Question about Dewalt Air Tools & Compressors
I start the compressor and it runs and builds up air. After a few moments it will come back on run for a few seconds and turn off. Then it comes back on runs a few seconds and shuts off. It just keeps repeating this cycle
  • glisajaco5 Apr 09, 2011
    I'm sorry that I did not explain it very well. I"m not using any air. There is not a hose hooked up to the compressor. The only thing that has been done is plug it in and turning it on. There is no air being released, not even from the pressure relief valve. So it comes on and goes off, over and over again.
    I do appreciate your help
  • 710 Answers
Hi Alisa,
This is normal for an air compressor. As you're using it, it uses up the air inside and must run to build your pressure back up.
When you finish using it, you should always, turn down the pressure knobs and turn it off. Saves on equipment.
You should also drain the tank periodically to let out water that has accumulated inside the tank so the tank won't rust. To do this, loosen the drain under the tank and let the water drain out. Don't forget to tighten it back up or you'll be back asking why you don't have pressure. :>)
I hope this helps. If it does, I'd appreciate your vote.Thanks,
Handie Andie
Posted on Apr 09, 2011
  • Handie Andie
    Handie Andie Apr 09, 2011
    Hey Alisa,
    This is common for air compressors. I don't manufacture them so I don't know why, somewhere they're losing air a little at a time, so they keep cycling on to keep up the pressure you set. The only cure for this is to set the pressure down to lowest or turn it off.
    Hope that answers your question. Anything else I can help you with on your compressor?
    Handie Andie
My frigidaire AC starts cooling fine but stops blowing cold air after few minutes and it does not cool at all. I haved turned it off and re-started it and it does the same thing
The compressor is being prematurely turned off. That explains why the cooling stops after a few moments. Either the thermostat is responsible or the electronics working with the therm are responsible for the anomaly.
Freon level is fine because it does cool when compressor is running. U might also want to check the start/run capacitor. That sucker starts the motor and keeps it running after the start. If the run section goes bad the motor will usually stop after it starts.
Aug 17, 2016 | Frigidaire FAS256R2A 25,000 BTU Window Air...
1989 deville load level compressor runs for 3 seconds then stops after turning ignition switch on
Check and make sure that the level control lever that goes to your shocks was reconnected. Might have been overlooked....Hope this helps.
Mar 30, 2014 | 1989 Cadillac Sedan DeVille
Super silent air 20-air compressor not running it humms for 3 seconds an then turns off every say 10- 15 seconds.
Hi, does it build up preasure? Possible problems can be too much water in the tank, air intake pluged, auto shut-off not properly adjusted or defect. Was it run hot before without oil?
Oct 26, 2013 | Silentaire Technology Super Silent 20-A...
My air compressor is sometimes slow to start and it will throw out the breaker on the compressor when it runs it runs great. when it builds up air and shuts off it will not come back on when the pressure...
Two things to check... the wiring to the compressor may not be a heavy enough gauge to support the current draw...
The start capacitor on the motor may be going bad...
heatman101
May 14, 2011 | Northern Industrial Tools Northern...
Compressor runs for few sec. fans inside dont turn on at all
hi there, circulation of air inside the refrigerator run complete the cycle of refrigeration.if no fan your compressor motor trip off.there are fuse that hold the line connected to fans this was located at the backside of refrigerator,have check on this. replace the fuse.fix my rate have a nice day.
May 14, 2010 | True Food VWR Storage Refrigerators with...
My craftsman conpressor is a 5 gal type oil free. problem is when I plugged it in to operate it the moment I turn on the switch, it would run a few seconds and tripped my circuit breaker in the house for...
First, the simple answer - check the AMP draw on the compressor. It should be on the motor or compressor nameplate/tag. Even a small compressor can use alot of power, and blow the breaker if there are other things on a circuit.
Does it seem to run OK for as long as it runs?
Oct 26, 2009 | Craftsman Air Tools & Compressors
DuoTherm compressor starts but will not continue to run
check condenser fan if running. it will make compressor comes on and off if broken
May 31, 2009 | Dometic Rooftop RV Air Conditioner
EC-12 runs but only builds to 35 psi and continues to run
It looks like there might be a knob which sets the max air pressure coming from the compressor. If there is one, this may have been turned down.
There are usually 3 pressure settings on an electric compressor. Compressor max, pressure switch cut on, and pressure switch cut off.
Apr 29, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Oct 26, 2007 | Heating & Cooling
Air Tools & Compressors Logo
63 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
