Question about Samsung Computers & Internet
I am trying to connect a samsung syncmaster 151v to my computer and the moniter reads video mode not supported what am i doing wrong?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 332 Answers
Your resolution is set to high for the monitor to accept it. Go into control panel and click on Display then click on display setting and lower your resolution keep going lower until your monitor accepts the resolution size and your monitor should work for you.
I hope this helps you out any positive feedback to me would be greatly appreciated.Thank you
Posted on Apr 09, 2011
My samsung syncMaster 753s moniter does not support resolution of xp what i do further
Your monitor can easily support Windows XP resolutions. The problem almost certainly lies in your video settings. You need to lower your screen resolution and/or refresh rate.
If you can not start Windows due to this problem, you will have to start Windows in VGA compatibility mode. Follow these steps:
  1. When your PC starts up, press F8 a few times
  2. This will bring up a menu whereby you can select VGA mode from the list
  3. Once you are logged into Windows, right click anywhere on the desktop & select "properties"
  4. Then go to display settings & select a resolution of 1024 X 768.
  5. Go to advanced settings and make sure your refresh rate is no more than 70 to 75Mhz
  6. Restart Windows normally & your display should be correct.
Let me know if you have any further questions.
Best wishes,
Graemevm
Mar 30, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
I bought a used Samsung Syncmaster 151v and had it for only a few hours before a thunderstorm knocked the power out. When I went to turn the monitor back on, all I got was a blinking green light and no...
This can be a fuse or the CRT tube or even a transistor, I would rather try to find a technical shop that can determine the problem, just be carefull that they dont charge you to check. Thus it will be for yourself to establish if it's worth it. Most of the time it is.
Good Luck
Mar 03, 2010 | Computers & Internet
MY SAMSUNG SYNCMASTER MONITOR SCREEN DOES NOT COME ON WHEN I TRY TURNING IT ON. HOWEVER THE POWER BUTTON BLINKS GREEN. ANY ADVICE? THANKS SAMSUNG SYNCMASTER Monitor (black) 739S O seen at the back
The cable connecting to the PC might be loose, or the part entering the monitor could be.
Try turning the monitor on, and after a few seconds, turn on the computer. You should be able to see the BIOS POST screen text flashing by. If you can't, there is something wrong in your hardware settings.
If you can, however, that's the OS resolution set too high: the monitor shuts down to protect itself. Boot in safe mode by pressing the F8 key immediately after powering up, then lower the video resolution in Control Panel display settings to something safe - 1024 x 768 usually does the trick. At that point you can reboot in normal mode and raise the resolution again to the maximum supported by the monitor (check the manual for that).
Oct 31, 2009 | Computers & Internet
A green hue from my samsung syncmaster 720n
Check the video cable connection at both ends. If it is secure, then move the cable in circles at both ends.
If the cable breaks a single wire, it will still be close enough to make contact under this test.
The red is almost always the one that will break first and cause the green and blue signals to be the only ones to be active resulting in a blue/green tint.
If you have another cable just try that instead.
Apr 28, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung syncmaster
my samsung 730B moniter will not run how do I fix it?
Dec 28, 2007 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Monitor
it's a problem with the graphic card, not the monitor, try finding another driver.
Apr 26, 2007 | Samsung SyncMaster 793DF (Silver, Black)...
Computers & Internet Logo
104 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
