Question about Logitech S120 2 Speakers
Speakers seem to crackle sometimes - Logitech S120 2 Speakers
  • Logitech Master
  • 27,725 Answers
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
hope this helps
Posted on Apr 09, 2011
Crackling front speaker
kinda over driving it heh??
Mar 14, 2014 | Peavey PR15 400w PA Speakers
Crackling
So if you bought enclosures that are premade AND had the speakers installed, you need to see if there is a cross over network installed in them
Apr 27, 2013 | Car Audio & Video
I have a Marantz 2275 receiver hooked to some JBL speakers. I noticed one of the speakers crackling. I swithched the speaker wires around and now the other speaker crackles so I'm guessing it is
Doesn't sound like it's a speaker - more likely a fried chip or transistor causing harmonic distortion.
It's usually more cost effective to replace modern audio components than to fix them.
Nov 21, 2017 | Audio Players & Recorders
My logitech s-120 speakers crackle very loudly sometimes. At first I thought it was the sound card in my old PC, but when I switched to a brand new Mac computer the problem continued, making me think the...
hi there,
The problem is actually from the speakers themselves. If it's not a year old you might want to bring it back to the store where you purchased it for a warranty repair or replacement.
Sadly the problem is inside the speaker and it could be a loose connection inside. If you're comfortable enough you can try to open the speakers and check inside for any loose wires which cause unstability of sound or for any loosed fittings from the magnet.
Hope this helps!
May 30, 2011 | Logitech S120 2 Speakers
Crackling sound from speakers, intermittent, but seems to start after warming up
If these speakers are internal to the TV, chances are an internal component is getting noisy -- probably a capacitor -- and will eventually need replacement. That's not something you can do yourself. It's also possible there's a loose connection or a noisy volume control, but that's less likely, and again, would require a qualified serviceman.
If the speakers are external - that is, you've plugged them into the set -- check the connections at the set and at the speaker to make sure they're not corroded and are firmly seated. Sometimes just unplugging and replugging them a couple of times rubs off enough corrosion to solve the problem. Also wiggle the wires close to the connectors on the cables. If that causes the crackle, replace the cables.
Oct 04, 2010 | LG 42PC3D 42 in. Plasma Television
My speakers will start to make a crackling sort of noise then stop. Sometimes the radio will not play at all. Sometimes the speakes make this crackling noise then they stop making the noise and play ok for...
Are your speakers factory? Sometimes the wires start corroding from moistures or from not being covered well. If you can or know someone who can, you may try checking the wires to the speakers/radio. If they are corroding, they may be shorting out.
Jun 30, 2010 | 2005 Kia Amanti
Crackling seems to be coming from central speaker
in mu experience its a problem with voltage of your speaker.
did you tried before touching the speakers hard...
because the magnetic in the central of the speaker may damaged.
Aug 26, 2009 | Dell WL6000 Computer Speakers
I sometimes lose sound from my left speaker and it crackles.
this is a speaker input pin problem, like pin is dameg or input pin is not atech proparly in computer problem is still present remove the cable and install new one cable in speaker
Mar 11, 2009 | Audio Players & Recorders
Sound problems
you have defective speakers! you can repair your speaker change the spider suspension wire! thats why your speaker is crackle sounds!
Oct 01, 2007 | Hitachi 61SWX12B 61" Rear Projection...
Logitech S120 2 Speakers Logo
109 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
