Question about Microwave Ovens
We accidentally removed the splatter shield on the inside of the microwave door and realized this was a mistake. Can this be replaced?
5 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: removed splatter shield
If you can supply the brand and model, we can probably point you to the supplier for the splatter shield (waveguide cover).
The door shouldn't really fog up too much (not permanently anyway) as long as the internal cooling fan and seals are okay.
The door panels can usually be separate for cleaning if it's absolutely necessary, but it's a pain of a job.
Again, brand and model mean everything, so if you can give us those we can probably get more specific. Happy to help.
Posted on Nov 18, 2007
SOURCE: Cleaning inside of microwave door
THE DOOR ON MY MAYTAG MICROWAVE OVEN HAS A SCREEN OVER IT. I HAVE SOME FOOD SPATTERS THAT PENETRATED THE SCREEN AND I CAN'T CLEAN THE GLASS THAT THE SCREEN PROTECTS. HOW CAN I REMOVE THIS SCREEN TO CLEAN THE GLASS?
Posted on Nov 23, 2008
radar001
  • 1051 Answers
SOURCE: Need to replace the splatter shield on my Emerson
Advise not to use. Without the shield cooking grease or other material may splatter into the main microwave components and cause them to fail. Some of those parts can cost over $100.00.
Posted on Aug 17, 2010
Do a google for how to clean a microwave door and it shows you how to take the screen off and clean it. I have same problem with a brand new Frigidaire--splatters between screen and door--looks bad! and I contacted company and they said call a service tech! I can't afford to!!!
Posted on Nov 29, 2011
It sparks
Check splatter shield inside cooking area for burnt carbon ie replace
Dec 11, 2013 | Panasonic NNSD688S 1.2 Cu. Ft. Capacity...
I own a microwave: model # jes636wk01 There is a plastic film covering the wire mess on the inside of the door. Will the microwave operate safely if the film is damaged or removed?
yes. It is there to protect the glass from food splatters It is the panel with the million holes that controls the micro waves I would not remove it but have it replaced if damaged.
Jun 09, 2013 | Microwave Ovens
For the sunbeam microwave sgb8901, do you take off the cover over the oven air vent? It's inside the oven on the right hand side- it looks like a rectanglar silver colored piece of cardboard.
I am also having this same problem i dont know the solution yet, but when you figure it out please let me know, or if i figure out i will repost =]
Aug 30, 2010 | Sunbeam SMW750 Microwave Oven
Need to replace the splatter shield on my Emerson microwave, serial # MV899SB. Is it safe to use the microwave without this shield?
Aug 17, 2010 | Emerson Microwave Ovens
Food splatter behind screen on door of microwave
If you take the glass out you have to find a deaker or someone who the tools to check for leaks around the glass.
Mar 17, 2009 | GE JVM1640 Microwave Oven
Microwave waveguide spatter shield burned through
THE PART IS CALLED A WAVEGUIDE COVER AVAILBALE FROM REPAIRCLINIC.COM
Jan 20, 2009 | Microwave Ovens
Oct 01, 2008 | Maytag MMV1153A Microwave Oven
Removed splatter shield
The parts can be ordered from the Panasonic authorized parts rep. You have to contact Panasonic for details.
I strongly recommend to have any work on a microwave oven done professionaly. There are radiation leakage issues if the door is not re-assembled properly. After doing any service the microwave oven must be tested for radiation leaks. I doubt that you have the radiation testing equipment to make sure that there are no leaks.
From US Food and Drug Administration (Microwave Oven Safety)
http://www.fda.gov/cdrh/consumer/microwave.html
Excellent Wikipedia Article About Microwave Ovens
http://en.wikipedia.org/wiki/Microwave_oven
Jerry G.
Jul 26, 2008 | Panasonic NN-S753 Microwave Oven
XL1800 Microwave Problem
A LOUD ticking sound could very well be a High Voltage Arc. This is usually caused by a breakdown of insulation on High Voltage Wires, or components. It can also be arcing between the door frame and the cavity. Usually where the bottom of the cavity floor meets the door frame. Indication of this will be small areas on the door where it looks like the paint has been chipped off, but if you look close you will see it is small burned marks. Another area is the Splatter Shield located inside and at the top. It looks like a Plastic Cover. It is not plastic, but a fiber material. Grease, and food will get trapped on and under this Splatter Shield. Over a period of time the grease and food particles will break down from being cooked over and over again. They will then form Carbon. Which will Arc when Microwaves are present. Remove Push-Pins holding Splatter Shield. Clean by washing with dish detergent . If burned (arc) spots are still present after washing, replace Splatter Shield or arcing will continue. Once Carbon has burned through, it will continue to burn.
Jan 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I am currently fixing my microwave, which has done the same thing. Go to http://www.repairclinic.com/SmartSearch/smartsearch.aspx?SearchText=%60AMicrowave
just select your brand and under parts, select doors and handles. It will be called Door film, peel & stick. For my microwave, it runs from $16.00 to $21.00. Seems like a very easy fix.
Nov 09, 2007 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
