Question about Vacuums
Can I wash the filtering part of my dysart to get all the dirt out? thanks Diane
  • dianeyah Aug 06, 2008
    very helpful.
    thanks
  • 33 Answers
Yes u can just make sure it drys totally before reinstalling in vac
Posted on Aug 06, 2008
  • Anonymous Aug 30, 2008
    but do replace it like every 6 mo your lungs will thank you they lose some of there filtering ability if you wash them too much
SOURCE:
How do you empty it?
http://www.homedepot.com/catalog/pdfimages/e1/e1548aa7-3a91-42bc-b2c0-1b405ef54686.pdf
This owners manual shows you how to empty. If you dont have access to Internet:
1. Depress the dirt cup release button and pull nozzle away from unit.
2. Hold nozzle over a wastebasket, Grasp filter and gently pull out.
3. Shake excess dirt and debris out of dirt cup. Brush the dust and dirt off the filter or shake inside the wastebasket. IMPORTANT do not wash filter.
4. Gently push the filter back into the dirt cup.
5. To reattach dirt cup: Align bottom first and rotate nozzle up until it snaps into place.
Good luck.
Apr 20, 2016 | Dirt Devil Red Versa Power Stick Vac
If the filter is clogged would it quit working
Hi there! If the filter is clogged this will cause the vacuum to lose suction and possibly shut-off. Below are instructions to checking and cleaning your filters.
1. Remove the dirt cup. Twist off the dirt cup lid.
2. Remove the filter cartridge from dirt cup.
3. Separate the foam and cartridge filters. Wash foam filter under running. Allow 24 hours to air dry outside the vacuum.
4. Tap the excess dirt out of Hepa filter. Hepa filter may also be washed. Allow 24 hours to air dry.
5. Check the secondary filter by removing the filter cover from base. Rinse the foam filter under running water until it runs clear. Allow 24 hours to air dry.
6. The red baffle tube inside of the dirt cup is apart of the filtration of the vacuum and needs to be cleaned as well. Twist out the baffle tube by turning 1/4 turn clockwise. Remove any hair or debris wrapped around baffle tube. Baffle tube can be rinsed if needed. Allow to dry thoroughly.
If the filters are too dirty they may need to be replaced. With regular maintenance the filters should be replaced about once a year. Follow the links below to order replacement filters for your UH20020.
Primary Filter
Exhaust Foam Filter
Hope this helps!
Jun 12, 2014 | Hoover Nano Cyclonic Compact Bagless...
Why does my dirt devil swerve get really hot?
Hello! Sounds like your vacuum may be overheating. This is usually caused by either a clog or a filter that needs to be cleaned. Please try the steps below to get your vacuum back up and running.
1. Remove the hose from both ends by pressing the release buttons.
2. Use a broom stick or something similar to gently loosen and remove any clogs from the hose.
3. Remove the nozzle from the cleaner by pressing the release button and pulling the nozzle from the body.
4. Use a wooden spoon or something similar to loosen up and remove any clogs from the nozzle or the lower tube.
5. Remove the dirt cup. Lift open the lid to the dirt cup.
6. Remove the filter from dirt cup. Remove the filter frame from dirt cup. Hold filter under running water to rinse. Allow 24 hours to air dry before replacing.
7. Check the exhaust filter by twisting off the filter cover.
8. If dirty, the exhaust filter can be washed as well. Hold filter under running water to rinse. Allow 24 hours to air dry.
This should stop the vacuum from overheating. If not please reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil. Thanks!
May 27, 2014 | Dirt Devil Swerve Upright Vacuum
How to empty it
1. Push down on carry handle and
pull dirt container away from unit.
2. Once it is pulled back lift it out.
3. Hold dirt container over trash can and push down on bottom
release lever to release debris.
4. Close bottom cover on the dirt
cup until it snaps shut.
While you have the dirt container out you can also clean the Lifetime HEPA filter. It is on the top of the dirt container.
