Question about Refrigerators
My refrigerator keeps turning off - Refrigerators
  • 415 Answers
It could be a defective defrost timer if you have lights and NO fans running nor compressor starting you maybe able to tell if it shut off about every 5-8 hrs. Now if it shut off after every cool cycle then I would tap the refrig temp control with a firm tap if the frig starts then it is a defective operating thermostat.
Posted on Apr 09, 2011
Why does the refrigerator's compressor keep turning on and off and not cooling?
is a very strong posibility thats your compressor, but first check the capacitor, then relay, change these parts and if the problem still then is youdr compressor
Oct 26, 2014 | Whirlpool Refrigerators
My frigidaire freezer keeps turning off, I have to keep turning the temp control to turn it back on.
Sounds like you have a control issue. specifically a thermostat issue. I'd replace the thermostat.
Aug 14, 2013 | Frigidaire 20.6 cu. ft. Top Freezer...
Kenmore refrigerator
K model 106, to have water dripping, is normal most times but only when the refrigerator is turned off, but to have dripping water when it's turned on, check the the cooling system, repiar it o have it changed.
Jun 06, 2013 | Refrigerators
The divider wall between the fridge and freezer stays very hot to the touch. Possibly the defrost mechanism is stuck??? Any ideas?
Check the fan which cools the compressor . Sometimes something gets caught in the blade . Also check that the coils at the front bottom are clean . If the motor is not turning and nothing obstructing the fan blade , replace the motor ( condensor motor )
Jun 16, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
My maytag is running all the time and the refrigerator does not keep anything cold, the freezer does not freeze but will keep things cold. What could be the problem?
Check the compressor fan. Make sure it is turning. If the fan is not turning, heat is not removed from the coils. This heat must be transmitted to the outside air for the refrigerant cycle to work properly.
This fan should be at the bottom of the unit near the rear. If it's not turning, the fan motor will need to be replaced.
Oct 14, 2009 | Refrigerators
Compressor keeps turning off
that know your turning is the defraost timmer
itg should turn the machine back on in like 20 min
if its not turning the machine back on then its bad
Oct 07, 2009 | Daewoo FR062R Compact Refrigerator
Freezer keeps buzzing
don't worry! its the sound of compressor vibration and it is normal........if the sound is more than turn round the refrigerator and tight the nuts of the compressor stand......................have a nice day:-)
May 14, 2009 | Samsung RB2155SH Bottom Freezer...
Kemore Refrigerator MODEL# 2535808789A is not cooling.
Thank You for having your model number ready, Could you remove the grate on front and bottom of refrigerator to expose the defrost timer. In the opening on front turn the timer slowly turn clockwise until you hear a click or change in operation of refrigerator. Let me know, Sea Breeze
Mar 21, 2009 | Kenmore Refrigerators
HI thanks for the question the problem is with the thermostat . the knob you keep turning.thats the part that turns off fridge when cold enough . i would replace the thermostat the appliance doc. please rate my answer .thanks
Oct 08, 2008 | Kenmore Refrigerators
Refrigerator Keeps running
Replacing the thermostat should correct the problem. Be sure to install the thermstat exactly as the one you are removing, assuming it hasn't been changed prior. Hope this helps
Jun 10, 2008 | Beverage-Air Beverage Air KR48-IAS 44.9...
Refrigerators Logo
193 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
