Question about Westinghouse Electric Westinghouse Lighting 3speed Ceiling Fan Switch 7707500
INSTALLING CEALING FAN SW. WU PIN (E198635) 3SPEED SWITCH .TO NO NAME CEILING FAN . 4 WIRES BLACK,RED, AND 2 ORANGE.....HELP
3 Suggested Answers
aquaman987
  • 927 Answers
SOURCE: I am installing a 3
I am assuming it is the switch in the picture on your post.
The switch has three wires, black, red, blue.
The black hot wire from your supply connects to the black wire on the switch.
The first pull connects black to red, so that could be your fan.
The second pull connects black to blue, so that could be your lights. Connect all of your light blacks together and connect that to blue.
The third pull connects black to both blue & red. The fan & four lights would come on.
All of the neutral white wires get connected together - one from the fan, four from the lights and one from the supply.
If your old switch was wired differently, take pictures and use that configuration.
Make sure power is OFF.
Gary
Posted on Sep 06, 2011
  • 351 Answers
SOURCE: Replacing a pull chain 3-way ceiling fan light switch
OK .. the thick black and white are the power for the fan , are there also white wires on the lamp sockets ..??
The thick black wire should connect to the black wire on the switch.
The small black wires connect to the red and blue wire on the switch .. two small black wires each .. that should give you a position for 2 lights , and 4 lights, on the step switch .. but there should be white wires from the lamp sockets connected to the thick white from the fan .
please respond .
Please Vote !!
Posted on May 25, 2010
Testimonial: "I appreciate the response, which reinforced my thought process and it worked - Thanks!"
Black wire, white wire, and tan wire coming from ceiling. New fan has blue, black, white wire and green wire on the bracket how does it hook up
1. Have on hand either wire connectors or electrical tape
2. Look at the wires coming from your ceiling fan. The black wire from the ceiling fan is the hot wire that runs the motor and turns the fan blades. The white wire is neutral and completes the fan circuit. The blue wire is the hot wire for the ceiling fan light fixture. The ceiling fan motor does not have a ground wire.
3. Find the short green wire or the green ground screw on your ceiling fan hanging bracket. Attach the bare copper wire from your electrical box to the short green wire by twisting and orange wire connector to the two wires. If you only have a green ground screw, wrap the bare copper wire around this screw and tighten the screw against the bracket to secure the wire.
4. Match the end of the white insulated wire from the ceiling fan to the end of the white wire from your electrical box. Twist a wire connector onto the two wires to complete the neutral circuit.
5. Connect the black insulated wire from the ceiling fan to the black insulated wire from the electrical box. If you do not have a separate toggle switch on the wall to operate the ceiling fan and light separately, grab the blue wire and place it with the black wire from the fan motor and the black insulated wire from the electrical box. Twist a wire connector to all three wires. If you have the additional toggle switch, connect the two black wires together with an orange wire connector, and then match the blue wire and the red wire together. Twist another orange wire connector on the red and blue wires
Nov 11, 2017 | Dryers
Do not know color coding for ceiling fan speed control witch WU Pin 198635
How many wires on capisitor? Black usually goes to L. Should write this down before removing switch. You can't buy any swich off a rack and expect it to work even if it looks the same on the outside.
www.fanfairceilingfans.com
Mar 20, 2013 | Dryers
Fan switch are LJY-280A and E198635
I have a Hampton Bay indoor/outdoor ceiling fan with 3 speed fan switch WU Pin LJY280A, E198635. It is a L-3-1-2 (ccw) switch with purple, grey, black and brown wires. The wiring is different than most on web. The L is not black, 2 is black. My wiring for the switch is L-Purple, 3-Grey, 1-Brown, 2-Black.
Found schematic on web that I think is correct:
Off-none,
Hi-L,1 4uF,
Med.-L,2,3 10uF & 4uF,
Low-L,3 5uF & 4uF.
I hope this helps someone.
Feb 21, 2012 | Hampton Bay Dryers
Replacing a pull switch on an Encon fan. 4 wires. Didn't label wires before I pulled them out. Number on old switch is 1282M and 17292101 with A B C D labels. Can you tell me which wires go where? ...
I have just figured out the wiring to my Encon 5TD42WHC ceiling fan. (This is not to say your fan won't be different.) You can't use just any switch; the switches vary in operation. See the images attached. Good luck, and be careful working with AC voltages.
Dec 23, 2010 | Encon Industries (78018) Ceiling Fan
Wiring diagram for a 3 way ceiling pull switch.
These fans are manufactured by a number of overseas companies and sold exclusively by Home Depot. They do not have a standard color code for the fan switch. What you can do is turn off the power, keep the white neutral connected. Then using the black power wire fro the ceiling, take one of the switch wires and connect to that black, turn the power on and observe the speed .. low mark it 1, medium mark it 2, high mark it 3. Repeat untill you have identified all the speed wires. Then connect these wires to the 1,2,3, terminations of your new switch
Questions?
Please Vote !
May 29, 2010 | Hampton Bay 24750 Huntington III Ceiling...
please respond .
Please Vote !!
May 24, 2010 | Westinghouse Electric Westinghouse...
Cealing fan wiring problem
Hi, try this.
The pull chain has four wires, L, 1, 2, 3. Connect '3' to the main black (hot) wire entering the fan. Connect 'L' to the red wire on the reverse switch. connect '1' to the lowest uF, eg ( 1.5 uF ). Connect '2' to the next uF, eg ( 3uF ). The other end of the capacitor has to be connected to the neutral wire, ( black with pink or white). If you have a VOM tester, check that pull switch is working properly, eg when the switch is on the Hi speed position, you should get a continuety reading on all the ends of the switch,
Apr 05, 2009 | Westinghouse Fans Indoor Ceiling Fans
MSI MS6511 jumpers overview?
Dear User here is confiruration.
1.Orange with + sign and orange is for HDD LED.
2. Green with +Sign and Green is for Power LED.
3.Red is for Power switch.
4. Blue of Black is for Reset switch
Mar 29, 2009 | Computers & Internet
Ceiling fan wires
is the old fixture still installed?
Oct 16, 2008 | Hampton Bay 24002 Ceiling Fan
Westinghouse Electric Westinghouse Lighting 3speed Ceiling Fan Switch 7707500 Logo
4,543 people viewed this question
Top Westinghouse Electric Electrical Supplies Experts
AJMAL KHAN
Gene Haynes
Terry Weaver
Terry Weaver
Are you a Westinghouse Electric Electrical Supply Expert? Answer questions, earn points and help others