1. Twist lid to the left to remove lid and filter from
container
2. Remove foam filter from dirt container and dump out
any loose dirt. Wash the foam filter.
3. Remove the HEPA filter by Twist filter handle to the left and
pull out of lid. Wash the Heap filter.
4. Once the filters are thoroughly dry (I recommend set out for 24 hours) then installer filters in lid and thread back on top of the dirt canister.
Before replacing the dirt canister you can also clean the exhaust filter install below the dirt canister on the top vacuum cleaner head.
1. Loosen the exhaust grille by pressing the locking tab, and
remove it.
2. Remove and shake out the exhaust filter and wash it.
Note: Scented filter are not washable.
3. Once the filters are thoroughly dry relace it and snap the
exhaust grill into place.
Replace the dirt container
NOTE: Dirt container will not
align on base if filter is not
aligned properly.
May 15, 2014 | VAX Appliances Vacuums
Bissell powertrak revolution dirt not going into cup
If the unit is not blocked between pickup and filter have a good look at the filter to see if air is passing through it---paper throwaway or foam filter the can be washed?
The ones that can be washed etc will have instructions right on them.
Nov 02, 2012 | Bissell 6591 Power Trak Revolution Bagless...
Can I clean the air filters or have to replace them and if so how often? I would also like to know where I can purchase new filters if necessary. Thank you!
Hi Thank you for contacting FixYa. We love to fix things.
You havent mentioned what make of Vacuum you are using.
Assuming this is a Dyson then yes you can wash the filters, let them dry then re-use them. You can wash the sponge type filters using fairly liquid and running under the tap and squeezing out the dirt just like you would with a normal sponge.
The Hepa Filters can be cleaned using a power washer or by placing them in a pillow case and puting them in the washing machine on a low heat low cycle. Ideally you should not need to replace the Hepa filters but i would recommend you do so after 1 year.
Oct 26, 2010 | Vacuums
Dirt and hairs not going into cylinder
It's not the filter that's the problem.  Air should go first to the cyclones, then to the filter, so the filter catches only those finest dust particles that are not trapped in the cyclones.  The most likely cause of the problem is that the cyclone pack is not properly seated, with the result that at least some of the dirt-bearing air is going directly to the filter rather than passing through the cyclones first.
Apr 18, 2009 | Dyson DC11 All Floors Bagless Canister...
HOW DO YOU WASH THE JC0280-000 FILTER SAFELY? IT'S FROM A BAGLESS VACUUM. THANKS
The easiest way to wash this is to put it in lukewarm / to the touch warm tap water in a basin and drop in some washing up liquid/dish liquid as this is one of the more gentler cleaning agents you can use. Leave it for a few hours without doing anything. Rather than use a brush which can tear the paper pleats/folds, inspect the filter to see if it has been rid of dust then use your fingers to gently widen the pleats to ensure all the dirt is gone.
Sadly for this type of filter it is near impossible to get it looking white again. However in lieu of letting it room dry for 24 hours (sometimes the JC0208-000 can take up to three days until it is bone dry)
Slip the filter into a pillow case and put into an electric tumble dryer. Select a low heat and check every 30 mins to see if the filter has dried.
Dont forget to rate this, thanks.
Jul 30, 2008 | Dirt Devil Vacuums
HEPA Filter
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618630&thid=730623
HEPA Filter
Posted by jenski66 on Jul 02, 2008
My vacuum came with a sponge over the filter and the directions said I could wash the filter. Do the directions mean to wash the black sponge or the actual filter? Is the sponge part of the filter or is it trash?
Filter F27
Dirt Devil Purpose Cleaner for Pets
Upright Bagless Vacuum
Model #1LY2108-000
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Typically the top filter of which is the sponge is washable but the HEPA filter is not, it can be brushed off and vacuum off with another vacuum, but the best filtration is to replace the HEPA filter and to wash the sponge filter, if the sponge filter get to bad then replace the sponge filter as well. Or, you can check with your local vacuum cleaner dealer in your area or to contact the manufacturer’s website and or phone #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 02, 2008 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
