Question about Canon imageRUNNER C3200 Copier
Canon PC Printer 70 (1980s microfiche reader with integral image inverting Xerox copier) P2 error - paper goes all the way through the machine until first few inches protrude out of heat roller, then stops there. Previous P1 error - paper leaves partially out of the paper tray, then stops there - was solved by taping paper dam out of the way (like as if the solenoid was engauged). Anybody thoroughly familiar with this machine?
mellomania
  • 121 Answers
SOURCE: Canon ir210 problem
try to uninstall and reinstall the printer by going to (add remove programs ) in control pannel then restart pc and printer.
Posted on Nov 13, 2007
spinal
  • 287 Answers
SOURCE: Canon iR8500 with Error E000583-0001
Hello Jeremy,
This error code has to do with your finisher. The auxillary tray is not finding its home position or does not leave the home position within the alotted time. Check for binds. I have limited exposure to the K4/3 finisher but try this. Turn the copier off, and open one of the finisher doors. Now turn the copier back on with the finisher door open so it cannot initialize. Once the copier is basically ready except the finisher door is open, close the finisher door and observe all the **** (and theres alot) initialize. This may help determine the problem. I hope this helps...........................SPINAL
Posted on Mar 21, 2008
checkitright
  • 1362 Answers
SOURCE: Canon IR105 and IR8500 Load paper Problem, Tray Suspend Problem, Paper Pickup and Jam Problem
WOW !!!! that is a list, but I will try to shed some light.
1-are the trays not being sensed in the paperdeck (optional paper tray capacity)
and the ones that work in the copier?/ a) the bord may be bad b) the connector may not have good contact
2-tray suspend
3-registration jam, a) the registration assembly is probably shorting out b) notenough sep causing the paper to rise up on the drum and then jam,
4-the paper sensor in the trays are in the pick up assembly tires, the ones that come down topick up the paper, there is a sensor that is loose but when it hits paper goes up, when no paper the metal plate goes up but has a hole for the sensor to fall trough and does not go up, giving paper empty.
5-I do not have any info on the specs for the corona wires, this is in the service manual
6-Sparking in the coronas is bad and can result in paper jams and holes in the drum, sometimes putting whiteout on the very ends of the coronas help, but it's better to replace, you can get the end blocks seperate.
7-Pre-corona assy' is to charge up the drum for fater copies, some techs do take them out, if all the wires are arcing then it may be your HVT (high voltage transformer) for the coronas going bad.
8-image is skewed only when using ADF if you put it on the glass it should be fine, the problem is the glass is too dry, try spraying some WD40 on the glass and wiping it off, leaving no residue just a slick smooth surface. the paper turns due to the dryness when fed on the glass.
9- Yes you are right there is no room for the paper to skew it would tear or get jammed if it did
hope I was of some help
Posted on Oct 15, 2008
  • 117 Answers
SOURCE: Canon copier show error code:E100
E100 means the copier is not warming up.Make sure all the wires to the fuser are properly connected, then open and close the front door.you may have to go into the service mode to reset the error code.Good Luck
Posted on Mar 26, 2009
  • 153 Answers
SOURCE: canon image runner 7105/7095/7086
try cleaning your pick up rollers but sounds like they need replacing, just clean them with window cleaner and rag
Posted on Apr 09, 2009
What does the Canon IR8500 error code E000222-0000 means?
There's no code like that in my manual.It's220-001 means lamp inverter PCB faulty,or reader controller PCB faulty. There's also a E 225-000 error which mean scanning lamp(xenon tube) is faulty,or inverter or CCD
Oct 14, 2014 | Canon Office Equipment & Supplies
MG3260. trying to set up and keep getting P2 error message. tried turn off both power cord and switch. still the same
not picking up ink cartraiges, is the plastic sticker peice off the ink cartridges? are they lined up right in the printer, do you have enough paper in the machine for it to register.
Feb 09, 2013 | Canon PIXMA Office Equipment & Supplies
Error code 117-363 printer starts machine is awake
only see error code 117-363 and not permited other option
Nov 26, 2009 | Xerox 6180MFP/N Printer
I get error code e071 and there is no paper pickup can you help me ??
plz check inside the paper try there will be sheet like xerox sheet check it if it goes out put it back in correct position
Nov 17, 2009 | Canon LASER SHOT LBP-5200 Printer
Paper jam canon mx850. I cant find the paper.
The error indicates a black ink stick was jammed. You have to clear the ISC (ink stick count) error. Turn off the printer. Turn on the printer. As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display. Release the buttons, it will now come up in the service mode. Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
If you ever buy any Xerox ink and you get a cracked ink stick call Xerox cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif800-835-6100cb_transparent_r.gif and they will replace it free of charge. Otherwise you risk this problem.
Hope this helps.
May 30, 2009 | Canon PIXMA MX850 Multifunction Printer
Error 002 with Canon image class MF 8180 C
I usually open the back cover, top cover, cartridge cover and pull out the paper tray. Sometimes this clears the alarm, if this does not clear the alarm, I unplug the printer for a couple minutes. Between opening and closing the covers and unpluging the printer, the alarm goes away. Ray
Dec 30, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
PRINTER
You have to have the telugu fonts installed in the machine otherwise, the other work around, you have to make the Canon print as an image and not as a text.
Apr 20, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon imageRUNNER C3200 Copier Logo
424 people viewed this question
old marine
old marine
