There is no display on the thermostat which prevents me from turning on the heater.
  • 413 Answers
Assuming this is a central air unit, you have lost power to the heater giving you a blank display on the thermostat. Also, some thermostats require batteries for the display to work.
Posted on Apr 09, 2011
I have a HVAC thermostat that had "always-on" backlit display.It still works but the display goes off in a few seconds.How can it be fixed to always stay on?
If the display on your thermostat resembles the illustration, it is an LCD not backlit (as in TV). The reason the display turns off is to prevent premature failure.
Aug 10, 2016 | Honeywell TH5110D1006 Focus PRO 5000...
My hot water is scalding hot and won't go down when I turn the thermostat own. Is it the thermostat?
Probably a faulty thermostat but a possibility, depending on design and area that heavy internal scale deposits are preventing the thermostat doing a good job.
Aug 03, 2016 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Our freezer defrosted and nearly cooked all its contents. We have a service man looking at it now and he can't figure out what the REC it displays means. It appears the unit is in reverse mode! Help?
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Aug 12, 2011 | Hoshizaki Commercial Freezer SafeTemp®...
I have a toyostove laser 30 kerosine heater which was displaying an EE 8 message, a repairman came and replaced the blower moto, and it started running agina, but now is showing an EE 13 message which the...
EE13 is for the burner thermister, not the thermostat. It prevents the burner from overheating. It does not reset after it has opened an will need to be replaced. Perform a resistance check on the thermistor. It should be less than 200k ohms after preheating. If it isn't, replace the thermistor. If it is the problem could be the circuit board. Hope this helps. Let me know if you need more assistance. nitensheaterservice@earthlink.net
Oct 26, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Power to refrig. Front displays show temp for freezer (0) and refrig.(37). Fan running by coils. Neither will cool. Also the compressor is hot but no humming or other noise
DEFROST PROBLEM
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
Aug 04, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Defrosting daily
It is normal to defrost every day for 20 minutes or so but the defrost thermostat prevents it from getting too warm.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
Nov 16, 2009 | GE Profile PSH25MGS Side by Side...
Not enough heat in winter
two things..make sure your cooling system is totally full and bled with the heater on.  Also your thermostat may be stuck open.  A flush before you change the thermostat wouldn't hurt.
Apr 03, 2009 | 1996 Dodge Caravan
Heater does not blow hot air
you might need to change the thermostat.. when the thermostat isn't working correctly it prevents the hot engine coolant to circulate and give you heat.
Mar 01, 2009 | 1994 GMC Yukon
-AC appears in the display of chronotherm III
I have had the same problem- twice. It was a similar but different problem each time. The -AC means the ac control voltage isnt making it to the thermostat. In my case both times it was a switch in the control circuit that wasn't closing properly. The easiest was the front cover switch. If the front cover is removed from the furnace or has vibrated loose, the switch will open, preventing the furnace from running. The other instance I ran into was a flow switch on the exhaust blower which ensures the there is flow OUT the chimney. The switch wasn't functioning, so the furnace wouldn't start. The blower would come on for a short time, but the burners wouldn't light.
Hope this helps,
Dec 12, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
178 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
