I have a vizio vw32l40a tv and cannot set closed captions. What do I do??
    Top Expert:
  • Televison & ... Master
  • 75,599 Answers
Hello
When selecting Closed Caption as a feature to be used; Closed Caption On Mute will provide you with
the option to obtain closed captioning when you press the key labeled mute on your Remote Control.
Press "Programme Down" button as many times as it takes to get this option highlighted.
Press either[=> /
Press the LAST key once to return to the previous screen or repeatedly to return to your program if task
has been completed.
Ok
Posted on Apr 09, 2011
Closed caption doesn't work on my Vizio E-55-E1. When I press the CC button on the remote nothing happens
Is this in the settings section of the TV menu? There are different types of closed captions example: CC1 CC2... there has been a few times I've had to change it up because one of the ones selected was not working. Hope this helps.
Oct 02, 2017 | Vizio Televison & Video
Can I turn the caption mode off with the remote?
CC (Closed Caption)
To select the options in the CC sub-menu, press the MENU button or the #
button. A new menu will be displayed showing the following CC settings:
CC
The CC feature is available when watching regular analog (NTSC) TV.
Select from CC1, CC2, CC3 or CC4. Closed Caption for regular TV is
usually CC1 or CC2.
Digital CC Style
The Digital CC Style feature is available when watching digital TV.
Select either As Broadcaster or Custom. If Custom is selected then
you can customize the way Closed Caption is displayed.
Feb 14, 2015 | Vizio VF550M 55 in. LCD HDTV
My closed captions all channel is displayed on my vizio tv. I can't get it to go off. I use verizon fios my box doesn't have a menu button on it. Any other suggestions?
Closed captioning is selected during initial set up of your Vizio TV. If you return to that procedure, you can turn off closed captioning.
Dec 07, 2014 | Vizio Televison & Video
Netflix closed captioning
cant find the closed captioned for Netflix on tv not on computer.
for on the computer, it has C.C on TV
Jan 03, 2014 | Vizio Vbr334 3d Blu-ray Player With Wifi,...
Subtitle choice grayed out on vizio e390i-a1
You are confusing subtitles with closed captioning (CC).
May 13, 2017 | Vizio E390i-A1
How to closed caption on mute vizio
Hello -
The remote control for your Vizio TV probably has a Closed Caption button. Is there a button with CC printed on it? If so, that is most likely the button to press for Closed Captioning.
Dec 23, 2017 | Vizio 42 in. LCD TV
My Vizio VA19L 19'' LCD Television's closed captioning isn't working. The closed caption isn't on the settings menu either. How can I get closed captioning on?
Just press the CC button on the remote. Some TV stations may not send out CC data. Pressing the CC button many times will cycle thru all the options including OFF.
Mar 05, 2011 | Vizio VA19LHDTV10T 19 in. LCD TV
Closed caption
CC (Closed Caption)
Press the down button to highlight the CC (Closed Caption) selection.
Press the > button. A separate menu will appear with the following CC
settings
CC
When watching regular analog (NTSC) TV, the CC feature is available in the
Setup menu.
Press the down button to highlight the CC selection.
Press the > button to select CC1, CC2, CC3 or CC4.
Once the adjustments are completed press the LAST button repeatedly to exit
the OSD completely.
Closed Caption for regular TV is usually CC1 or CC2.
Mar 02, 2010 | Vizio VO42L 42 in. LCD TV
I have a vizio vw32L40a and the screen is too wide. there are only wide and stretch settings, no normal setting. the screen is too wide for the tv.
6/09 I had the same problem when receiving the signal over the air with the input set to TV. Perhaps the signal strength or type was varying. At any rate, after I hooked up HD cable and watch from that input, the problem no longer occurs.
Jun 27, 2009 | V, Inc. Vizio P50HD Plasma Television
Can not get closed captions
Go to Setup using your menu button and navigate to "Setup". That's where the "Closed Caption" settings are manipulated on my Vizio.
Jun 25, 2009 | Vizio VW32L 32 in. LCD HDTV
Televison & Video Logo
147 people viewed this question
Top Televison & Video Experts
