Question about LG Washing Machines
Lg wt-r8571 error codes pe - LG Washing Machines
SOURCE: error code PE on top loader(LG)
Check the pressure switch -the system that determines correct waterlevel in the drum. If its giving an incorrect indication to the programtimer machine will either overfill, refuse to fill or refuse to spin.Its an air operated diaphragm switch triggered by rising air pressureinduced by the entry of water into an airtight vessel attached to thebase of the drum. It tells the program timer that the water has reachedthe correct level, allowing it to proceed to the water heating stage inthe cycle. Power off, drag machine out onto the floor, remove backcover and top cover. The pressure switch is a round item about 3 inchesacross with several wires and a thin rubber pipe attached. It generallysits just under the top cover. Disconnect the thin rubber pipe from theswitch and blow down through it to clear any blockage. Switch itselfmay be faulty but its more likely the pressure pipe or the vesselattached to the other end of the pipe is blocked. Some machines havethe pressure vessel integrated as part of the filter unit, with apressure chamber moulded into the top of the filter body. Remove thepressure vessel, put a small nut or screw in it, fill it with water andshake vigorously till any crud or residue is removed. Refit all parts,check that joints and connections are water tight.
Also check the filter itself - generally located behind a panel at thefoot of the machine.Some are obvious like little square hatches andsome are hidden behind the trim panel at the foot of the machine. Oncepanel is removed the filter should be visible. Its generally a circularplastic fitting which unscrews in an anticlockwise direction. Somehotpoint, indesit and ariston filters are located in the big black sumphose (the one that leaves the bottom of the outer drum and connects tothe pump). Power off, drag machine out onto the floor, remove backcover or tip machine up at an angle. Locate sump hose, remove thetensioner clip by squeezing the tabs together with a large pair ofpliers or vise grips, remove the hose, take out filter and clean. Beprepared for spillage of water. May help if the machine is tiltedbackwards at an angle.
Repair and service your own washing machine. Go to www.2ndwave.co.uk/manual.html
Posted on Jan 13, 2009
BIKER T
  • 909 Answers
SOURCE: i have an lg 8.5kg fuzzy logic that keeps coming
Where about in the program is the problem occuring.
Posted on Sep 14, 2009
  • 668 Answers
SOURCE: lg front loader washer error code -PE
PE error code means there is an pressure sensor error in your machine .
You need to check pressure it will be giving incorrect indication .
Pressure switch is faulty you need to change it .
Procedure for changing it is :
  • Power off the machine remove backcover and top cover.
  • The pressure switch is a round item about 3 inchesacross with several wires and a thin rubber pipe attached.
  • It generallysits just under the top cover.
Hope this helps.
Thanks for using Fixya.
Shane
Posted on Jan 20, 2010
Jahn27
  • 1554 Answers
SOURCE: My LG Turbo-Drum Top washing
The fault code PE indicates a pressure sensor problem. The problem is either the pressure switch is bad, the wire harness connection between the pressure switch and the PCB assembly is bad, or the pressure hose is clogged, blocked, or kinked.
Disconnect power and remove two back panel fixing screws on the back side then pull the back panel up to expose the machine controls including the pressure switch.
Check to make sure the wire harness connection between the pressure switch and the PCB assembly is intact, the connectors are clean and corrosion-free, and the pressure hose is attached correctly to the pressure switch. Inspect the pressure hose for clogs and kinks then blow air forcefully down into the pressure switch.
Remove the rear access panel and continue inspecting the pressure switch down to the bottom of the tub. Make sure the pressure hose is clear, not kinked, and no air leaks.
Replace the pressure switch if there are no issues found with the wire harness connections, connectors and the pressure hose. Simply remove the pressure once accessed as instructed above then stall the new one in place. Connect the wire harness and the pressure hose to the pressure switch then reinstall the back panel back into position to complete the repair.
The pressure switch is part number 6600FA1704L. I believe you are in Australia and you can find and purchase the pressure switch from BigWarehosue. Just click on the links (underlined words) provided and you will be redirected to the site.
