Question about Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch
I need to know what the black hose is for on the back of the refrigerator that runs from the bottom left corner to the top right corner.
  • 415 Answers
It would be the fill tube for the icemaker. some frig's are setup for this even though they don't have any icemaker.
Posted on Apr 09, 2011
Keep on getting the code 1080i at the right hand side top corner.
Hisense FAQs
www.hisense-usa.com/support/faq.asp
Hisense... Wine Cabinets. Laundry. Washers. Frequently Asked Questions Get answers to the most common questions. ...... Universal Remote Codes. Universal Remote.Missing: hand
[PDF]Hisense Roku TV User Manual
hisense-usa.com/support/manuals/40H4C_us_M_en_man.pdf
Hisense(black bars at top and bottom of screen); or viewing normal style (4:3) media on a widescreen (16:9) display (black bars on left and right sides of screen). ix ...Missing: 1080i
I have some informational text in the top-left corner... [META ...
https://www.reddit.com/.../i_have_some_informational_text_in_th...
RedditDec 25, 2014 - /r/Cordcutting - Cutting the cord, but keeping it legal. ... I have some informational text in the top-left corner. ... saw this problem on my moms roku. didnt know how to get rid of it. came ... Clicking the right stick will toggle that display on and off if that .... 06:26:06.164191+00:00 running cb0da57 country code: US.Missing: 1080i
What router settings do I need to set up Chromecast? - Google ...
productforums.google.com/d/topic/chromecast/ZGm4p8VcpAU
Google
Jan 05, 2016 | Hisense Televison & Video
Water is freezing in the bottom drawer GEProfile bottom drawer freezer and leaking water on floor
Sounds like your drain tube is blocked in the freezer for the defrost water. The drain tube is in the back left or right corner and will have a drain trough under the cooling coils tilting towards it. That trough will probably have ice built up all over it. Once the ice is out you may need to force hot water down the drain tube. I use to use a turkey baster with a rubber hose on it to force the hot water down the drain tube. Its clear when you put water in the trough top and it goes down the tube freely to the drain pan under the refrigerator.
Feb 28, 2015 | GE Profile PDS22MHR Bottom Freezer...
How do I fix a refrigerator that won't cool?
if you are sure the evap fans are running (the ones inside) then only 2 things left.... 1- there is ice build up around the evaporators blocking air flow..... 2- the unit is out of freon.... I really suspect that there is ice around evap, samsung's are not known for having freon leaks.....I would unplug unit for 24-48 hours, then remove ff shelving, then take 2 screws out,(located on the bottom left and right of the evap cover and the one that is behind a plastic plug located in the center about 2/3 of the way to the top of the cover....once you remove the screws, grasp the cover on the bottom right corner and gently pull out to remove cover, being careful not to break the foam that channels air..... once removed check to see where the ice is left.... usually in the top right corner, if so replace the sensor located there... Ken Hawk
Feb 21, 2015 | Samsung RF217ACRS Bottom Freezer French...
I need wiring diagram for Belle 150 cement mixer 110v
Small BLUE at top right hand corner, then the two rows of two...
top left is BLACK, top right is GREY, bottom left is BLUE from the power supply and bottom right is a short BROWN wire with a spur, which leaves a BLUE to connect to the spur. should be it :)
Oct 09, 2010 | Garden
Galaxy dx99v, bad squeal when I key the mic
Your microphone wires may be shorted take the mic plug apart (small screws) Now check for frayed wires touching or twisted together!
With the wires being resolderd or taped apart put back together
with the U pointing downward you shout have :
Right corner bottom Sheild ground!
Left corner bottom Black recive
Right corner top White or yellow this is Audio wire
Left corner top RED Transmit or PTT wire
If wiring looks good the problem is in the Mic take to servicer!
May 09, 2010 | Galaxy Radios DX-99V 40-Channels Base CB...
How do I wire the suoco 3 in 1 start in an amana refrigerator where do I connect for the power.
Good day,
Once all the original start components were removed from the compressor, there should be two wires That run back into the compartment that are your power source.
Those 2 wires go to the two black wires that are shown on the 3 and 1. Doesn't matter on those two which goes where.
You should have 3 wires left that are grouped together.
1.White goes to the bottom left.
2. Red goes to the bottom right
3. Black goes to the center top.
Dec 13, 2009 | Refrigerators
Need pinout for Alpine CDA-7940 head unit
facing the back of the 7940 the top left corner is pin 16 the top right corner is pin 9. The bottom left is pin 8 and the bottom right is pin 1. Only a few of the 16 pins are used due to this unit only having pre-outs, no internal amplifier on this unit. Pin 1 red (ignition), Pin 2 pink/black (interrupt), Pin 3 orange (Illumination), Pin 8 black (ground), Pin 9 blue (power antenna), Pin 10 blue/white (remote turn on), Pin 16 yellow (battery).
Feb 21, 2009 | Alpine CDA-7940
GE Monogram leaking water on right side bottom door
If this refrigerator has a Energy Saver mode, turn it on.
Then, check the door gasket for the refrigerator to make sure it's not leaking. Test by placing a crisp dollar bill on the door jamb with the door open, close the door, and you should feel resistance to pulling the dollar out. Check with particular emphasis on the place where you see water leaking or accumulating
Jan 24, 2009 | GE Monogram ZDI15C Automatic Icemaker
Kenmore ice maker
yes you need to hook up a line froun the cold water supply of the house to the water valve that is located at the back of the ref to the water valve that is down at the botton right corner
follow the water line from the top going into the icemaker down to the bottom there is where the valve is located behind the back cover
Apr 11, 2008 | Refrigerators
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Logo
59 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
