Question about Health & Beauty
Do not know how to use the heat feature - Health & Beauty
    Problem Solver:
  • 8 Answers
Do not know what you are referring to.
Posted on Apr 10, 2011
I've done self clean twice and both times the broiler feature had to replaced after cleaning
then knowing why do you still use the self clean feature .apparently some part is not able to withstand that kind of heat
Feb 23, 2016 | Kitchen Ranges
Tip
The Honeywell TH811U1003 thermostat is a universal programmable thermostat that...
The Honeywell TH811U1003 thermostat is a universal programmable thermostat that gives you electronic control of 24V AC heating and cooling systems. It also has the capability to be used on 750mV heating systems
One of the best features of this thermostat is it’s big clear backlit display. The current temperature, the set temperature and the time of day are displayed at all times. Simply touching the screen also activates the back light feature.
This thermostat has a menu programming guide the helps you through the process of setting up your schedule. You are able to select multiple days and customize the thermostat for any kind of unique schedule you may have. This thermostat also let’s you take it off the wall and still be able to program it. This lets you watch TV and program it at the same time.
There are built in backups that will hold the time for you if the power goes out. This t-stat will also update for daylight savings time. There are HOLD features that allow you to modify your program and hold it and then go back to the original.
Change reminders that are built in include the air filter, UV light, humidifier service and of course the batteries of the thermostat. The blower of you furnace can also be programmed to run extra to help increase the air quality in your home.
If you decide you want to know the outdoor temperature you can purchase an additional sensor and then hook it to you thermostat. The outdoor temperature will then be displayed on you thermostat. This feature also gives you the capability of using the sensor to monitor indoor temperatures remotely.
This thermostat will keep you very comfortable as the variation typically in temperature from set point is less than 1 degree F. The thermostat after a period of time learns the characterizes of the way the house or building heats and cools and then adjusts to get the most efficient operation of the heating or cooling system while maintaining a very close temperature tolerance.
By changing a few of the parameters in the thermostat this can be can be configured for either single stage conventional heat/cool systems or any single stage heat pump system.
Specifications of the Honeywell TH8110U1003 Thermostat
  • Description: VisionPRO Touchscreen 7-Day Programmable 1 Heat/1 Cool
  • Conventional and Heat Pump Thermostat
  • Application: Gas, Oil or Electric; Heat Pump; Millivolt
  • Programmability: Universal Programming from 7 Day to Non-Programmable
  • Changeover: Auto or Manual
  • Color: Premier White
  • User Interface: Touchscreen
  • Switch Positions (System): HEAT-OFF-COOL-AUTO
  • Switch Positions (Fan): AUTO-ON
  • Power Method: Battery or Hardwired
  • Terminal Designations: R, RC, C, W (O/B), Y, G, S1, S2
  • Dimensions (in.): 4 9/16 in. high x 6 in. wide x 1 1/4 in. deep
  • Mounting: Horizontal
  • Electrical Ratings: 20 to 30 Vac
  • Frequency: 60 Hz. 50 Hz
  • Setting Temperature Range (F): Heat: 40ª F to 90ª F. Cool: 50ª F to 99ª F
  • Setting Temperature Range (C): Heat: 4.5ª C to 32ª C. Cool: 10ª C to 37ª C
  • Differential Temperature (F): 1ª F
  • Differential Temperature (C): 0.5ª C
  • Stages: Up to 1 Heat/1 Cool
  • Outdoor Sensor: Yes, optional outdoor or indoor remote
  • Remote Sensor: Yes, optional outdoor or indoor remote
  • Sensor Element: Thermistor
  • Currents (Heating): 1.0 A running
  • Currents (Cooling): 1.0 A running
  • Currents (Fan): 0.6A running
  • Operating Humidity Range (% RH): 5 to 90% RH, non-condensing
  • Comments: Selectable to and Heat Only or Cool Only
  • Features: Screen lock
on Jan 15, 2010 | Hardware & Accessories
Tip
Th811u1003
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Specifications of the Honeywell TH8110U1003 Thermostat
on Jan 15, 2010 | Heating & Cooling
How do you use proofed feature
If I understand correctly Carol, you want to know about the 'prove' feature on your oven?
