Question about RCA P52926 52" Rear Projection Television
My tv bends in the middle,after you turn it on. can you tell me what the problem is?
  • RCA Master
  • 5,138 Answers
Replace STK730-010, Mounted up above the main chassis board is another board that has this Chip on it replace it,it will have PN on it.
Mats Electronics has them 1-800-628-1118
Posted on Apr 09, 2011
My picture is warped or bending in the middle
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 21, 2009 | Philips Magnavox 51MP392H Rear Projection...
Akai lct2701td, flat screen tv won't turn on.
Oh Dear. I had the same problem!! The Akai televisons are not well engineered-meaning that they tried to put too much in a little package. The problem is that the power supply is malfunctioning"supposedly". But I believe that the sad truth is that the whole motherboard is malfunctioning. I can suggest a few TEMPORARY solutions but they too are not guaranteed to work!
1. Bring the tv to a repair shop and tell them to check the power supply. If it is faulty -have it exchanged and it will work for <2 weeks.
2. Literally "bend" the television in multiple directions to find a sweet spot where the screen turns on.( wait for the diode tu tur green before doing this) this will slightly bend the motherboard in hopes of agitating it to turn the screen/bulbs on.
I am terribly sorry that you too have this ridiculous problem!!!!!! :-(
Good Luck!!! I am crossing my fingers for you!!
Jun 10, 2009 | Akai LCT2701TD Television
Chaz ''LCT42Z7TA 42in will not come on the red light lights up but the tv won t come on''
Oh Dear. I had the same problem!! The Akai televisons are not well engineered-meaning that they tried to put too much in a little package. The problem is that the power supply is malfunctioning"supposedly". But I believe that the sad truth is that the whole motherboard is malfunctioning. I can suggest a few TEMPORARY solutions but they too are not guaranteed to work! 1. Bring the tv to a repair shop and tell them to check the power supply. If it is faulty -have it exchanged and it will work for <2 weeks. 2. Literally "bend" the television in multiple directions to find a sweet spot where the screen turns on.( wait for the diode tu tur green before doing this) this will slightly bend the motherboard in hopes of agitating it to turn the screen/bulbs on. I am terribly sorry that you too have this ridiculous problem!!!!!! :-( Good Luck!!! I am crossing my fingers for you!!
Apr 13, 2009 | Akai LCT42Z7TA TV
Can not connect cable to TV
Well I have the same problem and I have been looking for an adapter for quite a while now and cant find anything... So i ended up cutting the end off my coax cable being careful not to strip off the outer wires( just like I was going to put a new end on it) leaving the middle wire about 1 1/4" long (enough to bend it in half) then I shoved the middle wire into the middle hole of the rf input and wrapped the outer silver wire around the outside and ran electrical tape around the whole thing so it wouldn't ground itself out and I'm picking up the channels perfectly. Hope this helps
Mar 16, 2009 | Televison & Video
Red line runs from middle of screen to right bottom and bends in middle
look the only thing u can do is have someone put the parts in for u the parts alone is 40-$ 60.00 and maybe $ 150 in labor that is all u should have to pay. that is what i would charge a customer to repair there tv set and it can be service right there in your home.i hope this helps marty
Oct 13, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Jensen TV
Perhpas the TV has a timer function that is turning it on at a certain time. Does it seem to occuring at the same time of night? check the TV settings for a timer.
The only other possibility is that the camper is losing AC power in the middle of the night, and when the power comes back on perhaps the TV is turning on.
However, i rather suspect the first problem...
I am a certified RV technician, so if you have other problems with your camper please let me know
Sep 05, 2008 | Televison & Video
Green on screen
try to do it inside the board.
there are some adjustments except brightness and focusing..
try if you can ...
regards,
Aug 10, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Panasonic PT-53WX53 fast horizontal scroll
Replace Ic7001 and Ic7002 the convergence amps in this unit. Both are STK392-110 Sanyo built Ic's and fairly inexpensive. If you're not at all sure how to replace these take it to a qualified shop. And when you're calling around shopping ask what they charge to replace the convergence amps in these units.
Also take the unit to them rather than pay the pickup and delivery charge, that will save a few bucks.
Have a great day!
Bill
Dec 07, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Black square in middle of TV
Turn off the closed caption on the TV set. Someone has turned on that feature. Good Luck
Jul 12, 2007 | Mitsubishi VS-60111 60" Rear Projection...
SONY KP-61HS30
When one or all the colors are bending severly, then the convergence circuit is not functioning correctly and must be repaired. Only one color bending means just the convergence ICs and all colors bending means convergence ICs and voltage supplies. Convergence issues are the most common problem with rear projection (w/picture tubes) televisions. The cure is replacing the convergence IC's. Sometimes the pico fuses need replaced as well. If you have the experience to use a soldering iron and a basic understanding of electronics, then, you may be able to do this job. If not then call a servicer in your area. Go to the Sony website, Sony.com, and you can locate one in your area.
Jan 07, 2007 | Sony KP-61HS30 TV
RCA P52926 52" Rear Projection Television Logo
29 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
