sound
You would NOT use a stereo cable to plug in your guitar.
The stereo cable would carry the battery voltage back to the amp and MAYBE cause the fuse to blow.
You use a MONO instrument cable for your guitar.
The ring connection is use to complete the circuit to turn on the battery in most guitars.
Replace the fuse ONCE and get the proper instrument cable (NOT consumer audio cable) for your guitar.
If fuse blows again, take amp to shop for service.
May 30, 2010 | Peavey Valveking Head
VOX Da5 5w Battery Powered Digital Amplifier Logo
194 people viewed this question
Top VOX Music Experts
rhodesworks
Tom Chichester
Are you a VOX Music Expert? Answer questions, earn points and help others
