Question about Sanyo Blenders
Ow do you put oven door back on a Mcclary stove. I removed the oven door to fix the handle and it will not go back on the way it came off.
How to remove the blender top
http://www.ninjakitchen.com/manual/NJ600_30_IB_ENG_100226.pdf
on page ten it describes how to remove the lid by lifting the handle and pulling straight up, also shows a diagram.
Nov 10, 2013 | Euro-Pro Ninja NJ600 Pro Blender - NJ600
How to remove the top
are you pushing the handle release button on the lid, swinging the handle straight up and pulling on the handle straight up?
see page ten figure 6: http://www.ninjakitchen.com/manual/NJ600_30_IB_ENG_100527.pdf
Ninja lid removal
your pushing the handle release button on the lid, swinging the handle straight up and pulling on the handle straight up?
Nov 10, 2013 | As Seen On TV Ninja Professional Blender
I took the spout of the smoothie plus 600 apart and can't put it back together
When you say you took the spout apart and can\'t put it back together its only 5 total pieces. The spout, the spring, the handle, the dispenser (rubber insert with plastic stem) and the threaded cap which holds the dispenser and handle to the spout.
If you can\'t get the handle to re attach, that does not surprise me. This is very poor craftsmanship. The plastic nobs that hold the handle onto the dispenser tend to break off.
If this is your problem, you can either, buy a new one for $5 plus shipping depending on where you live OR
You can fix the part that broke.
All you would need is a Drill, a small piece of number 14 copper about an inch long and same size drill bit. Drill the handle as close to center where the plastic molded nobs were located that either broke off or worn away. Then drill with the same size drill the stem to the dispenser which has the rubber stop attached. Drill this as close to the top of the stem where the nobs would snap in to hold the handle in place. You are basically making a pined handle, which will outlast the quality of this blender.
NOTE: You want to use a drill bit about the same size as the number 14 copper wire.
Then with one hand hold the threaded cap with the dispenser placed into position through the hole, be sure to put the spring in, small hole to the bottom of the rubber dispenser, pushing the spring and dispenser up through the threaded cap, attach the handle by putting the piece of copper wire in your hole which will connect your handle to the stem of the stopper. The copper should be cut no wider thent the width of the handle, if it sticks out a tiny bit, that\'s ok. The plastic cap will simply be carved out where the copper rubs against it. After that, simply screw the handle cap back onto the spout and screw the spout back onto the blender making sure the two washers are still on the pitcher.
All in all, for someone who is handy, this should take about 10 minutes. I would rate it about a 5 out of ten for difficulty simply because you have to drill straight and centered in the handle where the nobs were. Other then that its easy and if you can have someone help you put the pin in place, it would also make it easier.
If for some reason the rubber stop does not seem to go back into the spout, make sure the rubber didn\'t role up onto itself. Also if the spout drips, you didn\'t either put the spring back in or you didn\'t drill at the top of the plastic stem but some where in the middle, simply ream the hold towards the top where the plastic nobs would stop. Its a square reseated area in the stem. Looking at it you should be able to tell.
As for the spout instructions, you can download the pdf manual at the manufactures website: http://westbend.com/spl6white-smoothie-maker-plus-600.html
Hope it all helps, Its worked for me!
Dec 31, 2012 | Back to Basics 600 Smoothie Plus Work Top...
Can not remove base from blender model BL5500SC
leave the blender jar on the blender. with one hand grab the glass jar handle with the other hand hold the base of the blender. then twist or push the handle counterclockwise to free it up so you can completely remove it from the blade
May 19, 2012 | Blenders
How do you remove the cuisinart blender handle to clean he glass beneath it?
i have a perfect answer! and own this very modle with the same issue. Plus i have done it myself.
Instructions:
*on the lower part of the hadle you will see two holes, with a small 6" school sized METAL ruler (no thicker than 3/4mm) gently insert it inbetween the two holes and push down. ((The handle has a clamp there) NOTE: you MUST start at the bottom of the handle or you will brake it!
*then while still inserted push the ruler away from the jar. this should releese the clamp that will allow you to remove the outer piece. REMEMBER your handle is plastic.
*now slowly lift upward and the side clamps will release. STOPpulling when you get to the at the top clamp.
*now you want to carefully hold your thumb down with slight pressure on the top of the handle (where you see the ingroved space that connects the hadle piece, it looks just the same as the bottom but without the holes) and lift up the handle slowly. this should release the outter part of the handle.
* now that the outside piece of the handle is off you can see the scews, unscrew with a phillips scewdriver and take handle fully off.
*Lastly the wire-like rings MUST be slipped off towards the bottom. do NOT try to prie off the wire-like ring from the little piece that is holding it together to create the ring, you will snap it.
*after you have taken off the rings, clean them with VIM (with bleach) by placing them FLAT on the sink edge to keep them from changing shape. Scrup away. Also scrub the plastic parts but DO NOT use the VIM on the outside of the plastic handle as it could scrub away the silver paint. only do this on the inside to remove the mold and grime.
NOTE: VIMis the only thing i found that will even remove rust build up. use an old toothbrush to scrub away the rust and grime. preferably dry with the vim, no need for water. water will dilute the VIM and cause it to be uneffective.
* you can take the little nub that conects the rings off by twisting them to the left or right, for cleaning, doesnt matter. I tried both ways but prefer to keep them on.
* now that you washed all parts let them DRY or you will end up with the same rust and grime issue. After the parts have dried you can now reasemble youir handle, and have peace of mind :)
* Try not to overdue the assable and reassambling of your handle, keeping in mind it is made of plastic and plastic wears easliy.
Hope that helps.
Jun 14, 2011 | Cuisinart CBT-500 SmartPower Premier Work...
Kenmore range model 93751 stove door will not come on looked and is showing an f9 err code
microwave has a cracked inverter board and that is why it posts an F-9 code.
Jan 25, 2011 | Kenmore Blenders
My blender base has become discoloured with a sort of green mouldy streaks, how do i clean
If you remove the blinder base where the blades are you can put it all in the dishwasher. To do this grab the handle on the pitcher then unscrew the plastic base from the glass. make sure that you look how it comes apart first. then put in the dishwasher to clean. Then reassemble the way you took apart.
Jan 11, 2011 | Oster 12-Speed Brushed Nickel Blender...
After starting the microwave, I get a "F-7" message on the display and it shuts down. What can I do to fix this? This is a whirlpool model # GH5184XPS-4.
hello,
what this error means indicate is as follow
The F-7 error code indicates that the water or oil (any liquid form) temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
what you need to do to fix up your is to do general cleaning up on your oven both internal and external do this with care and allow it to dry up it self.
please when doing this you will have to put off any form of power supply connected to the oven .
thank you and thanks for using fixya.
Jun 01, 2010 | Blenders
Cuisinart DFP-14 Series does not start
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor plugged in and turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. For the DFP-14, remember: handle faces front, feed tube faces back, and metal element on back of pusher faces back of processor. Connect the pieces separately - if you try to put the work bowl on with the lid and pusher already attached, it will not always lock properly. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Nov 17, 2008 | Blenders
Blenders Logo
154 people viewed this question
Top Sanyo Blenders Experts
eyecam
Are you a Sanyo Blender Expert? Answer questions, earn points and help others
