Question about Stride Rite Lighted Unicorn Slipper Infant/Toddler/Youth Light Pink/ Trim Girl Shoes ; Infants and Toddlers
I want to deactivate lights in Stride Rite sneakers. Can you tell me where to start before I start slashing into the insole
When I place my finger on top of the spark plug lead of the second cylinder from front of vehicle, I feel a metallic click.
It may be time to change the spark plug wires. That click could be a leak in the spark plug wire, that could be causing a miss when you drive. You are lucky that you didn't get ZAPPED with the high voltage coming from the coil. Maybe you were wearing a good pair of sneakers that insolated you. Be careful. GOOD LUCK FRIEND.
Nov 17, 2014 | Cars & Trucks
Squeaky noisy sneaker
it's very simple. just take out the insole from the sneaker, then put some talcum powder in the sneaker, then put the insole back. this will eliminate the squeaking.
the problem is that sweat gets between the insole and the inside surface. the friction between the two is the cause of the squeaking.
May 09, 2013 | Nike Air Monarch III Shoes
My air monarch squeak and are very annoying...any fix?
Mar 20, 2013 | Nike Air Monarch III Shoes
Lights don't work in stride rite vroomz
There is a battery in the midsole. Take out the insole and replace it.
Mar 12, 2013 | Stride Rite Vroomz Racecar Shoes
How do you change battery in Carter's kids light up shoes
There is a battery in the insole. Lift the insole and the battery will be in the heel
Jan 20, 2013 | Carters Carter Match Light-Up Shoes at...
One shoe doesn't light up and they are brand new
You should taking them to store to replace it .I did heard that this brand have problems at one shoe with lights.Sorry for your problem.
Jun 12, 2011 | Stride Rite Star Wars Lighted Clone Wars...
I lost my directions and don't know how to change my stride to a lower number.
Manual is here: http://www.sportline.com/manuals/340.pdf
INPUT YOUR STRIDE LENGTH (Range: 12 inches to 60 inches or 30cm to 150cm) 1. Walk 10 steps. 2. Measure the distance that you've walked either from heel-to-heel or toe-to-toe. 3. Divide by the distance covered to arrive at your Stride Length. 4. Example: measured distance 360 inches, number of steps taken was 10 = 36 inches stride length. Important: Please remember that the length of your stride while walking is different than the length of your stride while running. If you plan to use this pedometer for both types of exercise, you will have to reprogram your stride length when you go from one to the other. 5. Press MODE button to reach the DISTANCE MODE showing MILE or KM. 6. In DISTANCE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these 5 seconds, you will have to start step 3 over again. 7. To change your stride length while the display is flashing, press the RESET button. Each press of the RESET button will increase the input by either 1 inch or 2 cm depending on which mode you are in. If you hold the RESET button, the numbers will increase continuously. Release when the display shows the Stride Length for you. 8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to DISTANCE MODE
Dec 31, 2010 | Sportline 340 Step and Distance Pedometer...
How do i set the stride for the sportline 2007 model 4202
5. Press MODE button to reach the MILE MODE.
6. In MILE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these
8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to MILE MODE.
Sep 20, 2010 | Accufitness SportLine Electronic Pedometer...
How to measure your stride?
one long step or stride is about 2.2 feet
Jun 24, 2010 | Exercise & Fitness
I ordered sneakers from 23assoc its been a week and i have yet to receive sneakers or a tracking number
uh ohhhh....i hate to tell you all the sneaker on that website are FAKE. none of those are legitamate jordan brand sneakers their all bootlegs/knockoffs. i also notice all of their "paypal" and "trustguard" logos are just JPEG's pictures. when those websites give those badges they usually lead to a link verifying that its a legit and trusted website. looks to me like you got scammed even if you recieve the sneakers. if you end up not recieving them tho you can report it here http://www.ic3.gov/complaint/default.aspx good luck
Sep 05, 2009 | PayPal Computers & Internet
Stride Rite Lighted Unicorn Slipper Infant/Toddler/Youth Light Pink/ Trim Girl Shoes ; Infants and Toddlers Logo
Top Stride Rite Clothing Accessories Experts
Da Doc
Tom Chichester
ray gallant
Are you a Stride Rite Clothing Accessory Expert? Answer questions, earn points and help others
