Question about Vacuums
My toast willl not pop up to retrieve it sits lower than the toaster
    President:
  • 1,273 Answers
I have the same problem with some breads. Mine is also set up for bagels, and the bread goes further into the toaster. When it pops up, it then drops back down just enough where I'm not about to stick my fingers into the darn thing......sound familiar? The only thing that I've found that helps is that, when the toast pops up, and then drops back down, I lift up on the lever that you push down to start the toast, and I can lift the toast up about an inch, and safely remove it. Try this, and see if it works for you.
Best regards, --W/D--
Posted on Apr 09, 2011
I am trying to repair a Sunbeam Model T-35 radiant control toaster. Everything is working but I can't seem to get the timer control (for setting light and dark) set correctly. Is there some...
I have/had a similar problem. Here's how I fixed it.
UNPLUG THE TOASTER
1. Clean the crumbs out throughly. I removed the bottom of the toaster (6 screws) to make sure all the debris was removed. Use a soft brush. Replace bottom and tighten screws. 2. Gently brush the sensor area in the 'one slice' slot with a soft brush. 3. Remove 'darker-lighter' knob. I gently pried mine off with a small screwdriver. 4. Plug toaster in. 5. Put a slice of your usual bread in the 'one slice' slot. 6. Watch it toast. 7. When 'done' to your liking slowly rotate the control counter clockwise using a small screwdriver until the toaster stops toasting. 8. Replace knob with the pointer at the mid point (up and down) to allow for minor adjustments.
Aug 18, 2011 | Sunbeam Vacuums
Oster toaster oven will not turn on
IS IT A TOASTER OR VACCUME?
Jul 28, 2011 | Vacuums
My toaster oven elements heat up pretty quickly and then go out for a few minutes and them come back on and keep doing that....toast doesn't get done because of it and tonight I tried to cook some hot...
You trouble is intermittent operation. Fix it by checking the thermostat and power button switch also the cord. Check it use a analog tester set to Rx1. All of that is test through continuity, so if there no fluctuation in the meter reading, there is defective parts. An intermittent part(s) operate sometimes good and sometimes bad. Check those parts carefully.
Good luck.
Jul 17, 2011 | Vacuums
I followed the trouble shooting advice for a Hoover steam vac that has non-spinning brushes. Turbine ordered and replaced. Female receptacle still is not spinning. What now?
There could be several reasons for this. Remember that the brushes will not turn unless the dirty water tank is in place. Also the handle must be released and tipped back. It is also possible that the rubber seal that the lower tank sits on is missing. If you look down into the motor area, there should be a large, round rubber seal that the lower tank sits on. Look for the round tube that protrudes from the bottom of the dirty water tank. This tube sits against the seal. If it is missing it will need replacement.
Jul 11, 2011 | Hoover SteamVac F5914-900 SpinScrub...
I cannot find the link to register my new convection toaster oven.
I would like to see if I could help you but, maybe I'm missing it, but I don't know what kind of toaster oven you have.
<a href="toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 15, 2011 | Vacuums
One side of toaste doesn,t heat.
You did not give any description of the toaster so if it is a basic two slice pop-up unit the following applies, the contact operated by the pop up mechanism may not be functioning. The other problem could be that the element on that side has a burnt out winding. You will need to remove the cover in either case - name sure that the toaster is unplugged when you do this
Jan 20, 2011 | Vacuums
I have Sunbeam 'Radiant Contol' TOASTERMATIC toaster. Must be 40 years old - and only recently stopped toasting. Is there anyone who might fix this - I think the radiant coils have burnt out. I live in...
There could a number of reasons why it has stopped working and depending on the problem it could be a simple fix but generally not. It is after all an old toaster as you realise. On the bottom is a model number AT-35 AT-40 or TA-J. It depends on what part is sentimental as the outside and ends and base can be transferred over to a working mechanism. I have a few of these toasters and think they are just great.
Sep 08, 2010 | Vacuums
Willl not vacuum up the water
Means the suction is clogged by carpet or other debris take apart and clean as necessary.
Apr 13, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I have an Aerus lux 7000 and there is something stuck in the hose. I've tried prying it out with a hanger and only succeeded in getting it further down the hose. Is there a way to get the handle off of the...
DON'T try a coat hanger again it could tear the sidewall of the hose. Never push and obstruction in a vac
You have a swivel handled hose. The handle will separate by removing several small screws buried under rubber buttons on the handle. The pieces, upper and lower, will separate and the handle willl slide forward off the hose itself.
Before doing so remove the filter of the vac and plug the hose into the blower below the filter. Try to blow out an obstruction. It is always easier to back out than force through as the handle is narrower than the those itself.
Oct 09, 2009 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
