Question about Carrier 38CKC036 Air Conditioner
MY inside fan is making a loud noise like it is rubing/vibrating and then at times runs quite
    Genius:
  • Carrier Master
  • 1,033 Answers
Hello, make sure the blower wheel is clean and that it is moving freely, if it feels loose on the motor shaft then you will need to tighten the set screws. If the the blower wheel is hard to turn then the bearings on the motor are going bad and will need to be replaced. I hope some of these tips help.
Posted on Apr 09, 2011
My fridge started getting really loud when it cycles on, and seems to have a vibration when running
If it ismaking a steady noise, the motor that runs the defrost timer may be making noise. I f the timer motor is making a loud noise, then you should replace the timer.Vibration noises are often caused by dishes or containers vibrate on a shelf inside.
Sep 16, 2013 | Refrigerators
WHEN EVER THE MACHINE IS RUNNING, ESPECIALLY DURING THE SPIN CYLE, THE WASING MACHINE MAKE A VERY LOUD NOISE AS IT ROTATES. IT ALL MOST SOUNDS LIKE IT RUBING AGAINST SOMETHING. ANY...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 18, 2010 | Washing Machines
MY unit has become increasing noisy and the fan is the mane cause. The fan is now making different noises at differing levels high and low of loudness, and it often quits running all togetger. It is also...
It sounds like the bearings in the motor are worn out, especially as you said it quits running at times. You should be safe in just replacing the fan motor, but check the fan blade to make sure it isn't out of balance for any reason(dirty, missing a balance weight, or bent). Hope I was of assistence!
Nov 14, 2009 | Kenmore 53701 Dehumidifier
GE top freezer refrigerator: motor has become very loud and refrigerator vibrates. However, when I move the cold control to a lower number, it gets slightly quieter and vibrates slightly less.
Please make sure it is level, the compressor is designed to run on level ground. Also check the fans. if the fan is bad or the bearings are shot, it'll vibrate and make a loud humming noise.
Find out where the noise is loudest. if it's under the fridge, it's the compressor.You have to check the coil for the compressor and if it's inside the freezer, it's the fan bearing.
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Oct 20, 2009 | Refrigerators
Refrigerator runs way too much.
make sure it is level. the compressor is designed to run on level ground. also check the fans. if the fan is bad or the bearings are shot, it'll vibrate and make a loud humming noise. find out where the noise is loudest. if it's under the fridge, it's the compressor. if it's inside the freezer, it's the fan.
Aug 28, 2009 | Refrigerators
Refrigerator Compressor has loud vibration
Clean the coils. what you are hearing is the valves as the pressure equqlizes. Also make sure that the fan by compressor is on while compressor is running.
Mar 28, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
When car is running and fan comes on
Sonds like the fan to me. Yes, those are available separately. Water pump is internal inside of the timing cover and those are pretty bullet proof. Fan is most likely NG. Not that common. I have replaced only 1 in 12 years with Nissan.
Sep 28, 2008 | 2000 Nissan Maxima
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
HELP HL-R5067W LOUD GRINDING/VIBRATING NOISE
noise you are hearing can be the fans inside with bad bearings and or what im assuming given the info you gave.More likely the motor inside the optics engine (color wheel) is making noise..This will also cause picture problems..very expensive to repair..
Dec 13, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Carrier 38CKC036 Air Conditioner Logo
201 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
