Question about Canon PIXMA MP150 All-In-One InkJet Printer
My problem is : Waste ink absorber of my Cannon Pixma MP150 is full, how to clear this / overcome this problem so i can continue with my printing job. Thank you.
  • Canon Master
  • 5,186 Answers
The waste ink absorber is two sets of pads that absorb ink during cleaning cycles and such. The counter that indicates that the absorber is full is set for a value that should be reached near the end of life of the printer. Additional failures may occur soon. If the printer is under warranty, get Canon to do the job.
If you wish to proceed with cleaning the waste ink pads:
This procedure will be messy. Have plenty of newspaper to absorb the excess ink. One group of pads is under the resting position of the cartridges (where they go when the unit is not in use). with the printer off and unplugged, move the cartridge carrier out of the way and pull out the pads. Blot off the excess ink and blot the spot where the pads sit. Run the pads under running water until the water runs clear. The other is at the very bottom of the printer. You need to disassemble the printer from the top to reach these pads. There are several screws to remove. (Some suggest taking pictures to aid in reassembling the printer.) Repeat the blot and clean procedure for these pads at the bottom. Dry all of the pads (you can use a blow dryer to speed the process). Put the pads back into the printer and reassemble it.
Next reset the waste ink counter (do not do this step without cleaning the pads or ink will eventually get everywhere):
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button 4 times.
Some have better luck if they hold the power button throughout the sequence. Press and hold Power while holding the Stop/Reset button. When the Power LED is lit, press Stop/Reset twice. Wait a few seconds then press Stop/Reset 4 times. Release both buttons. Then press the power button to turn off the printer (expect a slow response). Turn the printer back on and the error should have cleared.
I hope this helps.
Posted on Apr 09, 2011
I have a cannon pixma mp160 printer and i am repeatedly getting error 2 on the led display after replacing the cartridges. i have already tried reloading paper
ERROR CODE CANNON MP150/MP160
E2 2 No paper (ASF)
E3 3 Paper jam
E4 - No ink
E5 5 The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «??&raquo
E9 - The connected digital camera / video camera does not support Camera Direct Printing
E14 - The Ink cartridges whose destination are wrong
E15 15 Ink cartridge is not installed
E16 - Ink remaining is unknown
E19 - Failed to scan head alignment sheet
Feb 01, 2011 | Computers & Internet
Printer won't print. Says to contact service
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 10, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Ink well transformer full
Dec 02, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
ERROR E 2 comes up on the little lcd screen when i try to print now.
www.fixyourownprinter.com
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «ОК»)
E15 - Ink cartridge is not installed
E22 - Carriage error
E23 - Paper feed error
E24 - Purge unit error
E25 - ASF(cam) sensor error
E26 - Internal temperature rise error
E27 - Waste ink absorber full or platen waste ink absorber full
E28 - Ink cartridge temperature rise error -
E29 - EEPROM error
E33 - Paper feed position error
E35 - USB Host VBUD over current error - USB
E37 - Abnormal motor driver error
E40 - Other hardware error
E42 - Scanner error
Oct 26, 2009 | Canon PIXMA MP160 All-In-One Printer
Error 8
Dear sir your problem is or E8 mean
Aug 13, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Waste ink absorber is full, waste ink full, waste ink absorber, a
may the error code or how many blinking can solve your problem
this is the list of error code
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber
full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
try this methode
Methode 1
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED
lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
Jan 02, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma Mp150 keeps having E2 flash
Clear the EEPROM:
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E8 Waste ink absorber full, or platen waste ink absorber full
Direct Printing
E22 Carriage error
E29 EEPROM error
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
button pressing
procedures below.
procedures below.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 20, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Wastw ink absorber is full
On step 4, hit the stop/reset button 4 times to clear the waste ink error.
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
button pressing
procedures below.
procedures below.
Thanks, Joe
Dec 11, 2008 | Canon PIXMA MP150 All-In-One InkJet...
The waste ink absorber is almost full
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
button pressing
procedures below.
procedures below.
Thanks, Joe
Dec 04, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Printer says ''waste Ink absorber is full'' see service center
This is what the manual says: Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. Press [OK] to cancel the error so that you can continue printing. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
Canon recommends to contact a Canon service representative as soon as possible.
Nov 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
78 people viewed this question
old marine
old marine
