My netbook keys aren't work, it's been a while since it's gotten wet. What is the best thing to do?
  • 6,771 Answers
The netbook keypad will need to be replaced in order to fix the problem, I recommend having an inspection done to make sure there no other issues.
Posted on Apr 09, 2011
Can a key with a chip in it get wet
I have gotten mine wet before and the chip still works just fine. Ive washed them on accident also
Jul 29, 2014 | 2010 GMC Acadia
My packard bell netbook's keys aren't working so I
Please turn off the computer. Turn if upside down and remove battery. Hold down power button for a minute. Please restart it.
May 31, 2013 | Computers & Internet
Right arrow key not working
Did you spill anything on the keyboard?
You may need a replacement keyboard. They aren't that expensive and not that hard to replace.
Aug 27, 2012 | Samsung N150 Plus 101inch netbook
Keyboard got wet
The best thing to do with any electronics that have gotten wet is to remove any power source and allow it to dry thoroughly (letting it sit for several days in a dry area). The last thing you want to do is apply power to electronics that are wet, as it will most likely permanently damage them and cause failures (sometimes only intermittent).
Jun 25, 2012 | Computers & Internet
Certain keys on my key board aren't working like C , S, V , M
Replace the keyboard that most generally means liquid has been spilled on it at 1 time. They run about $20 online. You can try an external USB keyboard to verify thats what it is b4 you order a new 1.
Sep 24, 2011 | Coby PC Netbook 1ea
My keyboard is working fine but my enter key or return key as they say and shift key below the enter key isnt working.
If there is a mechanical fault there is not much you can do. If other keys are working then there definitely is a mechanical fault. Some crafty expert has to remove those keys and find out what the problem is. There can be broken brackets underneath or there might be some drops of liquid food congealed underneath the keys. Only the person who will open the keys will find out first.
Jul 22, 2011 | HP Mini 1000 Netbook
My netbook is generally running very slow,what can I do to improve speed
Hi
To speedup your netbook follow these steps;
1. Remove if any apps in the 'startup' (like instant messaging, dictionary, world clock openoffice etc (just remove it from the startup folder) Make sure programs like these are not starting up when you boot up else your netbook will feel slow.
2. Be sure that you are running your spyware and virus scanners are working, updated, and have fully scanned your system. These malicious pieces of software can slow down a fast system. They will wreck the speed on your netbook if you aren't careful.
3. One upgrade that you can do to your system that is cheap and easy to do on your own is to add RAM. It's best to maximize your netbook's RAM for best performance.
4. Uninstall unwanted or heavy load softwares.
5. Don't have open programs that you aren't using minimized. If you aren't going to use a program, shut it off. Try to only have a few programs open at once.
6. Use cloud based applications. These are software that you can use that are being processed on a server versus your machine. This is a better way to multitask on your netbook.
7. Consider adding Linux or buying a Linux netbook versus a Windows netbook. Typically the Linux netbooks do run much faster as they are designed to take up less resources making your netbook run much faster.
8. Delete temp files.
9. Running heavy loaded softwares will make the battery hot, that way the battery life is shortened which causes a slow running netbook.
Hope this helps.
Please rate if this solution was helpful, thanks!
Jul 14, 2011 | ASUS Eee PC 900HD Netbook
I just bought a used 1991 Jaguar XJ6 Vanden Plas. I am locked out! None of the keys work. None of the doors open including the trunk. The only thing it does is make a couple click noise but the actual...
use wd-40 or liquid wrench and a tooth pick- use toothpick to hold the little metal flap in lock back and spray oil inside- locks weren't uses much as you have remote locks- lack of use can cause rust/lockup
key will start engine? if not- you might have gotten the wrong keys- or there might be a different one for the door locks from the ignition key
May 29, 2011 | Jaguar Vanden Plas Cars & Trucks
My netbook got wet. Now the number buttons don't input one number they input three of the same number. My left mouse button doesn't click it is now working like the right mouse button. HELP???
I suspect that your net book has not dried out completely and has left a moisture trace on the membrane keyboard that is shorting to another trace. Heat the oven to 100 degrees (caution, do not go over 110 degrees), and place the net book in that 100 degree heat for a few hours. Hopefully any lingering moisture will evaporate and leave the key traces clean.
May 18, 2011 | Sylvania G-Netbook
I SPILT GRAVY ON MY NETBOOK, NOW A FEW OF THE KEYS WONT WORK, HOW DO I REPLACE IT
You don't, because the keyboard is not a "user-replacable" part.
Take it to a qualified technician, and get all the gravy cleaned out,
and get a replacement keyboard.
Dec 26, 2009 | Acer 91.63X07.001 Keyboard
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
