Question about Kenwood KDC-MP928 CD player with MP3 WMA
My wires blew up when i was conecting my stuff .. I really like this radio , and its still workin .. where can I find the wire that conects the radio to the car ? .. pleaze tkns I live around mtl in qc canada ...
  • 30 Answers
Remove the head unit in the dashboard you will see the wires at the back of the head unit. You have to remove also the center console so that you can pulled out the whole head unit.
Posted on Apr 10, 2011
Radio will not work when car is running but will work when key is on acc
connect the red wire to acc fuse, the yellow wire to constant dc and the black wire to car chassis. probably you connect the black wire to the dimmer light
Oct 21, 2012 | JVC KD-G140 Car CD Player
How to fix a 93 grand marquis radio?
check your remote wire witch is blue and hot wire witch is red on the back of cd player an see if its still conected
May 28, 2012 | 1993 Mercury Grand Marquis
Radio
if youve replaced all fuses and radio not working the impact could have losened conections to radio. pull radio and check conections/leads if ok have radio checked out
Dec 12, 2011 | 1994 GMC Sonoma
I need to know what wires are what in my dash for my radio in my 2000 grand prix please nothing is labeled like it should be for example it says red wire is accessory I dont have a red wire the closest...
first things first check your fuses and i mean all of them replace all that are bad with proper fuse amprages
you are going to have to do some probing of those wires to find the ones you need you can buy a voltmeter(25$ or less) or a simple test light(2-5$) from a local automotive store
colors to look for are
primary power wires :red,yellow, black for ground
accsesory wire from igntion ,orange or blue with wite stripe and posibly pink(rare)
any wire that has an on and off state from the turn key igntion can be used depending on its gauge/size test the orange one first as this is the most common color to use for the accsesories wire
to test you have the igntion in the on postion if you get a readying of +12 volt and then turn the igntion of and recive a reading of 0 volts this would be an on off wire
note: check the auxsilary postion of the turn key igntion also if there is no power to the wire in the auxzilary postion it is the incorect wire for the radio
BLACK> should be a ground wire
RED>should be an igntion supply wire of a larger diameter
YELLOW> should be a battery supply lead strait from the fuse box battery conection "always on"connect the wire of the stereo labeld battery to the always on battery lead ,this is for the memory function of the radio
ORANGE>(may be pink only seen pink in buick's) should be an on/off wire from the igntion and used for the main power of the radio so it is shut of when the car is turnt of this is also the wire you would hook the amplifyer on off up to if the radio dont supply the blue wire with white stripe aka ant/motor
test the on off state of the wire befor conecting it to the radio
you will conect the red (+ positive) wire to this on/off state wire
cation! disconect the batery ground wire when conecting anything to the main yellow battery wire as it is directly conected thru an exspensive(12$) 30 amp fuse
if you dont know what wires are what for the speakers in the car use a 9 volt batery to find the speaker wire leads (ues a brand new 9 volt)
ntsc standard color pairs are
white and grey front
green & brown for back
i dont remeber the left and right
the black stripe on the speaker leads means the ground or negative side of the speaker
good luck instaling your new radio hope i have helped you out
Feb 24, 2010 | 2000 Pontiac Grand Prix
Cdm1250 ignition on wire radio stays on
I dont understand your question, but ignition wire wich is conected at pin 10 in the accesory connector must be conected to the ignition, fuse is recomended for security reasons but you can use a 1 amp fuse, this line is just a sense to get the radio on or off folowing the ignition
Jan 07, 2010 | Motorola Radio Communications
Wireing turner plus 3 to president washington that is four pin
Wow I've never seen a six wire Turner + 3 anyway give this a try 1)shield & blue 2) white 3) black 4) red if the radio keys up as soon as you plug in the mic switch black and red . Good luck . Dan
Jul 23, 2009 | Magnum DeltaForce CB Radio
I conect the amp but its not on
make sure your ground wire is connected securely to bare metal
Mar 22, 2009 | AudioBahn A8000T Car Audio Amplifier
How to wire in dash cd player
if your instaling an after maket radio as in a kenwood or bose, and stuff just get a conection that goes from the stock radio hookup to the new radio. it keeps you from having to splice and cut your wires.......
Aug 02, 2008 | JVC Car Audio & Video
Car Audio & Video Logo
42 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
