Question about Fisher and Paykel Fisher & Paykel Washer
I have a Fisher & Paykel 6.5 Excellence, my garage door had a mishap and the wiring blew and is now all melted, have found that my washing machine now does not go whch is more than likely due to the power sparking re the door - is there ia trip switch on the washing machine that I can reset. Thanks
    Problem Solver:
  • 15 Answers
I am sorry to say there is no reset switch if u are geting power to the unit and the display is not coming on then u have a bad control board located in the front panel.
Posted on Apr 09, 2011
Hi where can I get a instruction manual for my washing machine
go google and type in -- owners manual for ( make and mode ) fisher and paykel washing machine
if it is available there will be a pdf version down load
Oct 26, 2015 | Fisher and Paykel Washing Machines
My fisher & paykel 7.5kg excellence smart drive stopped in spin and now has the 1st 4th and 8th lights on beeping
it is either the control board or the motor wiring, it will need further investigating to determine which of these it is
Oct 09, 2014 | Fisher and Paykel Washing Machines
Fisher & Paykel gw711 excellence keeps filling and overflowing
the clear pressure tube is blocked,
you need to blow air down the clear pressure tube hose.
Jan 30, 2013 | Fisher and Paykel GWL11 Top Load Washer
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
I have the fisher & paykal excellence 6-5 smart drive model gw609au when i first turn it on the seconds green light is flashing and it is trying to fill up but starts and stops all the time then just...
Hi Damian just read your posting.Your fault on your machine is the out of balance switch is faulty.Do you still require help?Please reply and I can guide you throe the repair of this problem.
Jul 02, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher & paykel GW 703-U water flow and the engine sounded choked
sounds like out of balance switch is faulty. does the water start stop start stop then machine beeps. if it does it is most likely out of balance switch.please reply 4 more help
Mar 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
F&P Smartdrive9, excellence 6.5Lt motor restriction
Tipped the washing machine over to tip out the washing and water, gave the thing a shake, hit some parts with a soft faced hammer adn she worked!
I think that process dislodged a blockage in the water pump...
Jul 18, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Mar 12, 2008 | Washing Machines
Washing Machines Logo
109 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