In bread making the proving part of the process is where low heat is makes the bread dough rise. It is a barely warm setting just about blood heat. It makes the yeast release carbon dioxide bubbles which makes the bread rise.
Nov 18, 2015 | GE PB910TPCC Profile Freestanding Electric...
My kenmore series dryer does not heat. the timer
the heater element has two parts to the heat coil if one of the coils breaks it will not get hot enough to heat the load all the way to set of the sensor to stop . it seems like you need to replace your heat element . if you want to know how to take it apart i have a couple of posts that tell how or reply back the coil costs about 89 dollars you can get one pre strung for around double the cost
Feb 25, 2010 | Kenmore 63942 Dryer
How do you get it to unlock
If the model number you have this listed under is correct, the locking feature can be turned on/off by holding the Heated Dry button for 4 seconds. This is a safety feature that prevents unintended use of the dishwasher. This is usually meant to prevent small children from inadvertently turning the unit on.
If you have questions, please let me know. I hope this helps you.
Oct 28, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
I need to know how to replace a heating element in a dryer # DE306, Maytag
I like to give instructions w/videos because this is step by step Hope you like it, it will also help U to learn more about your dryer
http://www.youtube.com/watch?v=e6cMej-C1XQ&feature=related
video 2 http://www.youtube.com/watch?v=Y18dyl9Sm3o&feature=related video 3 http://www.youtube.com/watch?v=jDUXsc_vapQ&feature=related video 4 http://www.youtube.com/watch?v=RGohdlnBK7s&feature=related video 5 http://www.youtube.com/watch?v=Wd1OOYegkmA&feature=related
video 5 is the one you ask for I hope this was helpful for u
was this information helpful? please rate my service thank you
Aug 28, 2009 | Dryers
Rangetop works, Broiler works, oven does not.Electrics seem fine; Should I check the solenoid valve first?
For future reference, you need to explain whether this is a GAS or ELECTRIC range. It does make a difference in diagnosing the problem you have.
If this is a GAS range, the problem is more than likely a faulty igniter on the bake manifold. Since the bake feature gets used more often, it is common for the igniter to wear out faster. The following link explains how the igniters work and instructions on replacing one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
If this is an ELECTRIC range, the problem is more than likely a defective heating element for the bake feature. The same reason applies. Since the bake feature gets used more frequently, the elements wear out much quicker. The next link explains how to replace a heating element:
http://www.fixya.com/support/r469407-replacing_bake_or_broil_element_in
I don't know what solenoid you are asking about, but if this is in reference to a gas safety valve or regulator, you would have similar problems with the broil functions if the there was a gas flow problem. Since MOST ranges are fed from a common regulator, gas flow to all the features would be impacted.
Replacement parts can be purchased on line at appliancepartspros.com, pcappliancerepair.com, searspartsdirect.com or repairclinic.com. All these sites offer great service with competitive pricing, so shop around for the best price. If you have any questions, please let me know. I hope this helps you.
May 19, 2009 | Kitchen Ranges
Air conitioner turns on by itself
The GE Zoneline units have small DIP switches inside the unit where you can turn various functions on or off. The units have a feature called Heat Sentinel that turns the A/C on at a certain room temperature, even when the unit is turned off. It also has a Freeze Sentinel that turns the heat on automatically, even when the unit is turned off. You can turn off the heat and freeze Sentinel features with the DIP switches in the unit. There are other features you may want to turn off. Read the owner's manual and it will tell you where the switches are and which ones turn off the features. Hope this helps.
Sep 17, 2008 | GE Zoneline AZ55H07D Air Conditioner
Health & Beauty Logo
20 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
