I have a hotpoint wm63, the door hinge broke, which i have replaced, but the nuts to fix the door back on have fallen inside the machine, i guess i eed to get inside to refix the door, but how do i do that??
  • Woof4 Aug 19, 2008
    hinge broken on WM63 How do I repair
It is not nuts but an internal bracket. You can access it from underneath by stretching your arm inside once you have found the bracket. REMEMBER TO POWER OFF BEFORE PUTTING YOUR ARM IN!
Posted on Nov 12, 2008
How do I fix a door that has fallen off because the bottom door hinge broke?
Most manufacturers will be able to supply REPLACEMENT hinges. Just contact your local white goods supplier or Service Centre.
OR you may be able to FABRICATE one yourself depending on your level of expertise or DIY skills.
Oct 20, 2014 | Refrigerators
Door is not level, how do I fix?
There should be some adjustment in the door hinges. Check the hinges to make sure the pin that enters the door is not broken. If it is, dril out the pin and replace it with a small bolt, put two nuts on the bolt and use the top nut to adjust the hight of the door.
Aug 11, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Plate at back of door hinge on hotpoint aqarius has fallen down
Tilt the washer back, and you will be able to retrieve the back plate from the bottom of the washer.
To refit it, you will have remove the front of the door seal from the cabinet front.
May 25, 2010 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius 1100 WM63 Not Spinning Clicking Programmer
I would suggest you check the brushes in the motor, as it sounds like they are worn out.
Replace them if they are less than 3 or 4 mm long
This would give you the symptoms you are describing.
Please rate my solution.
Feb 09, 2010 | Hotpoint Aquarius WF000 Front Load Washer
The hinge of the washing machine has broken - Creda W100FW
The door hinge block has fallen inside the front of the washer.To retieve it, tilt the washer back, and you should find it at the left hand side.
Remove all screws securing 2 parts of door together, prise apart with a screwdriver or similar, and the door will come apart.
You can now access the hinge and all other partsd inside the door.
Trust this helps.
Nov 28, 2009 | Creda W100FW Front Load Washer
How do we fit a new hinge to a Hotpoint WM64P washing machine
Remove the wire clamp that secures the door seal to the front of the washer.
Pull the seal of the front. and double it back inside the washer.
Undo the 2 screws that secure the door hinge to the front of the cabinet, keeping hold of the hinge support plate behind the cabinet front.
Remove the door, and undo all the scews that hold the 2 halves of the door together, then prise apart the the 2 halves..
Replace the door hinge.
Reassemble in reverse order.
Nov 24, 2009 | Hotpoint Washing Machines
Door Hinge Replacement
remove spring that holds the rubber bellows to front of machine
peel back and fish out plate from inside cavity of machine
then refit plare and reverse process
Mar 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Front Loader Washing Machine
My neihbors Maytag had a bad "wax motor" on the door. It's the locking mechanism. When it went bad it also damaged the control board which I was able to repair luckily. Total cost was less than $50. I don't charge labor..haha. If it's just the lock I'd say <$200. If the control board is bad I'd say >$500.
Feb 28, 2008 | Washing Machines
Replacing Door Hinge
You should be able to access the back of the hinge via the top of the machine removed.
Oct 07, 2007 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
246 people viewed this question
Top Washing Machines Experts
