Question about Gaiam Inversion Table
I'm looking for instructions to use Back Biotek inverter or similar
Use safety strap at rear to restrict inclination to about 15 degrees when first using. Gradually increase over days/ weeks.
Adjust boom(long spine) so that you are just balanced on the table(moving your arms forward or back tilts you either way)
Posted on Aug 24, 2011
Screen blank
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it.
Feb 09, 2011 | Dell Inspiron 1525 Notebook
My lcd does not display anything when turned on
Feb 04, 2011 | Dell Latitude D810 Notebook
SCREEN FOR MY NOTEBOOK IS NOT WORKING BUT THE PROCESSOR IS RUNNING
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it. Usually you can find cheaper replacements on Ebay.
Jan 15, 2011 | Fujitsu Siemens LifeBook S6120 Notebook
Compaq presario cq61 screen went dark but can still see window faintly through the dark sreen.
If no luck, try to remove battery and drain the power, then replace battery and turn on.
Jan 06, 2011 | Computers & Internet
No display on monitor
If the laptop acts as it would start and there's just no image, look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
Jan 05, 2011 | HP Pavilion dv6000z Notebook
Hi, my hp dv2000 screen is blank when I turn it on. It hums and lights up like it's supposed to, but the screen is completely blank! What do I do?
Nov 30, 2010 | HP Pavilion dv2000t Notebook
Blank computer screen
Nov 09, 2010 | Toshiba Satellite Pro L300 Notebook
Blank screen
Oct 18, 2009 | Acer Aspire 3000 Notebook
Gaiam Inversion Table Logo
328 people viewed this question
Top Gaiam Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Gaiam Exercise and Fitnes Expert? Answer questions, earn points and help others
