Re F & P Smartdrive 9 Excellence 6.5 model;GW608K Have just replaced the bearings and seal, now the m/c wont fill, on pushing the start the H & C solenoids click in and out until it cancells out.The RPS seems to have 5 complete circuits. Can you help?
  • 1294 Answers
SOURCE: Fisher and Paykel - SmartFisher and Paykel - SmartDrive (9) Excellence 7.5 - Pump Blockage
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Dec 29, 2007
  • 1294 Answers
SOURCE: F/P Excellence 6.5 smart drive 9
Your inlet valve could be clogged, check this out.............
Posted on Feb 08, 2008
  • 10 Answers
SOURCE: hi,i have 5.5 smartdrive 9 excellence washing
Hi this is an out of balance fault the out of balance switch is hidden under the main motor controller which is under the main key pad
Posted on Jul 11, 2010
  • 713 Answers
SOURCE: I have a F&P smartdrive 9 and you turn it on
Hi just read your posting.I need the model number of your machine, which is located on a sticker at the back of your machine at the top.Please reply with this information and I can help you rectify this fault.Looking forward to your reply.
Posted on Aug 18, 2010
rylee_smith
  • 8619 Answers
SOURCE: I have a Smartdrive Excellence 7.5 washing
Hi
Thanks for using FixYa. The issue is with the control panel going bad and should be replaced. However, before replacing the control panel you can take it apart and blow some air with the help of hair dryer so that if there is any moisture on it, the hair dryer will blow it off. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 21, 2010
My F&P Smartdrive 9 Excellence 5.5 GW509R will not start water fill.
no power to turn on the tap solenoid
could be a problem water lever control or program board
call in a technician for a proper diagnosis and quote
Aug 14, 2016 | Washing Machines
Hi my GW709 7.5 smartdrive excellence won't fill with water and won't agitate if I manually fill it , help me please
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Feb 12, 2013 | Washing Machines
Fisher & Paykel Washing Machine
Check out the fuses on the main controller board if they are fitted. If you need a new motherborad you can get one from Fisher & Paykel in Australia at http://www.fisherpaykel.com.au/customercare/contactus/
Sep 08, 2012 | Fisher and Paykel Washing Machines
Model GW712av wont agitate
Will the bowl turn with no water in it,
If not turning the bearings are seized and rusted.
A bearing and seal kit is needed for your machine.
Aug 15, 2012 | Fisher and Paykel Washing Machines
When start button is pushed the motor will buzz but yhe drum wont turn
Turn power off ,Will the bowl(drum) turn freely by hand.
If not turn by hand the bearings are seized,
It will need a seal & bearing kit & maybe a shaft as well.
Jul 21, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel washing machine excellence 6.5 smartdrive 8
see this possible causes: God bless you
see the diagrams
Lid switch
test for defective or open
Motor coupler
replace coupler motor for defective
Belts
worn belt
Clutch
wears replacement
Drive motor
one winding burn , run with one winding in one direction and another with the other winding.
Drive pulleys
frozen pulley, worn.
Transmission
broken gear+ shifter defective
Agitator
worn agitator replace
5_16_2012_7_59_29_pm.gif5_16_2012_7_59_43_pm.gif5_16_2012_7_59_54_pm.gif5_16_2012_8_00_26_pm.gif
May 16, 2012 | Fisher and Paykel Washing Machines
Fisher and paykel smartdrive motor
136. (10001000) Phase 1 to 6 - Motor Stall
The Motor Controller has been unable to start the motor. Possible causes of this
fault are: Faulty motor harness, faulty or jammed motor, seized bearings or seals,
faulty Motor Controller module, faulty Rotor Position Sensor or harness.
Primary Source: Wiring.
Action:
Measure / check the motor harness, connectors and motor for discontinuity. This
can be done by taking a resistance measurement between phases of the motor
harness at the Motor Controller module end. Nominal resistance should be around
12.2 ohm for Phase 2,3 & Phase 4. For Phase 5 and 6 onwards the nominal
resistance should be around 32 ohms.
Secondary Source: Motor.
Action:
1) Check free rotation of the agitator and basket by rotating by hand. Bearings
and seals may be seized.
2) Check the Rotor Position Sensor and associated harness for water,
mechanical damage or corrosion.
Tertiary Source: Motor Controller module.
Action:
If the primary and secondary checks pass inspection then replace the Motor
Controller module.
Feb 14, 2012 | Fisher and Paykel Washing Machines
I have a fisher and paykel smart drive 5.5 that will not sart filling withwater. All the lights are on and the hoses and filters are not clogged
Hi just found your posting.Do you still require help?Sounds like a lid switch fault to me.Does the machine beep when you push the start button.Please reply for further help.Looking forward to your reply.
Oct 09, 2010 | Fisher and Paykel Fisher & Paykel Washer
Washing Machines Logo
102 people viewed this question
Top Washing Machines Experts
