I can not get the laptop to get into internet by pluging into a cable wire for internet, new will not give me any information on isp I have a sylvania ce 7 with ? windows 6?
  • 96 Answers
What about your connection or connectors wire going to router should be cross over. To run for isp is press accessories then command prompt then type ipconfig
Posted on Apr 09, 2011
Internet conexionlocal only
Wired or Wireless? If Wireless will not connect, First try a test, using a Ethernet cable connect directly to the ISP modem, Does it connect? Yes or No? If yes, move the cable to the Wireless router, Does it connect, Yes or No? If no, Contact ISP. Check ALL cables to the ISP and Wireless device ,reseat cables. It may be the Laptop Wireless or wired adapter, reboot the laptop and the wireless device. I don't have all the info needed to supply a more percise solution. Try a IP release and renew using this procedure : http://helpdeskgeek.com/networking/release-and-renew-an-ip-address/
Jan 29, 2013 | Acer Aspire 7720 Notebook
I cant get internet from my rouder
Wired or wireless? Shut down the computer. Unplug the NetGear. Unplug the ISP modem, remove battery, if applicable, Check ALL cables and connections, reseat ALL connections. plug in the ISP modem, wait for selftest. Plug in the NetGear, wait for selftest. Reboot the computer. Try connecting with a Ethernet cable if you are trying to connect wirelessly to verify. If that fails, contact your ISP to verify signal comming in. Have a ISP tech come out to analyze the signal.
Jan 06, 2013 | NetGear Computers & Internet
What do I do to have my wireless working away from my Internet connection and wireless Router. I have 2 Ethernet cables one going from my router to my Laptop and one going from my Router to my Internet...
Ok. As per your statement your laptop is working perfectly , when you are connected your laptop with with the cable wire.So the network cable is OK. So you have to configured the wireless cable in your laptop when it is connected to your laptop. After connecting the cable wire to your laptop you have to findout the gate way of your ISP ( Internet Service Provider). To find out the gate way , kindly follow the following instructions.
First findout the IP address , subnet mask,and Gateway addresses of your ISP ( InternetService Provider ).To find out the above mentionedaddresses first open the control panel -> network connections -> local area connction -> properties -> Internet Protocol Version 4(TCP/IPV4) OR Internet Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
By the systematic selection as mentioned above you will get the IP address, subnet mask and Gateway addresses. Kindly note the Gate way address of your ISP. Then enter the gateway address in the browser and open the window. Then a control panel / a window will appear. It will prompt you to enter 1). user name, and 2) password. If you are having the user name and passwords provided by your ISP , kindly enter them in the window and click to open. Then the particulars of your ISP will be displayed in the window. Then click the wireless icon and click to enable. Hurray ! your laptop will work perfectly through wireless. If you are not aware of about the 1). User name and 2). password , you must approached to your ISP and try obtain the same for working of your laptop wirelessly. Provided , that you have to configure the wireless enabling for both the ethernet cables and there after save the changes , after finding the 'GATEWAYS' if both the the ISP's seperately.
Oct 03, 2010 | D-Link DI 514 Wireless Router (DI-514)
Having problems connecting my lap top to my wireless cable modem. Its a motorola SBG900 gateway. everything seems to be connected. Im able to use it with a ethernet cable just need help geting it to be...
By the systematic selection as mentioned above you will get the IP address, subnet mask and Gateway addresses. Kindly note the Gate way address of your ISP. Then enter the gateway address in the browser and open the window. Then a control panel / a window will appear. It will prompt you to enter 1). user name, and 2) password. If you are having the user name and passwords provided by your ISP , kindly enter them in the window and click to open. Then the particulars of Motorola SURFboard SBG900 Wireless Router will be displayed in the window. Then click the wireless icon and click to enable. Hurray ! your laptop will work perfectly through wireless. If you are not aware of about the 1). User name and 2). password , you must approached to your ISP and try obtain the same for working of your laptop wirelessly.
Oct 03, 2010 | Arris SURFboard SBG900 Wireless Router...
I pluged the belkin 54g into the modem were the internet comes from and 1 wire to the computer
hello,
typical setup: make sure everything is switched OFF, then, you will plug one side of the wire to the "WAN" port on your belkin and the other side of the same wire will go in the "LAN" port on the cable/DSL modem/device.
then you would take another wire and this time you will plug one side of the wire in the "LAN" port on your belkin router and the other side of the wire into your desktop/laptop computer.
1.first power on the cable/DSL modem, wait 20 - 30 seconds for the modem to go in ready state. 2. power on the belkin and wait another 15- 20 seconds for it to become ready. 3. finally power up your PC and everything should be good to go.
Note: if router is new and came with setup CD run that in the computer and follow instructions.
let me know if there are any issues.
Hope this helps, please vote.
regards,
Amar Sondhi
Dec 05, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Can't connect to internet thru 2wire modem on new computer
check the ipaddress. go to start -> run -> type ipconfig and hit enter. if you have a 169.x.x.x then you have an invalid ipaddress. if you have any other address go to start -> run -> and type ping google.com. if you recieve replies then the problem is browser . if you dont get replies then check your dns and verify with your isp that that is the correct address. if all checks out then call your isp and tell them they need to replace the modem wether is cable or dsl.
Nov 15, 2009 | Dell Computers & Internet
Isp password and name?
Your ISP should give you your username and password, not the router manufacturer. To know how to punch it in your router, please refer to your router user manual.
Mar 27, 2009 | Computers & Internet
Wii wired internet connection problems
if you have all of these
Requirements to Connect the Wii Console Online with a Wired Connection In order to connect the Wii console online with a wired connection, you will need the following:
  • A Wii LAN Adapter (where to buy)
  • An active broadband internet connection, such as DSL or Cable.
  • A compatible Internet Service Provider (ISP). Some ISPs require a sign-in every time you connect online, or are otherwise incompatible. Contact your ISP for more information.
  • Either a cable modem or wired router with an available ethernet port. (DSL users: while some DSL modems may be compatible, our experience has shown that many are not. We recommend using a router.)
  • An ethernet cable.
then go here for more information
http://www.nintendo.com/consumer/systems/wii/en_na/connectingOnline.jsp?entryId=wdRouter
this information was found on nintendo's customer service website
I hope you find it useful
Dec 29, 2008 | Nintendo Wii Console
Internet explorer cannot diplay the webpage. I am not connected to the internet, but all my connections are hooked up correctly
A couple of questions pls:
  1. how are you connected, DSL or dial-up?
  2. if it is DSL, wireless, cable, two-wire/telephone?
  3. what is the brand of your modem?
  4. do you use a router?
  5. what is your machine, a laptop or desktop?
  6. what is your operating system?
  7. who installed the system?
  8. who is your ISP and what is your subscription/package (speed of connection)?
  9. have you tried calling your ISP?
Hope you post back additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 20, 2008 | Computers & Internet
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
