Question about Nokia Cell Phones
My 6133 is barely audible on headset speaker. Works fine on loudspeaker.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 144 Answers
Hi there!
there's a huge chance that the headset that you have is already damaged. either its speakers or its cord. try using other headset, if the problem is the same, it can be the headset port (where you insert the headset jack). try moving it while its plugged see if the sound changes. if its the headset, replace it, if its not, bring the phone to a local technician so that they can replace the earphone slot. =)
Posted on Apr 09, 2011
No left a or b speakers
have you checked the speaker balance position as what you describe indicates you have the setting all the way to the right
Oct 03, 2016 | Audio Players & Recorders
Friends hear echo when headset is on in x-box live party chat
I had the same exact problem with a brand new x32 headset. right out of the box it was echoing for my friends. Also, if I muted my mic it would kill the chat volume (ie barely even audible). I switched the voice to play through speakers and it worked flawlessly after that.
Not sure if it is a hardware issue with my controller (my other headset worked just fine) or if it is a defective cable I received, or a design flaw with the x32. If you are looking for a work around, try setting it to play through speaker.
May 15, 2012 | Voyetra Turtle Beach Tbs-2265 Ear Force...
I need leads to connect my NAD C320 BEE amplifier to PSB T45 speakers. Not sure which plugs are needed to fit into the speakers.
From the C320 manual, Page 5...
11. SPEAKERS
Speaker terminals for speakers with an impedance of 4 ohms or more. Connect the right speaker to the terminals market 'R +' and 'R-' ensuring that the 'R+' is connected to the '+' terminal on your
loudspeaker and the 'R-' is connected to the loudspeaker's '-' terminal. Connect the terminals marked 'L+' and 'L-' to the left speaker in the same way.
Always use heavy duty (16 gauge; 1.5mm, or thicker) stranded wire to connect loudspeakers to your NAD C320. The high-current binding post terminals can be used as a screw terminal for cables
terminating in spade or pin sockets or for cables with bare wire ends.
BARE WIRES AND PIN CONNECTORS
Bare wires and pin sockets should be inserted into the hole in the shaft of the terminal. Unscrew the speaker terminal's plastic bushing until the hole in the screw shaft is revealed. Insert the pin
or bare cable end into the hole and secure the cable by tightening down the terminal's bushing.
Ensure bare wire from the speaker cables does not touch the back panel or another socket. Ensure that there is only 1/2" (1cm) of bare cable or pin and no loose strands of speakers wire.
Register and download the PSB manual for free at retrevo.com
http://www.retrevo.com/support/PSB-T45-Speakers-manual/id/23107ag412/t/2/
If you're pondering those jumpers on the back of the speakers, my advice is to leave them in place and ignore them. Connect the speaker cables to either plus or minus.
Bi-wiring does nothing but make you use twice as much speaker wire for the same electrical effect. Bi-amping assumes there are deficiencies in your electronics that must be worked around, again by using more speaker wire and separate amps.
Apr 15, 2011 | PSB Century 600i Speaker
Hi, my phone works OK, but I cannot get any sound thorugh the small ear speaker, but if it I put it on Loudspeaker it works fine, any ideas? Thanks
hi dave
the problem could be 1 of 2 things
either the ear speaker is faulty, or your system connector is shorting out
does it come up, as if there is a headset plugged in??
so, first of all , at the bottom of the phone, where u plug in the headset, is there any green or discolouration?? on the gold pins
Aug 27, 2010 | Sony Ericsson K800i Cellular Phone
Nokia 6133... all works fine except can't hear caller on handset
time to change your speaker or much better visit your friendly mobile tech... speaker don't cost tat much...
Aug 26, 2009 | Nokia 6133 Cellular Phone
Can't hear caller or people I call unless I hit speakerphone
This is the problem the speaker on your phone, I will give you some tips to clarify this
* try with the hands free (if you have)
* try with the loudspeaker mode.
If it works good in these modes, then you got to replace the hearing speaker.
Jul 21, 2009 | Sanyo Katana SCP-6600 Cellular Phone
Radio works well in headset mode but has a lot of disturances in loudspeaker mode
Hi Friend,
When u are hearing the Radio or Music Player in your mobile by using the headset its clear but when u are using thro' loudspeaker its not clear because of below reason,
1.There may be problem in the Speaker(LoudSpeaker).The Solution is u may change your speaker by giving to the Service Center.
Regards,
Ayyasam
May 31, 2009 | Nokia 7610
For Sansa E260 MP3,can't get the volume up. Battery, headset fine
This link will show you how to take it apart. From there I suggest just try and clean it....Hope this works
Apr 19, 2009 | SanDisk Sansa e260 MP3 Player
Headset Doesn't Work...
hi Ive got a logitech headset 250 but I cant use that in my laptop and why !??
pleale help me!
see yah bye for now
Nov 13, 2007 | Logitech 250 Headset
Cell Phones Logo
21 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