Let us know if you need further advice. Please accept the solution should you find it helpful and informative. Accepting the solution will not stop you from communicating with the expert. You can still communicate with the expert as long as you need further assistance regarding the issue stated herein.
Posted on Feb 06, 2011
  • 6277 Answers
SOURCE: LG 3 STEP TURBO WASH
'PE' for LG's decodes as 'sensing water pressure error'/'pressure switch fault'. which is not that helpful- inlet or outlet water pressure! I would try this first as I suspect it is talking about outlet/drain water.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 24, 2011
Error Code PE
go to the manufactures website and download the user manual and check in trouble shooting guide eric
Jan 19, 2018 | LG Washing Machines
Lg wf-t1022tp gives a PE error code.
Try this first before replacing any parts or disassembling your LG washer:
- Unplug the washing machine for 1 minute.
- Plug the washing machine back into power.
- Restart the wash cycle.
- The washing machine may now have cleared the PE error code, if not see below...
You will need to check the wiring harness that connects the water level pressure sensor to the main control board.
- Check for a loose wire harness, a damaged wire harness, or a burnt faulty wire.
- Check that you get continuity through the wire harness by checking it with a multimeter.
- If the wire harness from the water level pressure sensor to the main control board is found to be faulty, replace it.
- If you get continuity and the wiring harness is securely connected to both the water level pressure sensor and the main control board, then proceed to the step below...
LG WASHER PE ERROR CODE - FIX METHOD #2
Water Level Pressure Sensor Switch Is Faulty And Needs To Be Cleaned Or Removed And Replaced.
Most commonly, if the wire harness is secure, tight, and not damaged, the part that needs to be checked is the water level pressure sensor.
- First check to be sure the water level pressure sensor is not caked with hard water or other debris.
- If the water level pressure sensor is not clean, the PE error can display.
- Remove the water level pressure sensor from your LG washer and clean off any hard water or debris.
- Clean out the tube that connects to the
- If you found the water level pressure sensor was caked with debris and you have cleaned it, replace it back into the washer and run a test.
- If the washer runs without the PE error code displaying, the washer is fixed and the PE error has been cleared.
- If you find that the water level pressure sensor is faulty, remove it and replace with a new OEM part.
lg-electronics-washing-machine-water-level-sensor-pressure-switch-hth0u4ums0hor52ud1sodlv4-2-1.jpg
Replacing the water level pressure sensor simply involves locating the sensor in your LG washer. Remove it from the washer and replace it with a new genuine LG washer part. Test washer to be sure the PE error code has cleared and the washer is now working properly
Mar 20, 2017 | LG Washing Machines
I have an lg front loading an it showing pe signal
the PE error code is a power error code normally happens when there is a power failure you can turn the washer off then back on (not unplugging it) and this will clear the error code however if it happens with out any other reason then there maybe a power problem inside the diagnostic computer in the washing machine
Aug 05, 2016 | LG Washing Machines
Washing machine LG TR9103AEP IE error what does it mean ?
LG Top Load Washer-Understanding Error Codes - YouTube
? 2:17
www.youtube.com/watch?v=ZdoJVqFKye4
Sep 17, 2013 - Uploaded by ExperienceLG I have LG Washing machine and I tried to start it and came up with PE Error code and I ... I Can see IE OE and other error codes But Not PE.
Aug 04, 2015 | LG Washing Machines
What dose PE MEAN
The PE error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
Aug 08, 2014 | LG Washing Machines
"PE errors lg washer wm2032hw" I replaced the
Check the condition of the tube as any small crack or hole will render the pressure switch useless.
If in doubt replace the tube.
Sep 03, 2013 | LG WM-2032H Front Load Washer
I have a LG WD-1018C that won't work and has PE on the screen and I can't find the manual to fix it. Can you please tell me what PE means. Thanks
The error code "PE" stands for pressure sensor error. This is typically caused by a malfunctioning water pressure sensor switch.
Mar 09, 2011 | LG Washing Machines
Error code PE on lg washer
pressure sensor switch error; either dissconnected or replace.
Mar 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
141 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
