Question about Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side By Side Refrigerator, White (GS 5SHGXKQ, GS-5SHGXKQ)
Our water and ice taste terrible, what should we do?
    President:
  • 228 Answers
You may have two water filters, one in the back of your refrigerator tied in between the house line and
your refrigerator, you may have this if you have hard water and no water softner. but there is also one
on the refrigerator itself, it has a base water cartridge either located behind the grille, or may have a slot
in the grille. located below the freezer compartment door. if it is thru the grill rotate counter clockwise
and pull out, some water will spill, it should have a number on it, just remember when getting
any kind of parts, you will need make and model number, serial number and part number, if you do not
have the part number, so long as you have the rest and take the part with you, they can match it up.
if you need more info you can go to appliance pros.com and you can download a parts diaghram
for your appliance and any instructions. they will also carry the part you need. good luck!
Posted on Apr 09, 2011
Nasty tasting ice cubes
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Jul 13, 2010 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
We had a new kitchen faucet put in today and the water tastes terrible now. Can we do something?
Nothing other than let the water run at 1/4 throttle in an attempt to clear the nasty tasting water from the supply lines. Let it run for maybe an hour and taste it again.
Working on the lines might have shook loose the foul taste way back up the system. I would hope an hour would clear it but it may take more.
Some cities with less than perfect water will flush their supply lines by opening fire hydrants in a certain pattern designed to shake loose deposits from inside the supply pipes. They often report that people have bad tasting water for days afterwards - perhaps in a few days you might get your relief too?
Aug 04, 2009 | U-Line BI-95
My ice taste like plastic
if there is a filter change it or use more of the water so it does not sit too long and get stale
Aug 03, 2009 | GE GSS20IEP Side by Side Refrigerator
The ice from the ice maker tastes terrible, the water from the despenser is fine just the ice is a problem
remove icemaker and check that you have no eroding of teflon coating. you may install a quaity charcoal filter.
Jul 25, 2009 | Amana Refrigerators
The ice in my ice maker tastes terrible. what
try changing the filter to the ice maker.
Jul 21, 2009 | Refrigerators
Ice tastes like plastic. New LG French Door.
Change the filter each week until problem is gone. LG is not usually hit with this problem. good luck.
Jun 09, 2009 | LG LFC25760 French Door Refrigerator
I sure hope you are using an in-line filter for starters, then if the ice still tastes bad, check the source line.
Jun 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Chemical smell in ice and water
you will need to replace the water tank inside the unit
Jun 07, 2009 | Whirlpool GS6NBEXR Side by Side...
Terrible taste that came from water?...
Do you have a water softener? It's possible the softener was in soak when you used the water dispenser. That would explain the "salty" (hi sodium) water taste and thena retrun to normal later.
Also, if you get your water from a muncipal well, they may have been experiencing a problem at the time with higher than normal sodium content.
Apr 08, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
172 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
