Question about Maytag Dryers
I have model MDE6000AYW maytag dryer. The bell that sounds at the end of the cycle repeatedly goes off during the entire cycle. How do I solve the problem?
  • 4 Answers
SOURCE: DLE5955 Tromm Dryer. We have had
Sounds like your outside vent is plugging up. Go outside your house and check for lint build up and just pull it loose with your fingers or a shop vac.
If it's not obviously plugged from outside, feel the volume it should be significant. If it's very weak (while running of course) your ductwork may be plugged elsewhere, for example at an elbow, or the joint between a flex hose and the actual duct.
Posted on Jun 26, 2008
WRMtech
  • 70 Answers
SOURCE: during the drying cycle, the dryer door opens
Chances are the little plastic latch keep is broken. Look at the door and locate a peice that will press into the front area where the clothes go in.
Once you see it, check the keeper and see if it is broken. The door should not just pop open.
Posted on Feb 26, 2009
  • 1632 Answers
SOURCE: squeaks and sqeals during dry cycle
Lubricate the contact points, pulleys , change the felt seal .
Get a new dryer, abot time?
Vitally
Posted on May 15, 2009
GM Elec
  • 1000 Answers
SOURCE: Squeeky dryer
Typically what happens is over time the back drum supports wear out. Once they have worn thin the drum rides on the bare metal portion of the support and you get the "annoying" speek sound. Or if the supports are the roller bearing type, the bearing fails and it generates the noise.
Anyway, the supports or rollers are inexpensive to replace and not very difficult.
If you want to tackle the problem, let me know.
Good luck.
Regards,
Posted on Jun 22, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Maytag neptune dryer has a very loud squeaking
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Posted on Jan 01, 2010
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
How do I turn on bell on my dryer
From the Whirlpool user manual:
(OPTIONAL) Your dryer may have an End Of Cycle Signal. The
signal is helpful when drying items that should be removed
from the dryer as soon as it stops.
On some models, the End of Cycle Signal is fixed.
On other models, the End of Cycle signal is part of the
Start button and is selectable. Turn the PUSH TO START
button to ON or OFF. The signal will sound only if the
selector is set to On.
Jan 22, 2016 | Dryers
Maytag dryer model number LDE840ACE squeaks during the drying cycle
That is probably a Wheel. More likely the wheel over the heater. I recently worked on one of these and posted a pictorial:
My Maytag dryer repairs
Jun 20, 2012 | Maytag Dryers
I have a MAYTAG MDE6000AYW Series Dryer. It does not heat up, it makes no noise, tumbles, and the lights work, what can I do to solve the no heating problem with the dryer?
the heating coil needs fixing you can fix it yourself but try a repair man first allot of them come too your home and fix them so choose your repair guy wisely...
Apr 12, 2011 | Maytag MDE6000 Dryer
Inteli dry regular cycle, timer gets stuck and won't advance. other cycles work fine. thanks
An unusual noise coming from a running clothes dryer can cause concern, although these noises are rarely indicative of a more serious problem. Once the source of the noise has been located, a few simple repairs or adjustments will usually solve the problem and restore peace to your laundry room.
    Gas
  1. A gas dryer may emit an occasional clicking sound. This noise is caused by the gas valve and is a normal operating sound. The clicking sound coming from the gas valve can not be eliminated and it does not indicate any mechanical problem with the dryer.
  2. Warm Up
  3. A newly installed dryer, or a dryer that has been left unused for a period of time, may exhibit a thumping noise during the first few minutes of the drying cycle. According to the Maytag company, this noise is normal and should not be a cause for concern. If the noise continues for more than a few minutes or repeats on subsequent loads, however, then steps should be taken to locate the origin of the noise.
  4. Clothing
  5. Clothing can become knotted and balled up in the clothes dryer. This can cause vibration or a load thumping noise. When this happens, open the dryer and remove the knotted clothing. Separate the articles of clothing and place them back in the dryer. The thumping noise should not continue unless the clothing has become knotted again.
  6. Vibration
  7. Place your hands on top of the dryer and push down firmly; if the dryer tilts to one side, the clothes dryer is not level. This can cause the dryer to vibrate during the cycle and if the vibration is severe enough, the surrounding walls could be damaged by the dryer. Maytag dryers have four leveling legs installed into holes on the bottom of the dryer. These legs are included with the dryer and should have been screwed into the holes during installation. A wrench can be used to adjust the legs until the dryer is stable and level.
  8. Foreign Objects
  9. Small objects such as coins, buttons, or paperclips can become lodged between the drum and the sides of the clothes dryer. These items usually end up in the dryer after being left in clothing pockets during laundering. Turn the dryer off and remove any clothes to a laundry basket. Allow the dryer to cool down so that you won't burn your hand on any metal surfaces inside the dryer which may be hot. Look inside the dryer and pay special attention to the front and rear edges of the dryer drum. Run your fingers along the grooves where the drum connects to the dryer to locate any foreign objects. These objects could be bouncing around the dryer causing noise during the cycle, and then settling into the grooves when the dryer stops making them difficult to locate. Remember to remove all items from clothing pockets before laundering in the future to avoid this problem.
  10. please comment on these solution on how helpful
Dec 30, 2010 | Maytag SDE5401AYW Electric Dryer
Maytag neptune mdg4000aww squeaking during entire drying cycle. Could not find a repair manual on the net
Look here at part #24...
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46720&diagram_id=660607#d660607
The notes for part #24 give you the other parts and help that you will need to stop the squeek. The drum rollers or the front bearing is the problem.
While you have it apart repalce it all.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 07, 2009 | Maytag Dryers
Maytag neptune dryer is overheating mde6000ayw
With a name like Sexydiva69 I'd overheat too! Sounds like your exhaust hose might be clogged. Take it off and make sure you don't have excessive lint buildup anywhere in exhaust system.
Jul 26, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Bell rings in Maytag Dryer
Many newer models have a wrinkle guard setting. They will buzz or ring or chirp with some sound to let you know to remove the clothes before the wrinkles can set in. Usually for 5 min or so near the end of the cycle.
Eric
Jun 10, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Squeelling
It sounds like your belt is starting to go out. You might google the repair forums or check this site out. http://fixitnow.com/2003/11/appliance-tip-of-day-dryer-disassembly.htm
Oct 29, 2008 | Dryers
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
