Question about Ruud Heating & Cooling
I am repairing a RUUD Model # UGDG 050AUER serial# CB5D302F349 25638035 Honeywell CB fried. ST9101A1014 and F012742 Is this board obsolete? I guess I can replace with a universal Honeywell CB. Thanks, Curtis CR91909 Ga. chart41@bellsouth.net
5 Suggested Answers
shastalaker7
  • 1515 Answers
SOURCE: TROUBLE REPLACING OEM TIMER - UNIVERSAL ELECTRONIC FAN TIMER
Hi, you should be real close with the universal timer and the factory OEM. On the new control board, if you have 24 volts to the board, you should have 24 volts from R to ground or to Common. I know that on most all control boards the voltage in is 120volts as you will have terminals for L-1 and L-2 to run the high voltage controls from the board and all of the thermostat control terminals in a row, R,G,Y, W, C, and so on are 24 volts. 120 volts is stepped down to 24volts control and you say you have nothing out. Make sure you have 120volts in. You are calling this a timer board, is this a heat-pump defrost board with the 3 settings and pin to defrost the unit at 30,60,and 90 minute times? This is what it sounds like. If all was terminated per diagram, you would have the 24 volts required to fire this unit. These defrost timer boards require high voltage to them as well. Even though the board is a new board and you know for a fact that it is wired properly, it may be a defective board. I have seen this many times in my years as a tech. I have shorted new boards out by static electricity and by mis- wiring one. You can kill power and look at the back side of the board to see if this has happened. Sometimes you will find that they missed a solder point on the back side not completing a circuit through the board. To give you more ideas, I would need to see the diagram, or if you could send me the model, serial, and name of your unit. The board number would help also. Check out what I have said and get back to me on this. I will wait to hear.
Shastalaker7
Posted on Jun 06, 2010
wise_jf
  • 66 Answers
SOURCE: Ruud model # UGDG-10NBRJR does this unit have a
Generally speaking there is no pump to pump out the water. There are exceptions if the unit must drain through the attic for example. However these pumps are accessories that sit outside the unit. I would suspect a blocked drain first of all.
Posted on Jul 14, 2010
jyackle5
  • 8197 Answers
SOURCE: I'm trying to install a
May I ask if you still need help or did you get it fixed.
Posted on Nov 29, 2010
  • 1033 Answers
SOURCE: How can I tell if my IFC board is bad or my thermostat is not working properly on a Rheem furnace model UGDG-12EARJR
Hello, just jump the R and w wires on your thermostat subbase, if the unit comes on then the thermostat is bad, if not most likely the board.
Posted on Nov 14, 2011
Furnace blowing cold air
Try pulling the rubber hose off the inducer power vent motor housing and pressure switch. Make sure the barbed fittings are clear of debri (with a small allen wrench) and the hose is clear. Re-attach & run test.
A limit might also be open...check the flame rollout limit center manual reset & press in.
Dec 12, 2013 | Heating & Cooling
My Ruud Silhouette gas furnace ugdg 07 model blower stays on. The heat and air both work but it is pricing my energy bill higher. Whats the cause and can I just turn off the power to the unit (what about...
Problem could be the thermostat setting in "fan on" mode. Thermostat could be shorted between Y,R and G. Fan relay points soldered together or main board shorted.
Nov 03, 2013 | Ruud Gas Furnace - Excellent Condition -...
Ruud model # UGDG-10NBRJR does this unit have a pump for the water condensation to force it out. Unit leaks out the bottom. Or is the line blocked.
Jul 13, 2010 | Heating & Cooling
Blower will not stop RHUD HEATER model # ugdg
If you are referring to the room air blower, it is telling you that there is an error code blinking on the control board. Look for a small viewing port in the lower panel where you can see a flashing LED. Count the number of blinks and find your wiring diagram that is pasted on one of the panels. On that diagram there should be a diagnostic code chart. It may help you to find the cause of the issue.
Jan 23, 2010 | Heating & Cooling
Refrigerator honeywell model number 88031 melted circuit board! Where to get parts?
any refrigeration supply company could order that part for you just give him model and serial numbers of the refrigerator and number on the board and they can help you
May 13, 2009 | Honeywell HE365 Humidifier
I'm COLD!
Any will work provided you have it is a Heat Pump thermostat. I recommend honeywell or totaline.
Dec 05, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
107 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
