When i first turn my tv on it shows colored lines when i first turn it on then when it warms up it goes away.
    Genius:
  • Televison & ... Master
  • 2,432 Answers
It means there is a problem inside of your TV unit.if you have an idea about trouble shooting like this i can give you some possible tips for you to look. first is check possible loose contact in your chassis board cold soldered parts. check also leak capacitor at video section and at vertical section. if you don't have an idea how to be done all this you may need to look for a qualified service technician.
Posted on Apr 09, 2011
4 Suggested Answers
jerryg50
  • 1689 Answers
SOURCE: Blue color spread over the pictures
This sounds classic to a thermo problem where a part(s) are becoming thermo sensitive with aga and use. When the set is cold and then warmed up, the defective part(s) is changing characteristics.
Some components became thermo sensitive that are driving the display. Or an embeded component in the display itself became thermo sensitive. It is very possible that the fault is on the board that does the X - Y addressing or on the backplane electronics of the display screen itself.
Using the set with defective components is a bad idea. If the part(s) fail completely and go shorted or opened, other more costly damage can be done.
The service rep for the manufacture of your set is equiped and trained to be able to troubleshoot and service your set.
You will have to take the set in to have it serviced.
Jerry G.
Posted on Apr 17, 2008
jrweighing
  • 183 Answers
SOURCE: Similar problems to others - horizontal lines and
Is the fault on the screen forced top manifest when the screen is tapped? If it is then take the back off the tv with the power off and check that all leads are not loose and secured ok.Next check that the power supply usually mounted central, has no capacitor tops bulging with possibly brown leakage.If so, replace faulty capacitors or replace power supply. If all is visibly ok, remove the T-Con board which is mounted top centre of screen and clean LCd screen ribbons. Then remount t-con and test again..if fault is still present then it may be the backlight connections in the LCD screen loose and arcing causing video distortion.Hope this helpls :)
Posted on Oct 17, 2009
  • 8457 Answers
SOURCE: My screen has horizontal colored
The tv board call the T-CON decoders board is dying,that why this problems are appearing.This T-CON decoders board it sit right on the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Posted on Oct 25, 2010
How to fix Multi color Vertical Lines on a Vizio E470i-AO TV
Does the menu function display the same lines? What kind of cables are using ? (HDMI, Component vid, S-video, co-ax)
Were you as tenacious checking all cables/connections as you were the electronics? Lets rule out this all too often over-looked possibility.
Do you still get the lines with nothing connected to the TV? (no source connected)
Feb 28, 2016 | Vizio E-Series E470I-A0 47" LED TV...
No picture, vertical colored lines
I have never heard of a warm-up problem on a digital television. Unlike the old CRT TVs and monitors, digital panels don't have to warm up. I would go with the TV repair persons assessment that you've got a bad panel.
Jan 04, 2018 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
My screen has horizontal colored lines over the entire left hand side of the screen during a 2-3 minute warm up period when I turn on the TV. It goes away after that and is fine otherwise until I turn off...
Oct 25, 2010 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Samsung LCD Flatscreen only shows lines of color or purple dots
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 18, 2017 | Philips 42HF7444T 42 in. Plasma TV
Jerry G.
Apr 17, 2008 | Vizio GV46L 46 in. LCD Television
Color switches to b/w, then a click, then color, then b/w, click, etc.
Good day.
I think your problem is with the crt circuit. It is the one on the rear of your picture tube. Some loose connections may occured in there. Also, check if the flyback is arching. Sometimes, the voltage on the flybach itself causes this.
chris
Mar 23, 2008 | Sony KV-27FS13 27" TV
Samsung 42 HCN4226wx
i think you got a bad board, ask for an exchange.
Jan 21, 2008 | Samsung HCN4226W 42" Rear Projection...
BLUE SCREEN
I got this Sony KP-57WS500 57 in TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 25, 2007 | Sony KP-57WS500 57" Rear Projection...
Picture goes dark
1 your problem is in video section 2 if it is ok then check power supply for any components defective.
Sep 15, 2007 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
