Question about Nikon Optics
They haven't been used for several years and all the controls are very stiff. Optics and alignment are fine.
  • 24 Answers
This is the grease that has gone sticky what ever you do do not try to take them apart. i expect that the focus ring is the biggest problem or do you mean the width of the lenses to the width of your eyes, or is it the adjustable ring on the right eye adjuster or all of these things get back to me and i will see if i can help
Posted on Apr 09, 2011
Driver side windsheld washer not spraying
Check the pipe feed under the hood for any kinks in the line.
Remove the pipe feed carefully and using a high pressure airline, blow back in the reverse direction of the water, back down the washer jet. This fine washer jet is prone to becoming blocked. If you don't have a high pressure airline, then you will need something very fine and flexible, yet stiff enough that when you insert it down the washer jet holes, it can disturb any blockage down there. Although I haven't tried one, you might use a yard brush nylon brush filament.
Nov 04, 2012 | Cars & Trucks
Hi. there is an alignment problem with my canon pixma ip90 printer. I haven't used it for years and finally decided to take it out. changed the ink cartridges, and the alignment problem started. Please...
Go to Control panel. Click on Printer and Faxes. Right click on your printer icon. Click on Properties on the drop don menu. In the properties click on Maintenance Tab. Click on print-head alignment on the drop down menu/tab. Check the printed page after the alignment is completed. If not OK carry it on again till you get the right print.
Aug 20, 2011 | Canon PIXMA iP90 InkJet Printer
Remote control is messed up. car runs independently of control settings. won't stop. steering control doesn't respond. car worked fine when last used about two years ago. has been sitting in a...
Dear Jereed7,
Have you tried to change the batteries of the controller?
When you haven't used it for two years, then i would try that in the first place.
I hope I helped you with your problem.
With kind regards,
MisterN
Aug 10, 2011 | Nikko Toys
Not a clear picture
CRT projection televisions need periodic maintenance to maintain a clear picture. Typically, to maintain a sharp picture, they require cleaning and alignment every two or three years. If the television is being used in an environment where there is cigarette smoke or other smoke sources, the optics inside the television can become dirty and cause the picture to blur. Additionally, CRT focus and alignment wander over time, or physical CRT alignment can be knocked out if the set is bumped or dropped. All RCA CRT projection televisions have an "alignment" or "convergence" adjustment in their adjustment menus, which are fairly simple to use. The convergence feature is usually accessible from the main menu of the television. Check your User's Manual for the procedure to touch-up the convergence adjustment and see if you are able to achieve a sharper picture. If the optics in your set have not been cleaned for several years, or if it is in a smoky environment, the picture will be blurry and usually a brownish color, In any case, since the set is several years old at this point, it's likely due for a cleaning. This is best done by a technician, and mostly involves physical cleaning of internal lenses, the refractor mirror on the back of the chassis, and the back of the opaque display screen. An adjustment of CRT bias controls and individual CRT focus adjustments will bring further improvement in the image sharpness and clarity.
Jul 08, 2011 | RCA Televison & Video
I have a nigh owl optics night vision monocular. I bought it about 10 years ago . It has two buttons. One is the "On" button. The other is the IR LED. Both the red and the green lights are lit....
Ten year sounds fine. You got ten years out of Russian manufacture NV monocular, even though it has Night Owl Logo on it. Send to me, I new some parts. I can get the gen 1 Russian image intensfier tube, or you can sen to Night Owl Optics in El Paso, TX.
Some of use think we know what we are doing with NV but without parts or even schematic for them we are sometime not ability to fix these NV devises. I have a couple of suppliers that will provide some image intensifier tubes; of course, on American image tubes all American Citzens can buy them but they are really expensive. The ccfl inver, control board, and even the voltage multiplier needs to be manufactured.
Do what ever you think is right, call Night Owl and see what the charges. stewbison
Feb 14, 2011 | Night Owl Optics Optics
I purchased the Wagner power tex and loved it, recently it doesn?t spray with the ease as it did when I bought, I haven?t used it a lot only to do fill in?s, seems like it only releases the texture once...
Your sprayer is self powered? you don't use a separate compressor? I have one with a compressor and it has to be taken apart " the gun" everytime or the trigger becomes stiff. If it's self powered, I would say your mixture is too stiff and water and it should be fine..If not and if it's self powered, then your motor may not work properly.
Mar 17, 2010 | Wagner Power Tex Texture Sprayer #0520000
Schlage deadbolt simply failed to unlock, with key from exterior and from inside latch. The feel was like there was no resistance. The lock is only one year old and a previous Schalge deadbolt failed after...
you can buy some "grafite" powder at lowes that is made for stiff locks, it will grease it up. if that doesnt do it the your problem may be in the plunger. might it be out of line? if so straighten it and make sure the it aligns with the strike plate on the door jamb. one of those are sure to fix it.
Apr 17, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Skips or won't play disc if even slightly scratched
Hello opie440,
The optics might be dirty or the pickup assembly might need alignment. In the former case you can get an optics cleaning kit and try to clean the laser LED and pickup assembly. For the latter cause you will need to have thre unit aligned at a TV repair shop.
Feb 18, 2008 | Sony DVP-S530D DVD Player
Optics Logo
223 people viewed this question
Top Nikon Optics Experts
George Merkley
George Merkley
Are you a Nikon Optic Expert? Answer questions, earn points and help others
