Question about Cobra 200 GTL DX 4-Channels Base CB Radio
Light for meter on cobra 200
Can i get a replacement light at radio shack for my meter ..do you no what there part number would be?..thanks ..David
  • 90 Answers
The meter uses a fairly standard 12 volt mini amp, I don't know if Radio Shack carries them anymore, but any decent CB repair shop should have it. Workman Electronics distributes these to dealers, their part number is "CMB".
Posted on Sep 26, 2008
RADIO SHACK, HTX-212 2 METER MOBILE HAM TRANSCEIVER MANUAL
Hi David,
You can get the manual here and an online version here.
I hope this helps!
Mar 08, 2012 | Radio Communications
I'm trying to wire a galaxy desk mic to a cobra 200 10 meter mobile
  • The Galaxy desk mic (power mic) is already wired four pin and the Cobra 200 is a 4 pin already as well. So unless someone has messed with them the mic will plug right up to the radio as is.
  • But if someone has repined the mic then follow the pinout I listed below to get it rewired for the Cobra 200
  1. Pin #1 on mic connector - Black wire.
  2. Pin #2 on mic connector - White wire.
  3. Pin #3 on the mic connector - Blue wire.
  4. Pin #4 on the mic connector - Red wire.
  • If you look on the end of the mic connector it will have the imprint of the number for each pin on the mic.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 02, 2011 | Cobra Radio Communications
Replacing Lamps in a Cobra 200GTLDX I need to replace the Nightwatch Lamps and meter lamp in a Cobra 200GTLDX...
check the voltage going to the lamps before you do this so that you don't have to replace them . They might just be shorted enough to have the lights go out.
Jul 01, 2011 | Cobra 200 GTL DX 4-Channels Base CB Radio
Dimmer lights arent working right and meter light is out
With the Cobra NW units, they have a separate power supply for the lighting, in most cases the power supply fails and the NW lights do not work any longer., there is also a socket where the tape lighting for the face plats back lighting slides in to the socket this may be loose as well. If you need further repair service let me know.
dodgem250.com
Feb 28, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
How do I replace the RF meter light in a Cobra 29NW? Thanx Breeze Neshanic Station, NJ
The light is a small 12 volt lamp that you should be able to find a similar one at Radio Shack. The wires are soldered to it but you can cut the wires and solder them to the new lamp. The lamp is held in place in the meter by a rubber grommet. You can take the case off the radio and just pull the lamp out of the side of the meter. Don't get to power full of a lamp or you will melt the meter.
Feb 08, 2010 | Cobra 29 LTD CB Radio
Lazy revieve need to tx then recieve is ok also meter failed
the switch in the mic sounds like its bad. Try another mic. You will have to call cobra to get a meter for the radio.
Jan 16, 2010 | Cobra 200 GTL DX 4-Channels Base CB Radio
Gtl dx will not transmit below 26.955
First off, the 200 GTL DX is a 10 meter radio. Running it on 11 meters (CB) is illegal, as it is not FCC type accepted. If you go below 26.965 mhz, you are outside of the 11 meter band, and operating illegally.12 meters does not start until 24.930, so ultimately, the freq's between 24.930 and 26.965 mhz are restricted even to a licensed amateur radio operator.
Jul 09, 2009 | Cobra Radio Communications
Cobra 29 NW LTD Classic wont calibrate and red antenna light keeps coming on
The calibrate knob only calibrates the radios SWR meter, the owners manual will show you the procedure for that. If your ANT light is coming on, it is telling you that your SWR is to high, and may cause damage to the radio from reflected power. You should purchase an in line meter as the radios internal meter may be somewhat unreliable. You need to tune the antenna to the lowest SWR possible. Typically anything under 2.0:1 is acceptable. Radio Shack sells a meter for about $50, and is pretty accurate. Antenna mounting can also cause high reflection if it is to close to other objects. Google "CB antenna tuning" or read the instruction manual for you antenna, and you should be able to figure out how to properly tune the antenna.
Jul 07, 2009 | Cobra 25 NW LTD 40-Channels Base CB Radio
Wiring diagram
Hello birdhunter, no the cobra 200 has the same pinout as the 29's and such, but the color code might be different.
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
STOCK Pinout Let me know how you get along with it,,,, Mechanic
1- Shield
2- Audio
3- Transmit
4- Receive
Sep 14, 2008 | Magnum DeltaForce CB Radio
COBRA
Yes, I found out what it was. the driver was bad. I guess these radios are very sensitive to static electricity like carpet shock. It will take the driver out. You can get it from RF Unlimited.
Aug 28, 2008 | Cobra 200 GTL DX 4-Channels Base CB Radio
Cobra 200 GTL DX 4-Channels Base CB Radio Logo
180 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
