Question about Kenmore Dryers
Dryer power is on. When I set the cylce and push start nothing happens. Already checked the belt and it is fine.
    Problem Solver:
  • 11 Answers
Have you check go see it you are getting a full 220v to the dryer, assuming it's electric. If there's only one leg of the power the control power would come on, but nothing else would work.
Posted on Apr 09, 2011
Dryer not running, just getting a click.
check you drum belt. if belt is broken nothing will come on.
Feb 25, 2014 | Amana NED7200TW Electric Dryer
Power is on but nothing is happening when i push start. the dial wont let me change the time/dry setting. everything is lit up just nothing happening.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 17, 2010 | Samsung DV218AEW Electric Dryer
When I push start nothing happens First it was
The symtom your describing is that of a worn or loose belt. There is a belt safety switch on the motor mount that is actuated by the travel of the idler arm. If the belt is worn stretched or broken the dryer will not start because the belt safety switch has actuated.
This is a matter of changing the dryer belt. In the process of the belt change check the drum felts front and rear for excessive wear, Worn drum felts / seals can losen the belt so the idler travels to tighten the loose belt and can cause the belt safety switch to be activated. .
BEFORE you go directly to the belt as the problem check the door switch. You should hear and audible CLICK as the door just opens or closes. No CLICK = no start. I.e bad door switch.
There are a few other possibilities but these are the 2 most common. If none of the above is related to your dryer or you need more assistance please respond with your dryers' make and model number.
Thanks for choosing FixYa.
Kelly
Sep 15, 2010 | Whirlpool LER4634J Electric Dryer
I have everything set properly. When I push the knob to start the cylce nothing happens. I have a magic chef Model #YE20JN5 I have cleaned the lint trap. I have made sure my door is closed properly.
first thing to check is if the belt broke, as the safety switch would shut every thing down. you can check by removing bottom front cover , or if it doesnt, place machine on its side and look under
Oct 07, 2009 | Magic Chef CYE4000AWW Electric Dryer
Hum but wont start
The slight hum you are hearing is the start windings in the motor. This is a common problem in the kenmore dryers and there is nothing you could have done to keep it from happening. the part number on the motor is 279827 and price from sears is $105.99.
Oct 03, 2009 | Kenmore Dryers
Whirlpool dryer has power, but drum won't spin
More likely does have a belt. Get me the model number and I will see if I can help you on this problem, Thanks, Sea Breeze
Mar 21, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer will not cycle
Replace the belt and all will work fine. The belt spins the drum
Feb 09, 2009 | KitchenAid KEYS700LQ Electric Dryer
Kenmore electric dryer won't start
The first thing I would check would be the door switch. Dryers operate on 220 volts. Many brands split the 220v into 110v for controls and motor and 110v to the heater. There are also safety systems on many brands that won't allow the heater to come on if the fan motor is not running and blowing air throught he element to prevent overheating and dryer fires. If the door switch is ok, check the belt. If the belt is ok, it could be a problem with the motor start switch. The motor start swith is complicated fix and should be done by a professional. ALWAYS BE SURE TO DICONNECT THE POWER BEFORE ATTEMPTING ANY REPAIRS.
Mar 24, 2008 | Estate TEDX640JQ Electric Dryer
Dryers Logo
49 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
