Question about Ducane 30400040 Stainless Steel Grill
We have a Ducane Model #30400040 and we have replaced the three tube burners and the heat plates; however, we noticed that the drip plate under the tube burners is worn out, as well. Is it possible to order the replacement part for this, as we have been unable to identify the actual part.
It is called the Firebox.
Posted on Sep 12, 2011
Have a home depot ducane 5 burner. just replaced burner tubes. have never used the rotisserie burner on it before. it lights but won't stay lite after releasing knob...any suggestions? Thanks
Infrared burners requite that the gas control knob be held in for 2 minutes or so, to allow the thermocouple on the infrared burner to heat up completely. If it's windy were you are, the wind can blow the burner out, while trying to light it. That's why it has a thermocouple on it, to stop the gas if the burner goes out. All cooking on the rotisserie is doon with the lid/hood closed, at temperatures around 250 degrees F. Once the infrared burner turns bright red, release the control knob.
Hope this helped you to get it lit. Thanks for choosing FixYa.
Aug 24, 2011 | Ducane 30400040 Stainless Steel Grill
When using rotissery should main burner also be on?
NO, the grill will overheat with the lid closed. Besides, you will probably have to remove the cooking grates under the rotisserie , because a disposable drip pan should be placed under whatever your cooking.
Hope this helps and thanks for choosing FixYa.
Jul 29, 2011 | Ducane 30400040 Stainless Steel Grill
How do I remove the old burners to replace with new?
Should be as easy as removing the screws at the ends of the tubes and sliding the tubes away from you and putting the new ones in like you took out the old ones.
Apr 10, 2010 | Ducane 30400040 Stainless Steel Grill
Ducane model number 30400040 just received set of (3) stainless tubes to replace the old ones whats the easy way to install
goto ducane web site http://www.ducane.com/manuals/
and download manual. They have Meridian and Stainless models in 3 & 5 burner for LP & NG. Follow 1 year cleaning instructions. Pictures and instructions.
Apr 05, 2010 | Ducane 30400040 Stainless Steel Grill
I have a ducane stainless steel ducane 30400042. Weber has sent me new burner bars since the old ones rusted but you do I install them?
Remove the grates and burner heat deflectors. There are 4 screws on the knob panel, 2 on the left and 2 on the right. Remove the screws and pull back about a inch or two. I found it helpful to open all the doors a bit to rest the panel on them. The burners should remove easily once this is done. Replace the burner tubes and be sure tubes have holes facing up on the one side for correct heat distribution. When placing the knob panel back on, make sure that burner tubes go onto the gas control knob correctly. Replace screws on the knob panel.
****Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.****
Jun 20, 2009 | Ducane 30400040 Stainless Steel Grill
Cannot light new burners
I just replaced my burners and I also cleaned the starters. Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.
Jun 02, 2009 | Ducane 30400040 Stainless Steel Grill
Meridian 5 burner trouble
Yes you can fix it. Carefully remove the screws that hold the panel where the burner knobs are, There are 3 screws on each panel under the side shelf. There is another screw up underneath the face plate as well. Once the screws are out pull the face plate up and out so that all the tubes are disengaged. It should rest about 2 inches tilted back. Now remove the grates and burner covers and inspect the burner tubes. You will most likely find that spider webs or hornets have blocked off the gas flow to the burner. carefully clean every burner tube out and put everything back. You also may want to use a bit of sandpaper on the ignitor tip. Put everything back together and you should be good to go. It seems all Ducanes attract spiders on the burners...
Apr 06, 2009 | Ducane Meridian 32 Inch 5 Burner Gas Grill...
Gas burners heat unevenly
I had a similar problem. I took off the burner heat deflectors and seen gaping holes in the burner tubes. Get your model number and serial number and call Weber. Most Ducane grills have a 5 year warranty on the burner tubes. They will ship them free if under warranty!
Nov 10, 2008 | Ducane 30400042 (LP)
Burner replacement on Ducane 30400040
Remove the 2 grill wire cooking racks by lifting them out of the top of the grill, next lift out to remove the 3 heat deflector panels which exposes the 3 burner tubes. Remove the 4 screws located on the outside flanks (2 on each side) of the 5-knob control panel assembly - then gently slide the knob control assembly outward and away from the grill just about an inch or two. You can now remove the old burner tubes and replace them with the new units. Then simply slide the control assembly back into the grill frame and replace/tighten the 4 screws. Voila`
Jul 04, 2008 | Ducane 30400040 Stainless Steel Grill
Ducane 30400040 Stainless Steel Grill Logo
276 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
