Question about Breville BES820 Espresso Machine
Breville BES820 Espresso Machine internal short circuit
  • Spotless Overalls
    Spotless Overalls Apr 09, 2011
    Ok, I'll describe my own fix to my own problem in the hope that it helps others. First of all, the symptoms: your machine just stops working altogether; all lights go out; you try and turn it back on but nothing happens; then you realize half of your house has lost power. So you try and reset the circuit breaker, but you can't succeed until you turn off the machine at the wall plug.
    The diagnosis: probably an internal short circuit.
    This is what happened to my machine, and because it's out of warranty I thought I'd have a quick look at it myself. Turned out to be simple fix, so here goes...
    Getting access to the wiring we need to look at is easy enough.
    1. Disconnect power from outlet (obviously);
    2. Use your Torx T20 to driver bit to remove 4 screws holding the rear cover, then turn the machine upside down and remove 2 small philips-head screws securing the base of the rear cover. remove the cover.
    3. Gently bang the top die-cast cover from the back to try and dislodge it and move it towards the front of the machine (there are no screws holding the cover on the BES820, it is just a tight fit under some lugs). Your attempts to move the cover will be met with resistance. In the end I needed to thump it quite hard with my hand. A rubber mallet would probably be ideal, but I don't have one. Once you have pushed the cover forward by about 10mm, you should be able to lift the cover off.
    4. Unscrew the earthing cable form the top cover and put the cover aside.
    5. Now inspect the visible cables. Look in particular for any pair of wires that may be making contact with each other. This was what I found in my case. Two wires had been rubbing against each other, probably due to the vibration cause by the pump, and eventually had rubbed through the insulation to the point where the circuit was shorted. Smoking gun found!
    6. If you find this evidence, you will need to a) add some additional insulation where the original has worn through (make sure it is heat and steam resistant, consult with your electronics store), and b) ideally, try to rearrange the cabling to keep some physical separation between the cables so it doesn't happen again.
    When you are satisfied with your work, you can test it by plugging it back in and turning on at the wall. If you haven't replaced the covers yet, be aware that most of the visible wiring you see in there is running mains voltage, so keep hands clear!
    Reassembly is the reverse of above. Don't forget to re-connect the earth lead to the top cover before replacing it. Good luck!
  • steve_s741
  • 4 minutes ago
Posted on Apr 09, 2011
Testimonial: "This guy is a gun"
Hi, my breville bes820 machine won't pump or pressurize? Initially when you turn the machine on it would make a pumping sound but now it just makes a humming sound for a few seconds, I have taken the back...
Not familiar with this machine. But assume it has a vibrating armature pump. Usually when the power unit cannot deliver enough current to the pump it will hum like this. The pump could also just be stuck and need a service. Remove the pump, they are easy to open and cheap to replace.
Jan 01, 2015 | Coffee Makers & Espresso Machines
Hi, the machine needs to be powered on and off many times in order to be ready to work. A click noise is coming from behind when powering off. Thanks
Try this open the steam valve and leave it open then turn on the machine, close the valve when the wand starts making a hissing noise. I think the vent valve on your machine is damaged and needs to be replaced.
Feb 20, 2011 | Breville BES820 Espresso Machine
Bes820 when i connect power the machine starts pumping water into drip tray and this happens without pushing the power button i try pushing buttons but nothing changes the only way to stop the machine isto...
It's a common problem with this family of machines, mine does the same thing from time to time. There is a potential solution posted on this site somewhere, you might find it by searching for Breville 800esxl instead. The same article also appears here if you can't find it, but the format is messed up.
The fix is complicated, and you'd need to be competent with electronics repair, as it involves replacing a faulty zener diode in the controlling circuit board. Also, I'm not sure if it's going to work for the 820, as when I pulled my 820 apart and looked at the circuit board it didn't resemble the one shown in the article. There is a pretty good chance that they share a common component in this zener diode though, judging by the behaviour, so this circuit diagram will help if you want to have a go at fixing it. Replacing the entire control board would probably be achievable if you don't have the skills to replace the diode.
Also, dismantling the 820 will be a different process, which you can find in my other post here.
Personally, I just put up with the problem and turn it off at the wall if it won't *******.
Feb 03, 2011 | Breville BES820 Espresso Machine
Who in New Zealand supplies replacement seals for a Breville 800 series coffeee maker
You can get them from Need A Part. They are an online shop, but they have a phone number as well. I think this is the seal you want:
http://www.needapart.co.nz/shop/products/10120008
Nov 27, 2010 | Breville BES820 Espresso Machine
I got a used one today and i can't seem to get it to turn on, nor can I get a manual up online?
Most of the Breville 800 esxl have this problem.I strongly believe,your problem is within the electronic printed circuit board.I've searched&searched the internet.There are no internal parts for it,Unless you are into electronics,your broblem is a zener diode that is shot,Good luck.
Feb 26, 2010 | Breville Die Cast 800ESXL Espresso Machine
Breville BES820 Espresso Machine Logo
620 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
