Question about Dryers
Dryer is stuck on one setting i can't change the setting or get the dryer to even turn on
My Whirlpool GEW9868KQ2 dryer is stuck on the towels/cotton setting and will not change to any other setting. Also when i press the stop/cancel button, it wont turn off. Please help!
This is probably due to a stuck button. The only way to fix is to pull the board off and check the buttons manually and/or replace interface control.
Dec 12, 2011 | Whirlpool Dryers
1. When you set the timer knob for the dry cycle it gets stuck and dryer keeps running. 2 The dryer turns on and runs but does not always ignite to provide heat. Heat source LP Gas.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 20, 2011 | Whirlpool Dryers
When I start my Maytag Atlantis dryer it startes and heats fine, but it never turns off. Even when I turn it on the timed settings.
If you open the door an it still keeps running then the motor relay contacts are stuck. It's an easy fix but no doubt you will need a service man to do it
Feb 22, 2011 | Dryers
Asko Dryer t760 program menu won't change or is frozen The program menu is stuck on one setting, and the P1, P2, P3, P4 buttons don't change the program. When I try to reset the program (by pressing...
Welcome to FixYa.
By stating "the dryer does work" indicates it is likely an issue with programming.
What are the chances you have the menu lock-out option turned "on"...also referred to as "child lock".
You may quickly rule this out or confirm it is the problem indeed, by trying this.
CHILD-SAFE START
1. Turn the machine off then on.
2. Press ENTER five times, then press P3 five
times. (This must be done within 15 seconds.)
3. “Delayed start” displays with “0” flashing in the
lower right corner. Press the Right Arrow button
to toggle the display to “3.”
**NOTE: Child-Safe Menu Button**
Please note that when you set the child-safe Start
button, the Menu button is automatically
programmed to delay for three seconds before it
becomes active. This prevents a child from
accidentally changing the program settings.
When you want to change a program, press the Menu
button for three seconds to activate the menus. The
Menu button will work normally (without the
three-second delay) until you have completed your
changes. If it is not pressed for two minutes, it will
automatically revert back to the child-safe mode.
Let me know if this indeed solves the problem but either way please keep me posted.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Sep 18, 2010 | Asko T761 Electric Dryer
I have an LG DLE2516W electric dryer a couple of days ago when I turned it on it was making a really loud noise and vibrating. Now, it won't turn, when I took off the top you can't even push the drum...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 23, 2010 | LG DLE2532W Electric Dryer
My dryer drum is stuck. When I open the top, the drum is set so that I cannot get my clothes out. I looked at the directions to push a button in on the inside, and then manually rotate it. I had to...
It sounds like one or both of the bearings have failed. Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Aug 12, 2010 | Fisher and Paykel DEGX1 Electric Dryer
I have the GLEQ212ES1 dryer. When it is running. it sounds like something is rubbing against the drum. When you turn it by hand manually, the drum is harder to turn.Could a piece clothing gotten stuck...
Although this is possible, usually one of the wheel bearings may have gotten dry or even is stuck. Inside there are wheels that the drum is steadied by and that rotate with the drum. If it's a year old it should be under warranty and a tech can fix it. If that is a problem, remove the back (after unplugging it) find the wheels and rotate the drum by hand. If a wheel is stuck or dry you will find it. I hope this helps.
Jul 15, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Dryer lights blinking will not turn on or off, or change time,or settings has power ,setting stuck in sensor dry
This is a major control fault. you will need to replace the main control board. it has failed.
Jun 15, 2009 | Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
