Question about Amana Refrigerators
Amana model# SZD23VE refrigerator were is the water filter? or does it even have a water filter?
  • Amana Master
  • 5,228 Answers
Yes it has a water filter option. The water filter housing is in the refrigerator near the top of the unit. You need to twist the old filter itself to the left to remove. (You will be removing a cover that you need to take off the old filter and put on the new filter. This cover can also be replaced without a filter to bypass the filter. The part number for the filter is AP4310541, http://www.appliancepartspros.com/part_details.aspx?part_id=4310541 .
I hope this helps.
Posted on Apr 09, 2011
I have an Amana side by side refrigerator model ASD2522WRB06. I replaced the filter that is located in the grill at the bottom of the fridge. Now water does not flow at all.
It should work with the filter removed because of a automatic bypass built into Amana refrigerators but sometimes even new filters or copy cat filters will not work at all because they have a defective area where they connect to your water system.
http://appliance911seabreeze.com/
Nov 14, 2015 | Amana Refrigerators
Were is the water filter on a amana sxde 526 m does it have one
I looked up your Model with both P#'s. Sadly no water filters for your Refrigerator. Amana only has a few models with water filters.
Sep 04, 2012 | Amana 22.6 cu. ft. Side-By-Side...
We never received a manual and now need to replace the water filter. model no. ASD2522WRW03 - ser. no. S01831393. also how do we order a replacement manual
The direct link to the manual from Amana is http://www.kitchenaid.ca/assets/pdfs/literature/User%20Instructions%20-%20W10237701A.pdf . If the direct link doesn't work, start here: http://shop.amana.com/product_literature/search_results.jsp?searchTerm=ASD2522WRW03&siteCd=AMA&userType=Consumer . The manual is also available at Manage My Life: http://www.managemylife.com/mmh/owner_manuals/17324/AMANA-Side-by-Side-Refrigerator-L1002225?brand_name_search=ASD2522WRB03+AMANA .
The filter you need is T2RFWG2 and P2RFWG2 (part number 4396841) . The filter is in the base grill on the freezer side of the side by side. There is a cap over the filter. You need to push the release button on the cap to remove the cap and filter. Save the cap and put it on the new filter before replacing the filter. If you replace the cap, you can use the water and ice dispenser without the filter.
If you want a printed copy of the manual, you can order it from Sears Parts Direct. They also have the filter. See http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-ASD2522WRW03/1268/0165000/W1009009/00001?blt=06&prst=&shdMod= . The manual is part 1 ($5.99) and the filter is part 30 ($54.98). The filter is also available from Partstore.com http://www.partstore.com/Model/Maytag/Maytag/ASD2522WRW03.aspx for $37. Amana sells the filter here: http://www.amana.com/accessories/refrigerators/water_filters/refrigerator_water_filter___in_the_grille_fast_fill_push_button_4396841.pro?scr=category for $40. If you go here: http://www.amana.com/accessories/refrigerators/water_filters.cat , you can order several filters at once.
I hope this helps.
May 22, 2011 | Amana Refrigerators
Where is the water filter on the amana #scd25tw
The Amana with model number SCD25TW does not have a water filter. You would have to install an in-line filter on the water supply line if you want to filter the water. If your talking about the model number ARS266ZBS, then open the refrigerator door and look at the top right hand side. You should see a filter housing with a tab to release. Once released you have to remove the filter from the housing to replace it. When finished be sure to run about a gallon through the dispenser, to flush any air out of the system.
Mar 23, 2011 | Amana ARS266ZBS Side by Side Refrigerator
We have a Amana refrigerator Model # SXD22SW2 and need to replace the water filter. We don't have the owner's/service manual for the refrigerator and I have looked everywhere on-line, including the Amana...
Removing a water filter from the base grill of your Amana brand refrigerator:
Removing and replacing a water filter - base grill location
Filters situated in the base grill (below the freezer compartment) of Whirlpool-built side-by-side refrigerators are relatively simple to replace. Follow these two steps:
  1. Grasp the filter's end and make a one-quarter turn to the left.
  2. Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order, making sure to first remove the red cap from the filter. Proceed by pushing the filter straight into the slot, and then giving it a one quarter turn to the right.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Oct 13, 2010 | Amana SXD524VW Side by Side Refrigerator
Need to find water filter on my amana model scd23vw refrig.
Install Water Filtration Cartridge (some
models)
a. Remove bypass cartridge from water filter head in rear
right corner of refrigerator section. Twist cartridge
counterclockwise 1/4 turn and pull down to remove.
Save bypass for use at a later date.
b. See Water Filtration System Installation and
Operating Instructions provided with water filter
cartridge for filter installation and operation.
Aug 16, 2010 | Amana Refrigerators
Where do I find the water filter on a Amana Model ARSE67RBS and how do I get to it
here is a breakdown of the location of the water filter on your fridge. hope it helps. 67002378 is the part number for the filter.250
Nov 09, 2009 | Amana ARSE67RBS Side by Side Refrigerator
Amana fridge water dispenser real slow
u m,ay have to change the filter tubing as well
Mar 15, 2009 | Amana ARB8057CSL Bottom Freezer...
WHERE IS THE WATER FILTER ON A AMANA SXD20NPW?
Good news and bad news. Here is a link for the manual:
http://shop.amana.com/assets/pdfs/literature/ARF9233.PDF
However, it is poor quality, and really doesn't give much hint where the filter is, or even if it has one. There is no mention of a filter anywhere. Sorry.
Oct 16, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana ACD2234HRS replacement water filter
Don, I have a manufacturers part number of 67003591, you might be able to cross reference that. Straight from the manual..Catriver.
Jun 20, 2007 | Amana ACD2234HRS Side by Side Refrigerator
Refrigerators Logo
120 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
