Question about Dishwashers
Will not drain. I have checked the drain hose for blockages, nothing there. I pulled the drain hose from the pump and the dirty water flowed out.
    Guru:
  • 500 Answers
Drain pump not working anymore. Depending on your make & model there are a few ways to acces the drain pump, but most common practice is removing the Top Panel (fastened by 2 screws at the back) and then the side panels. A normal Dishwasher should be attached to the sump.
Replace it and all should be fine, the reason why dirty water is coming out when you remove the hose is called a Siphoning effect. The dirty water is what your drain pump can not push out of the dishwasher.
Kind Regards :-)
* If you found this solution helpful, please rate 4 thumbs up and leave a small testimonial. :-)
Posted on Apr 09, 2011
My 17kg whirlpool x-pert is not spin drying
Is it emptying the water quickly enough? A blockage, or partial blockage on drain will prevent the spin starting quickly, and you only have a limited time on spin before the program stops.
Carefully remove and clean any filters if fitted on the drain - you must do this and don't assume they are clear. If ok, check the connections at the waste hose on the sink or plumbing, and in the waste hosepipe. Can you hear the drain pump running on the drain only cycle? a glug glug glug noise.... if you cant hear the pump it may be seized or jammed with a coin or button or pin or bra wire or zip etc etc.
If no waste water is flowing, try lowering the waste pipe on to the floor completely flat - water should flow out under gravity. If it doesn't, there may be a blockage in the machine sump hose - a sock or pants, etc.
Check all the basics first - water fill, water drain, filter clear, drain water flowing etc.... if all ok, may be motor or control card.
Dec 28, 2017 | Whirlpool Washing Machines
Clothes coming out soaking wet
put it in the spin cycle and if nothing is coming out the drain hose it is most likely the drain pump ....just a fyi some are easier than others to replace.
I don't see the make and model of this machine so to give you specifics I can't. just general directions.
also I would check under the dasher there is a screen under there if you wash DIRTY clothes and maybe add a case of dog/cat hair it could be restricting the flow but wouldn't stop it totally.
also another fyi if you do get to that point use a toothbrush to clean it as you don't want to poke any holes in it.
Hope this helps.
Jan 20, 2015 | Dishwashers
Washer not draining
First is machine spinning? machine only drains in spin mode.
If machine not spinning check lid is closed and check lid switch and plastic plunger that operates the switch located on the lid.
If machine is spinning then most likely a blockage on the drain hoses or pump. if there is water in the machine, lower the rear drain hose to low level, if water starts to flow out the hoses are not blocked, more likely a pump failure. To replace pump first drain all water from the machine with drain hose at low level.
Tilt machine back and remove the belt from below.
Remove the front panel.
To gain access and remove front panel insert a knife or thin blade approx. 4" in the from each side in between the front seam on the front panel, this will release the lid clips, lift and hinge back the lid panel, remove the two screws securing the front panel and remove.
Pump on right hand side at the back, disconnect main hose from pump by squeezing hose clip with pliers (may be a bit of water remaining). Unbolt pump and pull forward with the drain hose attached until it can be disconnected and pump fully removed.
Check pump for blockage and damage to impellor, replace/refit in reverse order.
Nov 23, 2013 | Admiral AW22 Top Load Washer
Water did not drain from the bottom
Hello Cheryl, There are a couple of possibilities. When the dishwasher drains the dirty water it is a time based function. This leads me to believe it is a blockage or partial blockage in the drain hose.
Here is an example. (If your dishwasher drains into your garbage disposal) washing dishes you put scraps into the disposal and forget to turn it on after you are done. The disposal is filled with scraps this restricts the flow of dirty waterfrom the dishwasher. If the flow is restricted less water is being drained per second from the dishwasher. This is why the dishes still looked clean and there was still water in the bottom of the dishwasher.
(if your dishwasher drains into a drain pipe) there is blockage or partial blockagein the dishwasher drain hose. if the sink drains slowly the blockage is in the main line
Hope this helps
Joe Connolly
Nov 02, 2011 | Frigidaire Dishwashers
Error 03 not draining or going to spin cycle. Tub is full of water. I followed all the steps to drain and clean the hoses, pump, and the pump trap is clear and vanes spin fine. Nothing seems to be...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the blockage is in your plumbing and not in the machine.
Pl rate me ‘very helpful’ for the free help!
Jun 14, 2010 | Bosch WFK 2401
The spine cycle seem slow need to run more then once
check the tub to pump and pump to drain for blockages of debris,the pump should drain the bulk of the water,then it should spin out the rest unless the belt is that glazed,get to the spin cycle and pull out the washer drain hose out of the house drain stand pipe and see how much force water is while being pumped out while just pumping and not spinning,there should be the water stream the size of the inside of the drain hose and good velocity of water flow to the drain
Mar 13, 2010 | Kenmore 88752 Top Load Stacked Washer /...
Bosch wfr2460
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Dec 01, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Hotpoint wd860 code f20
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 23, 2009 | Washing Machines
E20 error on Kenmore front loader. The water is
Jun 07, 2009 | Kenmore 44072 Front Load Washer
Mywashing machine getting E2 display
E2 is an error code for drainage failure.
Jan 28, 2009 | Washing Machines
Dishwashers Logo
61 people viewed this question
Top Dishwashers Experts
