Question about Polaroid a540 Digital Camera
My polaroid camera wont turn on when i press the power button
  • 96 Answers
Please check the battery first if it has energy by using multitester connecting its positive and negative to test whether there are energies inside and if none pls try to charge if it can charge try to use other batter for isolation if using the new battery then it still the same something wrong with your power supply.
Posted on Apr 09, 2011
How to change the iso on my polaroid t1031 camera
To change the ISO on your Polaroid t1031, please do the following:
  1. Turn your camera on
  2. Press the FUNC (Function) button (right button on bottom right of device next to the LCD)
  3. Use the Up/Down, Left/Right buttons to move through the menu.
  4. Scroll down to the option that reads ISO AUTO and press the SET button (located in the middle of the arrow buttons) to bring up the different ISO options available to you (see Fig 1 below)
  5. Use the arrow keys to navigate the different ISO options and press the SET button to confirm your selection.
  6. If the menu does not close on its own after making your selection, press the FUNC button to close.
  7. Thats it! Your ISO setting has been changed.
Fig 1
Mar 14, 2011 | Polaroid t1031 Digital Camera
I have an auto flash, but it's not flashing. Do I need to somehow turn this function on? If so, where is it?
Follow below mentioned steps to turn flash on:-
  • Rotate MODE DIAL to any one of them Auto, program, portrait, landscape, sport or night mode.
  • Press POWER button to turn power ON.
  • Press Navigation button (left arrow button), Flash mode change each time button is pressed. you can use UP and Down Arrow button to change settings. Set it to FLASH ON.
  • Press OK to confirm settings.
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
Feb 13, 2011 | Polaroid i936 Digital Camera
When i turn on my fuji polaroid cam, there is an "E" error message. I can't take any polaroid pictures with it altho the polaroid cam is loaded with film. Please help. Thanks
First, remove the remaining films from the camera. (while your camera is switched off) Second, press on both the shutter button and the power button at the same time. (to reset) Third, reload a new set of polaroid films into the camera.
Hope it helps!
Dec 26, 2010 | Fuji instax mini 7S Film Camera
Cannot find batteries that work. I have replaced the batteries with different brands and it still wont turn on. What is the problem.... Its not reliable.
It is possible that there is a small amount of corrosion on the contacts in the camera. Use the eraser end of a common pencil to clean these contacts. Also, make sure you are using the correct batteries. It shows here that you have the polaroid i830. this camera uses two AA batteries: Open the battery door, located on the underside of the camera (use your thumb to slide the door outwards). Install the two AA batteries into the battery bay. Install the SD card into the slot located next to the battery bay. Close the battery door.
  1. Step2Press the power button located on top of the camera. Locate the "Playback" button on the rear of the camera, under the "W" button; this button switches the camera between "Capture" and "Playback" modes. Set the camera to "Capture" mode.
  2. Step3Press the button on the bottom right of the rear of the camera to open the mode selection window. Use the navigation buttons to select "Still Image" mode. Press the button labeled "Set Disp" to confirm your selection.
Nov 02, 2009 | Polaroid i830 Digital Camera
My Polaroid camera i631 won't turn on!!
Here is the solution for your problem. If you look at your camera at an angle, you will see the zoom lens is little bent to the side. I want you to put press on it to snap-it into it's place. After you heard a click, then turn-on your camera. This will fix your cam.
Vicent
Apr 04, 2009 | Polaroid i631 Digital Camera
Dropped camera
lens wont move in or out beeps thrre times and shuts off i want to fix it or you give me anther
Oct 02, 2008 | Polaroid i531 Digital Camera
Polaroid i735 Camera won't turn on. Lens stuck.
I had the same problem, and fixed it by wiggling the lens a little, when turning it on.
After a few tries, it finally wiggled free, and the lens retracted.
Jul 05, 2008 | Polaroid I533P Digital Camera
Polaroid PDC 5080
if you don't use it (press a button, take a pic., take a video, etc.) then it will turn off because say you put it in the case and forgot to turn it off, then it won't stay on and waste the battery.
Jan 30, 2008 | Polaroid PDC 5080 Digital Camera
Polaroid a540 Digital Camera Logo
195 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
