Question about Dryers
Took my dryer apart to change the heating coil. Some wires came loose on the back now my dryer wont turn on? Can you email me the wiring diagram? Thanks so much!
  • 415 Answers
Remove the back panel to the controls panel and your wiring diag will be there.
Posted on Apr 09, 2011
Amana dryer wont heat
without Model number, generically speaking, if no voltage to the heaters, keep back tracking the circuit till you find where you are loosing it. Check the basics such as a loose or burnt wire in the circuit. Does power pass thru the timer? Study the wiring diagram and follow the circuit. Supply more info and I will try to find wiring diagram for your unit.
Sep 23, 2017 | Amana Dryers
Heat cuts out shortly after dryer starts. Have taken apart several times. First replaced thermal cut off (tested bad) and thermostat. Element ok. Good airflow. Dryer seems to heat up very quickly and very...
Sure can!
Most Kenmore style dryers have a heating element that has a long wire coil inside it, (often there are two wires or elements inside one housing). Regardless, if you have carefully checked the air exhaust, and you find it is "perfect" ( means no back-up heat from a plugged or impeded air flow) and you have determined the air flow inside the machine is like new, ( no back up there either), then what has possible happened is the wire heating element has wiggled loose and is touching itself, thereby shorting out and making super heat.
The wire coils are usually held loosely in place with white ceramic rings, to keep them from touching the metal housing. If you carefully remove the heating element "box or "tube" and look inside , you may be able to see the problem. Testing it with an ohm meter will not work, it will simply test OK. The element is made to heat at a certain temperature according to it's length, if it touches itself, the elecrttricity will take the shortest route and may make your element glow white hot in one spot. Be blessed.
Sep 02, 2013 | Kenmore Series 70 80 90 PN281798 Dryer...
My wife started the dryer the other night and 15 min into the cycle we could smell something burning.we discovered that the electrical outlet got so hot that the dryer plug and wall outlet were melting.i...
The problem was not in the dryer, but it was a loose wire in the plug or the outlet...I have seen this happen many times.. the wire gets loose and then because of the poor connection it heats up and starts a fire...
Replace the outlet AND the plug!!
The dryer pulls a lot of current but it is not the problem...
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
Aug 23, 2010 | Hotpoint NVLR333EE Dryer
Gas will not turn on to heat dryer...igniter is ok...tested that...got new solinoids for gas valve seems to be back to timer but do not know for sure took that apart and points seem to be ok no hot spots...
Sometimes the heat sensor/ igniter gets carboned up and needs to be lightly sanded or cleaned for it to sense heat. That could prevent the main gas valve from opening and staying open. Also, does your unit have a heat limit switch or thermal switch that could be faulty? Check the wiring diagram.
Jun 12, 2010 | Whirlpool LEN2000PW Dryer
I took the wires of the thermostat and heating coil and cannot remember how they go back on. I need a wiring diagram to put them back on properly
if you look at the connectors the wires that connect to the heater are larger and the wire is thicker,it doesn't matter what wire goes where on them,also the heater wires should be red and the other is red with a white stripe and like i said it doesn't matter what post on the heating element the wire with the stripe or the solid red wire connects to.the same with the thermostat
May 31, 2010 | Dryers
Timer
I have seen a similar question before. Look up the wire schematics and see what that wire is for. The sire schematics usually come with the dryer.
Apr 27, 2010 | Roper REX4634KQ Electric Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
My whirl pool dryer does not dry?
coil never gets power usually a sign that you have a blown thermal fuse , small white 2in' fuse located behind rear panel, there should be a wire diagram behind the console, few screws acrosss the back
Oct 30, 2008 | Dryers
Dryer tripping electrics out
try gaining access to look at the heating coil. Many times, a coil will either bend over time from repeated heat/cool cycles or simply break and one part of the coil may be touching the metal dryer chassis. I have repaired these by either replacing the coil or repairing (if broken coil wire) it by taking the broken ends and twisting them back together. Make sure no part of it touches metal. Also inspect for breakage the insulators that hold the coil.
Aug 09, 2007 | Tricity Bendix TM310W Electric Dryer
Dryers Logo
43 people viewed this question
Top Dryers Experts
