Question about Car Audio & Video
Speakers front 1 and front 2/sub room section work fine, but the center and rear sections won't work.
    Scholar:
  • 83 Answers
Is this an amplified system by a amplifier? Check the connections at the back of the receiver/radio. Also check the settings of your radio, the center & rear channels might be turned off.
Posted on Apr 09, 2011
Kenwood vr606 reciever shutting off subwoofer and centre speaker simultaneously after few minutes/seconds of powering on. WHat's the cause?
The receiver's out put sections are grouped in pairs. Front left and right in one output, rear left and right in second output, and center channel and sub output on the third. Sounds like a semiconductor or semiconductors have gone bad in the center & sub output.
Nov 19, 2015 | Kenwood VR-606 Receiver
4 ohm and 8 ohm speakers
You can plug in higher ohm speakers , the higher the ohm the higher the resistance is, it is a danger when you plug lower ohm speakers into a higer ohm Amp , at a high volume that will cause them to blow , the center speaker would be fine to use a higer ohm speaker , your best choice is to buy a Active Subwoofer, which means the sub has it's own power supply , and u can blast the thing as much as u like , thn u can turn the bass down on all the other speaker's so u can play it louder , and have the sub turned up has high as u like , this is the best way to get great sound with high volume , buy a Active sub woofer , any active subwoofer is ok , a active sub woofer has its own volume and inputs on the speaker ,
Dec 09, 2007 | Audio Players & Recorders
I been having a problem with my JBL TLX CSS-SUB1, I don't have the manual. Connecting speaker wires from the JBL TLX CSS-SUB1 to the a Digital Audio/Video Control Center ( it's a reciever) I confused,...
The connection on the receiver would be the sub woofer out. Not a sub woofer out LFE, a sub woofer out with speaker wire connection. From there you plug it in to the top section of the available terminals on the sub you are referring to (speaker level input). One in positive and the other in negative matching what you did on the receiver with correct ends. The speaker connections underneath the top connections is for additional speakers like surrounds to be able to be connected directly to the sub woofer speaker level out for sound. This of course would be for an older receiver connection. I do not think it is possible to convert this connection to an LFE and have it work properly. If the receiver does not have sub woofer speaker connection and only a RCA out then you can try to connect both rear speaker connections from the receiver to the speaker level inputs on the sub and then connect your rear speakers to the speaker level output on the sub to power them. This is an active sub woofer but for some reason they made it connect as if it was passive. I am not sure if this sub is designed for really low frequencies required for movie or if it is better for music.
Nov 01, 2010 | Audio Players & Recorders
No sound from front speakers
Check if a or b or what is reflected for speaker.
Oct 27, 2017 | Technics SA-DX950 Receiver
We have a very small living room now. I would like to set up just the center speaker and the two rear speakers and disconnect the two front speakers and the subwoofer. Is that possible?
well it depends on what audio device installed on your computer coz other you can make an adjustment for 4 channel, 5 channel & 7 channel speakers including sub woofer and surrounds. try to check your setting or the best way is to unplug your front speaker and sub woofer. good luck!!!
Oct 07, 2009 | Onkyo HTR500 Receiver
I have a yamaha htr-5240 receiver. Also have a 6 speaker polk-audio surround set.Center,2 rear,2 front,& the subwoofer. The sub is a psw-250 with no sub out or LFE.I can't figure out what i've done...
First, look at the sub, their should be a switch for "auto" "off" "on" switch it to "on" Then use the Left input on the sub not the right. Left is for mono. Now, if you still dont have any sub, disconnect the RCA at the receiver and touch the end of the RCA, if the sub is on, you will hear a loud humm. Now, go back into the receivers Menu and go into manual setup, find "Audio" and select "Auto". That should do it. If not, put the receiver on "Tuner" and set the sound to 7 channel stereo (I'm not sure if the HTR series has this) or "Adventure" I'm a Yamaha RXV series Dealer so the names may differ. (check in manual for audio surround settings) Anyway, this should let you know if you've got all your spkrs working. Then make sure your TV's external audio is set to "Fixed" (it may be called audio out) depends on TV type. Scroll thru TV's audio menu. If you still have problems post a comment and I will help some more. Hope this helps
Jun 21, 2009 | Audio Players & Recorders
No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
May 23, 2009 | Kenwood VR615 Receiver
Center, and rear surround speakers
Sounds like the rear volume is just turned down. Cant be the amp if the front and subs are working
Aug 28, 2008 | Bose Acoustimass 15 System
Surround Sound Center Speaker/Sound Card issue
You need to use a digital interface cable between the sound card and the speakers to get all of the 6 channels to work properly.
Sep 24, 2006 | Inland 58019 ThunderSound 5.1 PCI Sound...
Car Audio & Video Logo
78 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
