Question about GE Profile Spectra JGBP90 Gas Kitchen Range
I'm curious to know whether the oven igniter coil glows continuosly during operation or if it shuts down until next on cycle?
    Problem Solver:
  • 15 Answers
Yes in most ovens the glow bar igniter will glow all the time.
Posted on Apr 09, 2011
Oven shuts down after few minutes
SAME CONCEPT FOR OVENS ::
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Aug 28, 2014 | GE Profile JTP18 Electric Single Oven
The oven does not stay an even temperature and there is a gas smell. The broiler works fine! Only the oven....
By the parts diagram, it looks like you have a glow coil type igniter . Generally when the oven wont keep temperature, the igniter is failing to reignite the burner. The burner comes on till it reaches temp then shuts off until the temp falls below a certain temp then comes back on until it reaches temp again and so on and so forth. Most of the time the igniter has a very small crack in it and doesn't begin to fail until it cycles several times. I would check the igniter and the safety valves and coils on the valve
Dec 15, 2009 | Whirlpool Kitchen Ranges
Dryer starts with heat. After 10-15 minutes, when dryer calls for more heat, here a metal clicking noise, flame does not ignite. When it's clicking, I can look down the back from the top and see a glow....
Your gas valve coils are defective. Part #694539 and 694540 are required. Once the coils get hot they collapse internally and the gas valve shuts off. This is a common problem when valve coils get weak from use.
Nov 09, 2009 | Whirlpool LGQ9857L Gas Dryer
Oven will not relight during cooking cycle
When the bake igniter becomes weak or burns out, your oven would not bake properly. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
-- defective gas valve coils
Oct 20, 2009 | Whirlpool SB160PEE Gas Single Oven
I own a GE JGBP33BEH5BB and the oven doesn't get hot enough. I've changed the sensor with one from a JGBP30BEA1WH that was working fine when it was removed. (replacements for both are the same part number...
The orange glow is the igniter. Normally, the igniter turns on and begins to glow. As the igniter heats, the change in it's resistance causes it to use more electrical current (amperage). When the amperage level reaches a threshold (let's say 3.2 amps, for an example) the ovens safety gas valve will open because in knows the igniter (using that much electrical current) is hot enough to light the gas. This process usually takes under two minutes. The igniter stays on until the oven reaches the set temp, then it turns off, and the gas valve shuts off very soon after. Then the cycle repeats when the oven thermostat call for heat again after cooling down a bit.
The trouble is, as these igniters get old, they have a harder time reaching that needed amperage threshold to operate properly. You can just swap the broiler igniter with the bake igniter if you wish, as they are the same part number in your model, and the broil is generally used much less, and so should have much more life left. (of course now the broiler and the self clean will not work, until you replace the broiler igniter with a new one.) In rare cases, if you have low line voltage to the range (say 108 volts) that will also cause the same problem, or if you have a poor electrical connection, but those cases are rare, and about 99 percent of the time your problem will be fixed by replacing the oven igniter. (GE part number WB2X9154 for your model)
Sorry to get so long winded. Just replace the oven igniter.
Aug 15, 2009 | GE JGBP33 Gas Kitchen Range
Burner comes on for 30 secs or so and shuts off. Ignitor cycles
it sounds like the gas valve solenoids are shorting out. there are two coils that operate in tandem to allow gas flow. these coils can eventually overheat and cause the gas not to flow as well have a rattling sound from the plunger inside the coil trying to move inside the weakened coil. the coils can be replaced and will come in a pair with guide pins to help you put them in correctly. one coil will have three wires going to it and the other coil will have two wires going to it. pretty simple fix and should solve the problem
hope this helps....jay
Mar 06, 2009 | Whirlpool LEQ9858P Electric Dryer
Glow plug on oven
Yes. Igniter stays on from just before ignition until just prior to burner shut down with each burn cycle.
Nov 12, 2008 | Tappan 30IN ELEC IGNa Oven
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
43 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
