Question about Dacor Epicure ERD36 Dual Fuel (Electric and Gas) Kitchen Range
All elements in the oven do not work - Dacor Epicure ERD36 Dual Fuel (Electric and Gas) Kitchen Range
    President:
  • 1,654 Answers
Are you getting any trouble codes on the control panel? If not then the elements may just be burned out. If you have a volt ohm meter, pull the elements out and check them for resistivity, or ohms, this should go to infinity if it is good and if they are bad then reading will be very low to nothing at all. If they are good, then check the element plugs for voltage, if your not getting any juice to the element then it must either be the thermostat, or the control panel. Let me know what you find.
Posted on Apr 09, 2011
Problem start when i turn Oven only on teka, then the fuses blown up. I can still use grill but whwn I turn to oven fuses go blow up again.
Hi! It seems it is not the heating element! It seems to be before that. Either a short circuit delivering to much current thus causing the blow. I would check the corresponding cable all the way to the circuit and the circuit elements corresponding to the oven element. The grill and oven elements being "independent" explains why grill still works. (A short circuit seems quite possible to me!)
Dec 06, 2014 | Ovens
Top element not working
either a wire of the element or a faulty element
Feb 13, 2014 | Fisher and Paykel Titan OD301M Electric...
Hotpoint 24in double electric wall oven 20RJ83D not heating, element is working
The thermostat for the upper element has gone bad. Needs to be replaced.
Apr 15, 2017 | Ovens
Need heating element for oven of 1950's Frigidaire by GM stove
Fixya is unable to identify parts sources.
Jan 23, 2018 | Ovens
It would appear that the main oven element is not working. I had a power cut whilst using the oven recently and have only just realised that the oven will not heat up. Everything else is working ok. If it...
If it is a fan forced oven, the element is round in shape and goes around the fan blade on the back wall of oven.
To replace: Turn off power!!
-Remove side racks from oven, then remove rear panel.
-You should now see fan blade and fan element.
-You need to remove oven from cavity, then remove rear outer panel.
-You can now access element- it will be held in place by 2 small nuts either side of element wiring connections. Disconnect element wires, unscrew nuts. Element is now removed!
Reverse procedure to reassemble and test. If oven is heating OK, also check main oven thermostat is regulating temperature (ie clicks on and off), as sometimes thermostat can fail if element has blown
Aug 10, 2009 | Smeg Ovens
Maytag electric oven - MER5770AAQ. lower heating element not work
Hi, Unplug the oven and remove the element to test it. Check the element and see if there is continuity. If the element is open, replace it. It can be bad even tho it doesn't appear bad.
I hope this helps you.
Vic
Jun 20, 2009 | Ovens
Belling XOU 252 Oven suddenly stopped working
Yes ,I would say that without doubt the element has gone
Elements can go without any warning at all.
Dec 13, 2008 | Belling XOU252 Electric Single Oven
Frigidaire double oven has one element not working in each oven
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
Nov 24, 2008 | Frigidaire GLEB30T8A Electric Double Oven
Dacor Epicure ERD36 Dual Fuel (Electric and Gas) Kitchen Range Logo
94 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
